Installing Speed Cameras on The Amundsen MIB2 - Free Database and Quite Simple to Do!
On 08/10/2025 at 18:58, bigade1 said:
I'm sorry to hear that but that's out of my control. I'm using the same database ( SCDB ) from the same contributor as the July ones. I would revert to using the July ones for now and then check them again in my next upload. That's not saying they will return though - that's out of my hands I'm afraid.
Are you sure you export it right because it is also lot smaller then the July database.
  • Replies 493
  • Views 148.1k
  • Latest Updated Speedcams - December, 2022.   It's been a long while but at last here's the latest update of my customised version of EUR Speedcams ( December, 2022). They consist of the full
  • Latest Updated Speedcams - November, 2021.   Here's the latest update of my customised version of EUR Speedcams ( November, 2021). They consist of the full EUROPE speed cameras which I've sp
  • At last and after a long break - here's the latest update of my customised version of EUR Speedcams ( February, 2021). They consist of the full EUROPE speed cameras which I've split up into four conso
Yup I've definitely exported it correctly - unfortunately I can only go with the database that's shared and it's from the exact same sharer and exact same database source. I even downloaded it twice because I myself even noticed that it contained a couple of files less than previous source downloads but it's out of my control.
many thanks bigade1
Would it be possible to add support for other Vag-group devices as well?
FYI,... this version doesn't work on my Škoda Karoq
Can it be installed on version on the picture ?
Karoq
1 hour ago, Goran6061 said:
Can it be installed on version on the picture ? Karoq, i don't have sd card slot, only USB.
Edited by Goran6061
I'm sorry but I have no experience of the Skoda Karoq but from your picture I would say no. These files are for MIB2 units only. They will only work on the Skoda Amundsen and Columbus MIB2 versions as well as the equivalent VW Discover Media and Discover Pro versions.
Latest Updated Speedcams - April, 2026.
Here goes - Happy Easter lol.
Once again here's the latest update of my customised version of EUR Speedcams ( April, 2026 ). They consist of the full EUROPE speed cameras which I've split up into four consolidated poi categories i.e. Redlight Speedcams, Fixed Speedcams , Average Speedcams ( which also include European tunnel speedcams ) and Variable Speedcams. They come supplied with my own preferred personal choice of icons, shown below, to match each of the speedcam categories. Remember to Install them as I explained in the first post in this thread i.e. after extracting the zip file remember to open the newly extracted folder and place only the PersonalPOI folder and metainfo2.txt file onto your sd card ( Please Note: a usb stick will not work! ). Also, please remember to select/tick the relevant newly added poi categories and the poi audible warning alert in your infotainment map menu settings after performing the update or they will not display on your map or audibly alert you. Hope you all enjoy them!
EU Redlight Speedcam.pngEU Fixed Speedcam.png EU Average Speedcam.png EU Variable Speedcam.png
EUR Speedcams - April, 2026.zip
* Once again credit goes to jungblume2005 from Gpsurl for sharing his files which I borrowed and then converted in order to make this compilation.
thanks bigade1
Thanks once again to all involved in producing and distributing this database.
bigade1 Thanks again for your hard work
Hi ,
I try dowload the latest update of speedcams but seam inside are now all folders.
Is the whole date base still available for another down or can u give me a hads plz ) ?
@bigade1
4 hours ago, MihaiRo2022 said:
Hi ,
@bigade1
Ok - I've just downloaded them to check them out and there is nothing wrong with them. The file contents and the file structures are all correct. I see from your profile that you have a 2016 car so it's possible that you may have a MIB1 device and if that's the case then I'm sorry as these files won't work for you.
Thx so much ! I'll try again , maybe my PC had something. Got 2016 O3, with MIB 2 std and the previous version installed from you, worked.)
Edited by MihaiRo2022
I found out why we have problems detecting or loading Speed Cam POI points:
1. The USB media or SD-CARD is not prepared correctly. In my experience and also in the official instructions it is written that it must be a FAT32 partition and 4096 cluster size and must NOT contain any BOOT records!!
2. The problem with an unrecognized database is that the created database does not support the device in your vehicle. The file "metainfo2.txt" contains 5-digit codes that describe device support or Firmware version support. In the case of an unsupported code, the database will not be recognized or installed.
VW T-ROC ŠKODA KAROQ
I also found another POI database SpeedCam which supports many more vehicles, but I don't know if bigade1 agrees with the post.
I used AI to help capture the data, so there may be some errors!
MASTER LIST – POI KOMPATIBILNI VARIANT ID
🚗 ŠKODA – Amundsen (NAV)
Variant ID Brand Region Firmware Platform HW POI
17206 Skoda EU MST2_EU_SK_ZR ZR Technisat YES
37206 Skoda EU MST2_EU_SK_ZR ZR Technisat YES
47203 Skoda EU MST2_EU_SK_ZR ZR Technisat YES
17254 Skoda EU MST2_EU_SK_ZR ZR Delphi YES
37212 Skoda NAR MST2_NAR_SK_ZR ZR Delphi YES
37214 Skoda RoW MST2_ROW_SK_ZR ZR Mixed YES
🚗 VOLKSWAGEN – Discover Media (NAV)
17210 VW EU MST2_EU_VW_ZR ZR Technisat YES
17216 VW EU MST2_EU_VW_ZR ZR Technisat YES
47213 VW RoW MST2_ROW_VW_ZR ZR Technisat YES
17245 VW EU MST2_EU_VW_ZR ZR Delphi YES
17250 VW EU MST2_EU_VW_PQ PQ Delphi YES
17268 VW NAR MST2_NAR_VW_ZR ZR Delphi YES
17270 VW RoW MST2_ROW_VW_ZR ZR Delphi YES
🚗 SEAT – Navi System
17212 Seat EU MST2_EU_SE_ZR ZR Technisat YES
47215 Seat RoW MST2_ROW_SE_ZR ZR Technisat YES
17247 Seat EU MST2_EU_SE_ZR ZR Delphi YES
🌍 EXPORT / OSTALO (NAV)
Variant ID Brand Region Firmware Platform POI
47208 Seat RoW MST2_ROW_SE_ZR ZR YES
17223 VW JP MST2_RoA_VW_PQ PQ YES
