Engine Fault codes
I am about to buy a 2012 Octy rs Wagon for the misses and found these fault codes during a scan..
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0020
   Revision: AAH18---    Serial number:
   Coding: 0203000C1C070160
   Shop #: WSC 73430 790 00090
   VCID: 79F9BB1E30BD9D8992-802C
2 Faults Found:
000370 - Fuel Trim; Bank 1
               P0172 - 000 - System Too Rich - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 136316 km
                    Time Indication: 0
                    Date: 2017.01.24
                    Time: 11:53:17
             Freeze Frame:
                    RPM: 758 /min
                    Load: 22.0 %
                    Speed: 0.0 km/h
                    Temperature: 93.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 136015 km
                    Time Indication: 0
                    Date: 2017.01.18
                    Time: 16:28:09
             Freeze Frame:
                    RPM: 841 /min
                    Load: 23.9 %
                    Speed: 0.0 km/h
                    Temperature: 93.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.970 V
Are these issue of concern or can they be cured over time?  I have test driven it and all is good other than a rich petrol smell while idling.
Cheers...
will do thanks langers2k
They could be related, i'd probably solve the evap fault first either one of the two valves or a new canister likely required.
If the trim problem remains and turns out to be a faulty injector or something that is a more significant and costly problem.
To protect yourself against an unknown, you may want it repaired or inspected before you purchase.
