Paddle wheel retrofit to L&K
  • Replies 112
  • Views 34.2k
  • Hi guys, I finally have my paddles steering wheel. I found oh eBay paddles heated st wheel (only the wheel) for 100 Euro delivery includ. And additionally paddless+View MF buttons. For another 13
  • But the buttons will not work in the Superb, the buttons are very easily swapped over though (I have a vRS / Sportline wheel in my L&K) personally I prefer the perforated leather used on the FBSW:
  • Not correct! If you have MF st.wheel without paddles, your MF buttons on the st.wheel are not compatible with the paddles, as the car was not configurated with paddles and as the paddles are connected
4 hours ago, FDB said:
All,
at the end I did it!!
It was quite easy (just few "bad words" to disconnect the Air Bag from Steering wheel).
All works (🤞 since I tried for about 20 km), no coding and no errors.
Thanks all and in particular to Nedko.
so is ur airbag still disconnected?
or is it connected and all is well now?
i hope its not the first one.
  • 1 year later...
Hi all
Read through this thread and wondered if anyone has ever compiled a list of part numbers of what will and won’t fit?
My car is a 2016 Superb 190 L&K diesel.
Will this fit
SKODA OCTAVIA MK3 5E VRS 2014 MULTIFUNCTION STEERING WHEEL FLAT 5E0419091BQ
IMG_4660.thumb.jpeg.af84a51eb44354aae07a34c37775d1af.jpegIMG_4660.thumb.jpeg.af84a51eb44354aae07a34c37775d1af.jpegIMG_4657.thumb.jpeg.bec83fb592f19d900551bd6582a7ba51.jpegIMG_4659.thumb.jpeg.265f6bcfd64427b58a770c116e95cb9f.jpeg
This is my wheel
  • 3 months later...
I never got a reply here, I’m sure there must be knowledgable members who could’ve helped but just didn’t look in at the time?
I’m just bumping this again as I intend doing this still but varying life events have taken priority.
If anyone has information with reference to my above car details and questions I’d appreciate any help.
Don't think the Octavia wheel is compatible - the buttons are different.
Thanks @D402
i think the buttons are interchangeable between wheels reading this thread. That wheel has long gone anyway.
That's right, but only if you already have paddles. Buttons from a non-paddle steering wheel don't have the extra connectors needed for the paddles.
@D402
Everything I’ve read everywhere suggests that if you change a standard wheel for one with paddles, the paddles just work, no extra wiring etc.
The only time extra wiring is required is if you’re adding a wheel that is heated.
Others correct me if that’s incorrect, I’m just struggling to know what wheels off of other models will be a straight swap.
Would be lovely to a list of if you have a Superb III then wheels from xxxxxx will fit as a direct replacement.
I retrofitted a flat bottom steering wheel with this part 565 419 091 E BGW
My factory one was 3V0 419 091 S CWE.
Plug n play as both were DSG version, and same buttons.
No heating.
This is correct. However, the buttons must have the same functions and you can't swap the buttons from a standard wheel to a wheel with paddles.
No heating.
What car/year was yours?
Do you mean your pigweed already had paddles?
I’m on here for help so please don’t think he seems to know better all the time 😂 as that is not the case.
I feel if the same number of switches/rockers are identical on each wheel regardless of the symbols and functions it will work as it is just communication on the bus? The bus doesn't know what the symbol is, it just does the same function as before?
1 hour ago, MSV10 said:
MY17 Superb 220.
If by "pigweed" u mean steering wheel - yes, as per my post, my original had DSG paddles already.
