1 hour ago, leolito said:
I actually have bits and pieces but not the entire thing - one of the few cars I don't have all the tech info, which bothers me ... I can swap with lots of other literature 😁
EDIT: I stand corrected, I have a "Workshop Manual Superb III 2015 ➤
General body repairs, interior
Edition 05.2018"
File D4B80536B1A which is a 163 page PDF, 19.2Mb
I would love Engine/Suspension sections, if available ... 🥰
I’ll pm you
  • Replies 5.6k
  • Views 737.5k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
Back home this evening and white LED torch installed. It’s B E A utiful. The last yellow light now gone! Doesn’t come out great on the photos but I’m very pleased! Great find by @Danoid
Before
After
Did you mean "Great find by @danoid my dealer"? 😁
Edited by Bap33
This one was purchased legitimately. I can’t speak for @Danoid s one though…
Don't worry, just teasing because of some comments above (not necessarily yours, I give it to you). 😉
Edited by Bap33
Waze and Google maps were set up on the digital dash. Certainly not a must have, but a nice little gimmick.
How did you do it?
Which repo did you use?
14 hours ago, defsix said:
How did you do it?
I’d be interested to know also.
I though this was only possible on the MIB2/2.5- MHI2
But I think you have the L&K like me.. which i thought is the MHI3??
The red tab for the rear seats doesn’t pop up as the plastic trim isn’t seated properly. Read on a post that it needs reseating and then they work properly.
Tried to remove the trim to refit and failed miserably. Twice. Catch broken off on both sides. Lots of searching on Ali express and eBay and couldn’t find them anywhere. Not even the trusty Skoda-parts.com But found them on Skodapartsdirect.co.uk for £7.50 each plus postage.
Replaced top two boot lights, can now see everything yay
Went with these https://a.aliexpress.com/_EwTWKJ0 which @ile7 said about the other day
Edited by Danoid
I wish the hatchback had lights in the tailgate like yours … thinking of fitting something similar but need to work out how to switch them
If you have a powered tailgate there will be a constant power to the latch motor and there may well be a switched earth from the catch. If not will be vice versa. Should be achievable without running new wires out to the tailgate. I’ll have a look at the wiring diagram later.
Well a couple of weeks ago I had 4 new tyres fitted as when I bought the car all 4 were different types, I just got some unknown ones from National Express,, I’ve bought Cabin, fuel, Air & Oil filters, still got enough oil for this service, and I just received a new DSG gearshift trim (the chrome was peeling of the original) and while on eBay I “accidentally” bought a replacement boot light, that the seller showed the sticker and was the F version ( £30+ p&p) I’m blaming you lot …
Run these tyres on my Porsche wheels
They handle really good in wet and dry!
@Binx1310 ThanQ .. yep I’ve got powered tailgate, and just ordered another set of the led lights I fitted into the boot last time,
@RogueWagon ThanQ , I thought I’d risk going by the label which looks great for the price, but was then told that there’s no real regulation and each band (A to E) could be vague between one manufacturer and another
No warranty!
Doesn’t even need to be powered tailgate. If you find the central locking motor in the rear lid.
Thin grey / blue wire (circled in brown below. Ignore the red one. That’s incorrect) gives switched earth that will energise when boot open. This is how the standard trunk lights (w18 and w35 on the diagram) are switched in the hatch so should be no issue. You can splice in the wire anywhere or make y connection at the plug.
You would also need a constant live and it needs to be one that is live with ignition off. The only one I’ve found from wiring diagrams is on the illumination for the button to close the rear lid. Red/blue wire in pin 1 on the plug. The other side of this illumination is the grey/blue wire (pin 4) already mentioned so potentially you could take a feed from both at the connection to the button.
I think these are the right plugs: https://a.aliexpress.com/_EwDOgHg
You would just need to cut a rectangular hole in the plastic in a strategic position to install the lights.
Edited by Binx1310
Oil and filter, air, fuel and cabin filters all changed today.
Brake discs are all looking worn/pitted, so will need changing when pads are down. Probably aided by the storm in Blackpool a couple of weeks ago!!
@Binx1310 ThanQ for the info I’ll look at it when the new cables I’ve just ordered arrive …. 🤔🤔 do you have shares in Aliexpress by any chance??? 😂
@Sheriff when you changed the fuel filter did you have to do anything special??? I know on my Passats and my exeo I had to use VCDS to prime the filter but they were inline filters not “drop in “ replacements
No. Just a good source for cheap components!
I’ll edit my post above. Found some other potential wires.
Priming can be done w/o VCDS. Just with setting contact ON and OFF (w/o starting the engine) several times. 10s ON / 15s OFF.
Then start the engine and rev at 15000rpm for 20-30s to get rid of potential bubbles....
I've done this on 6 TDI engines over the last 20 years. No problem at all.
@Bap33 just a note of caution, revving up a TDI until 15k RPM might bring other foreseeable troubles .... 😁😜
Doubt will arrive at 20-30s 🤪
Edited by leolito
Sorry for the mistyping. 1500rpm only of course. 😉
You could always do what I've done with our Kodiaq... 12v LED strip stuck under the rigid roller part of the parcel shelf wired in via a connector to the existing side mounted boot lights. It works a treat and no issues with it staying on or flagging a bulb warning.
Recently Browsing 1
