VCDS side mirror adaptations
Hi guys,
i am trying for some time now to make an adaptation in VCDS for the electric side mirrors in order to fold when i close the doors from the remote.
Like it's standard in octavia mk3.
did anyone of you tried this? do you have a solution?
thanks,
florin
For me it works only when I long press remote 2nd time - 1st long press closes windows only.
Thanks for answering Jafo. Fot me this works also but i wqas trying to automatize it :)
Not possible with VCDS.
However on a 2010 Audi TT you can add a relay and a wiring loom between both doors to make this possible... however you will get fault codes as a couple of wires need cutting in the door controllers.
Agreed, its a pain that it can't be set to fold when you lock the door. I resort to turning the mirror switch on the driver's door before I get out.
If your windows are up then they fold on first press (long, three seconds).
On the Octavia III this is included (as far as i know as standard for cars with electric mirrors).
Is it possible to copy some of the coding from Octavia III and adapt it to Superb II?
I have an Octavia III available and i can copy the coding from it.
Florin
The Octavia III (and Superb III) are both based on a totally different platform (MQB) which is why there is no coding on the MKII Superb to do this.
