1 hour ago, Too Tall said:
I went to the insurance and the garage.
RIP. Mr pheasant!
Whats-App-Image-2021-05-15-at-22-25-38.j
At first sight nothing major, just the foglight access panel was popped out. Nothing looked wrong, popped right back in. Next day in daylight however...
Little bits of plastic fell out...then I checked the center grille...yep...cracked...
At least you get to eat the culprit.
  • Replies 5.4k
  • Views 640.4k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
I hard wired in my dash-cam, and then realised how crappy the glove box closure mechanism is.
Doing 99% of the driving I didn't realise the left hand side doesn't close properly most of the times unless you give it a good kick.
It seems there are 2 problems, 1/ the latch gets stuck and 2/ the aperture where the latch locates is round (surely this should have a flat front edge to locate the plunger?)
Did anyone else resolve this (I see it mentioned quite a lot on other skoda forums) apart from replacing the entire glove box?
Dynamic mirror turn signals
Edited by john999boy
Updated hyperlink.
3 hours ago, Colin170CR said:
Very snazzy Alan. Difficult to do?
nope, easy enough - this video  shows the process well.
I got the version that , as well as indicating, does some cool blue led animation when the puddle lights come on also
https://www.aliexpress.com/item/1005001893801465.html
I took delivery of my MY19 Skoda Superb Sportline (206kw 4x4) in July last year with under 5,000km on the clock and with no evidence of any service history in its previous life as a Skoda corporate vehicle. This car is a long term keeper for me and I intend to look after and modify it to suit my wants and needs, so I had my preferred specialist perform an oil/filter change.
I hit 15,000km last week and took it in for its first (and likely only) dealer service, so that I could establish a relationship in case of any warranty issues in the future. I asked which oil they use and the answer was Skoda oil... this didn't reassure me so after some discussion they agreed I could supply my choice of oil (Liqui Moly Top Tec 4200 Engine Oil 5W30) as long as it complied with their approval and specs, which it does.
Now that I have the car back from the dealer I have replaced the OEM air filter with an aFE Magnum FLOW Pro 5R Air Filter and fitted the DTE Pedalbox that I got recently. The Pedalbox is great in immediately eliminating the throttle lag and improving pedal response, very happy with this and an easy fit thanks to the tips from others on here who have fitted one previously.
Remaining on my to do list is deciding on: a front/rear dash cam setup, improving the air flow from airbox to turbo, a cat back exhaust upgrade and how long I can wait until I upgrade to a Stage 1 tune.
Interesting, I'm assuming this throws no errors?
no errors
So did you buy the blue/yellow ones?
yes, see link in my post, blue function is cool.
As part of preparing my car for a virtual cockpit retrofit, today I upgraded the canbus gateway module (module 19) from 5q0 907 530AM to 3Q0 907 530AC.
This is not an operation for the faint of heart in terms of coding/programming. If you get it wrong, bricking your car is more than possible here..
I got the module used off a VW for £39 on ebay.
I paid eur20 for 1hr access to an odis online account from vaglogins.com, as component protection removal is needed as part of the process.
Remove drivers knee airbag, remove drivers footwell air duct, swap gateway module
I used the guided function in Odis-s to go through all the flashing, parameterization, coding, cp removal, restoring features, etc etc.
Edited by AlVal
After a message came up on my dash a new battery went into my key fob yesterday. This is the 2nd battery that has gone into this particular remote during my ownership. The spare has not had one yet as it's never been used. For safety both keys live in a RFI proof tin in the house when not being used.
I have also recently fitted a K&N engine air filter & replaced the pollen filter.
Had the pleasure of doing another camera on @JBD1974’s lovely Superb which is another one that is almost my cars twin!!
I will be doing the same in a few weeks hopefully
Then the alloys are being changed to veeman fs66 I think, then lowered in a few months
I'd love a little more poke but from a previous bad and expensive engine experience with a bmw I won't be mapping again
1 hour ago, JBD1974 said:
A pleasure meeting you @SashaGrace and I'll echo the comments of others  - thanks for a very professional  job of installing the camera, the bonus coding tweaks and tea.
If you're thinking of installing a reversing camera etc I can't recommend her enough!
That’s awesome!! I’ll let you know when the virtual pedal parts start arriving 😅
A bit small, but it's only an A4 printer!
Virtual pedal, hmmm.....
Retrofitted MIB2.5 high (columbus) to replace mib2, retrofitted virtual cockpit. Havent got the maps coming through over MOST from mib2.5 to the VC yet, must be some coding I missed. Getting working geko/fazit/odis live accounts with cp removal enabled to do this kind of retrofitting yourself is the hardest bit, but got there in the end. You can have a bad day when you start getting these blue screens haha, but got it all sorted
Edited by AlVal
Impressive work Alan.
On 22/05/2021 at 21:56, AlVal said:
Swapped out the second "basic plastic" key shell for a metal capped shell using the metal shell from aliexpress, link courtesy of @SashaGrace
£9.56  30%OFF | MQB Car Intelligent Keyless Go Smart Remote Key 434Mhz with ID48 Chip for VW Passat B8 Magotan Superb A7 Variant 2014-2020 Year
https://a.aliexpress.com/_mrh2g4t
U now need to get the "Superb" version from Superskoda.....
Your video looks like a paid video, this version is far from perfect :(
still waiting for the second edition
On 04/02/2020 at 19:25, MartiniB said:
acceptable for this price,
but i will cross fingers there will come next generation version with side illumination.
 it's a quick vid I made after fitting mine, I've not got any money yet, nor do I really expect some random aliexpress chinese seller to send me money.. :D
I was aware of the lack of visual confirmation from inside the vehicle, but not enough of an issue for me to make me wait in the hope of a better one can't find anyone making that 'perfect' version yet.
here you can see the blue animation when you open the car. Can't decide whether it's cool or naff
product
I'm going with cool!
Replacing BCM module, retrofitting 5q0937084DD (upgrade from CG) , and losing skin in the process
Edited by AlVal
Recently Browsing 1
