Inside Canton Amplifier
On 23/09/2023 at 07:30, Internetdivisor said:
For all you guys that are really tired of this crappy bass and want to fix it permanently without adding anything else like DSP and Amps+Helix AAC+(or other alternatives) get the Audi 80A035382A and retrofit it into the spare wheel cutting the foam if you have storage space or adding it if you have a spare wheel.
What you need to do it OE Style is:
1. Audi 80A035382A* take care for the code because 80A035382(Without the A) is on 40W and 2Ohm single channel
2. Skoda 5E5867427P for replacing the empty space after the removal of the Canton Sub Box
3. 191972714 Female plug (You plug the male connector that goes now into your Canton Sub)
4. 7n0972704 Male connector plug (That goes into the B&O Subwoofer).
Take care of the pinout to keep the phase correct and enjoy the bass that should have been there from the start.
I also suggest to add some sound insulation in and on/around the subwoofer box. This will remove the rattling and plastic resonance sound and make the deeper frequencies clearer.
Enjoy!
Guys, as this genius did above with the b&o upgrade I’ve also just done this after upgrading my front door speakers (canton) to blam super relax 165. The sound is great. If anyone wants clean sound without spending so much the B&O is a heavy upgrade compared to that canton crap! And the subwoofer doesn’t even clip at high volume, I’ve got the sound settings to “Driver” and just adjust your equaliser settings to suit yourself!
  • Replies 50
  • Views 24.7k
  • Internetdivisor
    Internetdivisor
  • Hi, I'm using 2 speakers, getting power from separate channels. already 10 months no problems. My speakers are : http://www.tb-speaker.com/products/w6-1139sif Have a friend using 2 cone woofer :
  • Yes.
