Bolero MIB2 software update 252
If some one needs here is a software update for Bolero MIB2.
Links removed due to copyright
Edited by mannyo
Removed links to copyright material.
:clap:  :clap:
is there one for Colombus? Please
John
I don't want Russian or is it multilingual.
Edited by TheWanderer
Does anyone know how to install the iso ?
The author suggest to do the upgrade only if you trust your abilities, but does not mention what is the procedure.
I have read on a VW forum that a similar update was done using an sd card and ODIS.
Try extracting it to a USB stick or SD card.
I have tested this update (my previous version was 0245)
All I did was unpack the .iso with WinRAR and put the folder structure + .txt in the root of the SD card.
To start with update procedure press and hold the MENU button and wait for the service menu to appear.
Select SW Update, then Update, Select SD card, select Release and finally press Start.
P.S.
​It is multilingual SW
Edited by dskoric
And what are the benefits (if any)?
To he honest haven't noticed any, but still didn't test much...
What I have found on drive2.ru (google translate)
According to TPI software update to version 0252 on MIB2 Bolero fixes the following complaints:
- Is temporarily closed indication of optical parking aid when reverse gear, acoustic signal system is in order.
- Display parking system on the screen does not turn off at speeds above 10 km / h.
- Sporadic failures rear view camera display.
how do we tell when was 0252 released?
Hej guys.
Just installed this update. Did it while I was driving to work (yes, engine-on, start-stop off, bluetooth off, upgrade while driving) - it took approx. 30 minutes and noticed no problems whatsoever. My hardware is H24 and previous version was 241.
As some users already suggested, I unpacked ISO with 7Zip fully to SD card, then accessed the update function with an long press of MENU button. Tryied upgrading via USB day before, but USB option in upgrade menu was grayed out and only SD card was enabled.
I did the upgrade mainly because of promised fixes for rear-view camera, where occasionally I get errors (e.g. if I leave the car in reverse when parked and upon startup it then shows me error "Parking pilot currently not available"). Will see if update improves things... Other changes I didn't notice yet.
Still have to plug in VCDS and look for possible errors - not sure if version confirmation via diagnostics is required, but there was a screen suggesting something like that at the end of upgrade..
Edited by milanj
How come this is not available via the official update portal?
John
Apparently there is :) < link removed>
mod note: please do not post links to copyright material.
Edited by mannyo
Remove copyright links.
Because firmware updates are officially dealer only and should never be in the public domain, the links posted at the start of this thread have been removed as they should have never been in the public domain and breach forum rules.
There is a reason they are not public, if the update goes wrong then your dealer is not going to want to know and you'll be left with a headunit that will not be fixed by a dealer.
Edited by mannyo
Gotcha, it is a firmware update not a software update, thanks for clearing that up .
The link was to a company that was doing the updates, so unfortunatly not something you could download to DIY
John
There was no actual link for the firmware file, just the information it is available for Columbus (MIB2)..
That argument applies to a whole load of software and hardware modifications that are discussed on this forum all the time.
Can someone please share the link for the Bolero MIB2 in private message ? It was already removed from the post by the time I saw it.
Thanks! :)
  • 1 year later...
i want the Update pls send me an PM
Would love to have the file too. Please pm me if possible.
Link removed. Could someone please PM me MIB2 firmware 0252.
  • 2 months later...
Hello! Can I have also the latest firmware for my Bolero MIB2?
Device part number: 5Q0035842A
Hardware: H25
Software: 0245
Thanks!
Hi, is there a possibility to get the latest Firmware for Bolero MIB2??
Here are device-data:
partnumber of device: 5Q0035840A
HW: H24
SW: 0245
Media-Codec: 2101.0.0.10
Many Thanks to you guys!
  • 4 weeks later...
Hi,
Anybody has the update file to share for Bolero MIB2?
Partnumber of device: 5Q0035840A
HW: H24
SW: 0245
Thanks in advance.
