LED DRL and Fog lights no error
I have seen your topics regarding to adaptions on Octavia III.
https://www.briskoda.net/forums/topic/314350-led-fog-light-bulb-coding-adaptation-now-found/
Could you help me with VCDS adaptions settings on Skoda Superb II y.2010? I have VAG VCDS 12.12 release (I know...old version...).
I would like to use LED lights to DRL and fog lights.
I have halogen lights, but soon I will switch from halogen to xenon conversion kit (MTECH CANBUS PROFESIONAL). I don't know if that information change something.
Thanks for your help...
Regards,
Rene
The thread by xpower is for the MK3 Octavia, this is very different electrically to a MK2 Superb so it won't help you.
Your Superb probably has a BCM with a part number starting with 1K0 937 08(4,5,6,7). If it has, VCDS isn't able to change the lighting settings and remove bulb warnings for DRL and fog lights... You'll need to find someone with VCP or ODIS-e instead.
Also, you should update your VCDS software, the current version is 17.8.0.
Yes I have BCM unit: Part No SW: 1K0 937 087 E    HW: 1K0 937 087 E;    Component: BCM PQ35  H+  103 0575
Thanks for your replay.
You can only update if you bought Vcds legitimately
:D
