Satnav route/manoeuvre list
I have recently bought a superb mark III l&k. Previously had a superb elegance. Only minor issue is when I start a new route I can't see anywhere how to see the turn by turn list the route is going to take. This was easy on the Mark II. I have checked in all the obvious places e.g Route - Information but none of the options show the route list. Any advice gratefully received.
Glen
press the Sat nav button twice or press view in the bottom menu
Thanks for the advice. The view button just gives options of 2D or 3D or destination and pressing the nav button twice doesn't change the screen. Is this something that works on the satnav in your mark 3 superb. It should be straight forward as it was on the previous model and is normally a fundamental feature but for some reason I can't find it.
Is this what you are looking for?  From the View "button" select "split screen" This opens a small window (not a split screen) and there is a drop down arrow menu at the top of the new window to select what's displayed. Menu options (from memory) include audio, map (type,zoom etc. options), recent routes - select route and driving directions are displayed. I guess if you have a route active then directions will be a top level menu option.
Edited by peter_k
Thanks for the advice however the split screen only shows the next two manoeuvres. It's not the end of the world it's just nice to know exactly which route the sat nav is going to take.
When you set your destination it gives you an overview of the 3 suggested routes, whilst it is difficult to see exactly which roads the route is suggesting it gives you an idea. You can then select which of the 3 routes you want to use.
