Emissions remap
It doesn't work like that. The ECU measures pressure differential across the DPF and when it reaches a certain level, it initiates an active regeneration. This will be at or near 100 % loading of the DPF. The ECU can't directly measure the soot mass accumulated in the filter, it calculates an estimate based on differential pressure.
If an active regeneration is interrupted by engine shut down, it'll try again the next time the car is used. If it's repeatedly interrupted then you will eventually get an orange DPF warning light on the dash, and a warning on the MFD to go for a regeneration drive (this is outlined in the manual). If you don't do this, you'll eventually end up with a red DPF warning light and an instruction to drive to your dealer, where you may well be told the DPF is toast and needs replacing.
An additional consequence of repeated interruption of regens is that you'll end up with fuel in the engine oil: during active regeneration, extra fuel is injected near the end of the combustion cycle to flow through to the DPF to help it light off. If you interrupt regeneration, this fuel stays in the cylinder and drains down into the sump after shutdown.
As much as possible the engine will try to regenerate passively during normal operation. This usually happens on longer runs where the engine can get fully up to temperature and stay there for long periods. Under these conditions, the soot in the DPF is constantly being burned off without any change in engine operation.
Passive regeneration is part of the NOx management strategy employed in these engines: it's actually NOx that's used to burn off the accumulated soot, converting the soot to CO2 and the NOx to molecular nitrogen gas.
  • Replies 153
  • Views 19.5k
  • For the billionth time, no.   Simply removing the cheat would lead to two possibilities: the car is emissions compliant all the time but has much poorer power and economy; or the car has its
  • I'd like to use this VAG DPF (or similar) to know when my car is performing a regen but I downloaded the free version to test and although I connect to the ECU I get a message to indicate it can't rea
  • Just had the rollback done today. Initial impressions are a slight improvement in response although it wasn't bad before (as the car hasn't done too many miles) Around town and on the A roads at
Hi folks I have this app running now I'm at 95 %at the moment 24g soot but my egr valve is at 61% is    This significant would appreciate some comments
Edited by Razzertrevor
The percentage figure on the EGR valve is an indication of how far closed it is, a higher value indicates less exhaust gas being recirculated into the intake. If you're in a position to monitor it at full power, you'll probably see it near or at 100 % as the engine pulls in as much fresh air as possible to maximise power.
Thanks my friend I've only looked at it at tick over I'm hoping it's not going to regen as much now its Had update rolled back
The ever position shown is instantaneous and changes all the time. Looks like I am averaging 300miles between regenerations but as I commented before when it regenerates it does not return to 0% or 0g of soot
Where did you get it done?
Shark tuners in Mansfield £120 includes vat
Thanks. I will give them a call
01623 332233 I've noticed a difference already engine quite mpg better I never got more than 39-40 now I'm getting 45+ just nocking about in the town shopping
I've had yet another communication from Skoda UK. It seems that they've finally accepted that many owners do not wish to have the "fix" and you can now officially opt out by visiting www.serviceaction.co.uk. You enter your VIN and Reg. No. and you will apparently be taken off the mailing list. I'll wait and see what happens next.
Drefaldwyn
That's good news for you who made the decision not to have it done but they still won't except that it as balls up a lot of cars and for people who have had it done. I hope the next thing is they roll back the cars they have done hahaha
@drefaldwyn received - I think the same - leaflet few days ago - but I won't be replying in any way, in case they want to use it against me in the future.
 I figured that either responding or burying my head in the sand and ignoring it wouldn't materially affect anything. After all they'll know whether or not your car's had the fix anyway and can also demonstrate that they've taken all reasonable steps to contact you.
As always, it's up to the individual - do whatever you feel comfortable with.
Drefaldwyn
Do what ever might cost you less and save your nearest and dearest having to pursue the VW Group and management over Corporate Responsibility,
& the UK Government for allowing the German Authorities to lead them with Approvals of not fit for purpose Defeat Device Removal and new Engine Management.
http://channel4.com/news/vw-software-fix-has-damaged-vehicles
All to come out in the wash yet!
Has any body blanked egr valve off yet and what are the consequences if any does it effect engine management systems
Bad idea. ECU will throw a fit.
If you had the software I guess you could find the EGR demand map and set it to zero. What the consequences of that is I don't know.
Finding all the maps for the EGR demand would be demanding!
Edited by matnrach
Matnrach nice one sounds like a bad idea
Just had first regen since rollback still 5.4 g of soot after regen is this normal
How many more miles between regens do you think you have got with the rollback?
When I get a regen the soot does not return to zero either
Hopefully I will get mine done in the next week or so and will do some statistics as I have taken quite a few data logs with the Torque App with the 'fix' map
When I had the rollback done it was already on 20% had first regen yesterday so will keep you updated when it happens again it was 118 miles between one before so I hope it's better this time will have to wait and see
Are those torque and fix apps any good
Around town and on the A roads at cruising speed, the EGR rate does appear to be less and the number of miles to increase the soot level appears lower but will have to wait to see the overall effect on consumption and the mileage between regens.
Just done 50 miles since regen only 2g soot so hopefully will get a few more miles before next regen
Just installed app.
Almost 500 kilometers since last regen. Regen took about 13 minutes, after regen still 5,4 g of soot, 22% of full left.
