Securtiy Access code for 2010 Skoda Octavia MKII 1.4TSI
Hi all,
I need security access code for login with vcds to my car. Known access code (like 31347) won't work with my car. I want to turn on some of hidden options like LED plate lights etc.
My Car: 2010 Skoda Octavia MKII (1.4TSI (CAXA))
Thank you.
Got an autoscan?
Most things shouldn't need an access code on a PQ35 based car, just use the long coding helper...
Some of hidden options need code. If it shouldn't need access code turned on but i need other options.
Hidden options such as what?
As an example from your first post, if your BCM supports LED plate lights, it's normally byte 17, bit 7 in module 09. There is no need for any access codes etc to do this.
Please explain exactly what you are trying to do and an autoscan to see what your car is made of.
are you using a dodgy version of vcds?
1. front and rear Teardrop  wipe
2. CH / LH with fog lamp
3. comfort signal blink count from 3 to 5 etc.
This options need login adaptations page from central electric interface with vcds program.
I don't think any of those need access codes on your car.
That's assuming a 2010 Octavia in Turkey is a MK2 FL and PQ35 based, can you post an autoscan so we can actually offer some help?
The SA codes are also different for each controller.
Your first two certainly do not require a SA code as they are done under coding and not adaptations.
What VCDS interface are you using? it sounds like it is a clone.
