@Binx1310 - when i did my front grille DRL light bar, i ran a cable from the BCM, through the firewall and into the engine bay.
its located above the passenger (for RHD cars) footwell. there is NO need to remove the glovebox or the fusebox there.
u will need to remove the battery though, which u've done, to pull the wire through.
no need to remove the airbox either.
close up of the grommet .....
grommet located just above where the felt ends......
blue line showing the path
  • Replies 5.5k
  • Views 711.6k
  • Well this was something else....   Not bad for 14 hours work.
  • rob_g_clarkson
    rob_g_clarkson
    Had the wheels refurb'd... and new centre caps and new tyres all round. Much much nicerer. Before and after
  • BriskodaJeff
    BriskodaJeff
    Chucked a bucket of water over it. Three hours later this is the result.         Happy with that
Thanks. Will have a look at this tomorrow. If I can get through there I’ll return the conduit!
Couldn’t find this grommet at all. So went back to plan B. I ran the cables across the back of the bay in some heat proof conduit and then tucked it down behind the heat shield and in through the clutch grommet.
Wires all terminated and routed next to the PDC controller ready for when the correct 18 pin plug arrives.
Today I removed the Ali express blind spot detection kit.
I wasn’t comfortable with how it worked.
  • It only detected vehicles that were gaining on you, if they were alongside at the same speed the light went off.
  • It only detected 80% of those vehicles that gained on you.
  • It just flat out did not work in the rain. And when visibility is poor is when you need it most.
If I cannot trust it 100% then it’s not worth having. It was always just an experiment and proof of concept to see what the kits were like. No wires were cut as part of the install so removal was straightforward. No harm done other than £40 and my time. And I enjoyed the experiment so it was just a small cost. I am wholly expecting some “I told you so” comments!
I may look to do OEM fit in future but for the cost even with second hand parts, and the in depth coding required, probably not for what I would gain.
Hopefully finish off the front OPS set up today if the unit I am waiting on doesn’t need a new dataset.
Edited by Binx1310
Tis a shame it didn't work out, then again not surprised given its an AliExpress version.
1 hour ago, Binx1310 said:
Heute habe ich das Totwinkel-Erkennungsset von AliExpress ausgebaut.
Mir gefiel die Funktionsweise nicht.
  • Es erkannte nur Fahrzeuge, die aufholten; wenn sie mit der gleichen Geschwindigkeit neben Ihnen fuhren, ging das Licht aus.
  • Es erkannte nur 80 % der Fahrzeuge, die auf Sie aufholten.
  • Es funktionierte im Regen einfach überhaupt nicht. Und gerade bei schlechter Sicht braucht man es am dringendsten.
Wenn ich dem Ganzen nicht hundertprozentig vertrauen kann, ist es die Anschaffung nicht wert. Es war ja nur ein Experiment und ein Machbarkeitsnachweis, um zu sehen, wie die Bausätze so sind. Beim Einbau wurden keine Kabel durchtrennt, der Ausbau war also unkompliziert. Außer 40 Pfund und meiner Zeit ist nichts passiert. Und da mir das Experiment Spaß gemacht hat, waren die Kosten ja gering. Ich bin schon auf einige „Ich hab’s dir ja gesagt“-Kommentare gefasst!
Ich könnte mir vorstellen, in Zukunft auf OEM-Passform umzusteigen, aber angesichts der Kosten, selbst bei gebrauchten Teilen, und des erforderlichen detaillierten Codierungsaufwands, lohnt sich das wahrscheinlich nicht.
Hoffentlich kann ich heute noch die Einrichtung des vorderen OPS abschließen, falls das Gerät, auf das ich warte, keinen neuen Datensatz benötigt.
Ich habe 2 Stück OEM Skoda Halter für blind Spot daheim. Besorge dir 2 fix fertig codierte und Parametrierte 2Q0 Steuergeräte. Lege dir dafür die 3D Druck Adapter dazu. @Lutz_91 hat die selben. Hab einen funktionierenden vas5054a noch bekommst dazu. Du brauchst dich nur um Kabel Satz und Außenspiegel kümmern.
Alles andere per PM
I have two OEM Skoda blind spot brackets at home. For Superb 3 Combi. Get yourself two pre-coded and parameterized 2Q0 control units. Also get the 3D-printed adapters. @Lutz_91 has the same ones. I also have a working VAS5054A unit that you'll get with it. You only need to take care of the wiring harness and the side mirrors.
Everything else via PM.
Edited by Cairus
1 hour ago, Cairus said:
I have two OEM Skoda blind spot sensor holders at home. Get yourself two pre-coded and parameterized 2Q0 control units. Also get the 3D-printed adapters for them.@Lutz_91They're the same. I also have a working VAS5054A that you'll get with it. You only need to take care of the wiring harness and the side mirrors.
I have two OEM Skoda blind spot brackets at home. For Superb 3 Combi. Get yourself two pre-coded and parameterized 2Q0 control units. So get the 3D printed adapters.@Lutz_91has the same ones. I also have a working VAS5054A unit that you'll get with it. You only need to take care of the wiring harness and the side mirrors.
Sounds very tempting. I’ll have a search and see what the control modules would cost. Wiring harness is £40 from Ali.
Success with the parking sensor retrofit. Just a bit of coding to tidy up.
I will check the Moduls for you, to all setting on the table and send you with the Other Things
It works 100%. I didn't want to do it at first either, but I ended up switching from the 5Q0 to the 2Q0 anyway. I made the adapter wiring harness myself. Just popped in a 3D-printed adapter and that was it. Adjusted the coding, and it works great—with LEDs in both the mirror housing and the glass
What is the 3d printed part for?
Hi,
@Binx1310 Just sharing my humble experience. I used to have BSD LEDs in the mirror glasses on my ex Superb Mk3, but I way more prefer the BSD LEDs in the mirror housings on my current Kodiaq Mk1. Additionally, you can trim the LEDs intensity from the MMI (assuming you get OEM parts and correct coding). Much safer!
2 minutes ago, Bap33 said:
Hi,
This is what I would do. I already jumped the gun on the previous project and bought Passat B8 LEDs and a spare set of mirror housings to mount them in to. Will need cutting and gluing but a significantly cheaper option than the pre-made ones on AliExpress, or OEM.
Wieso die Druck teile, weil die 2Q0 Radar Steuergeräte deutlich kleiner sind als die 5Q0. Wenn diese vorhanden sind, wieso neue Halter kaufen? Gedruckte Adapter rein und dann Steuergeräte einsetzen.
Why the printed parts? Because the 2Q0 radar control units are significantly smaller than the 5Q0 ones. If you already have them, why buy new brackets? Just use the printed adapters and then insert the control units.
On 04/09/2026 at 20:31, Binx1310 said:
Wozu dient das 3D-gedruckte Teil?
5Q0 and 2Q0 radars have different mounting positions and, consequently, different brackets.
With the 2Q0, you would normally have to buy and install different brackets. The 3D-printed part saves you from having to do that, allowing you to use the OEM 5Q0 bracket instead.
It’s a great solution from @Cairus.
I took mine for its first MOT yesterday and it passed easily with a comment that it's in excellent condition all round. As it's only 3 years old and has just passed 18,000 miles, it's what I expected.
The crunch comes at the end of this month when the tax is due at £640 - ouch!
On 05/09/2026 at 15:54, Binx1310 said:
Today’s task was to add LED lights to the back doors in place of the reflectors.
Using information from this post.
Tapped into red and white/ brown and yellow wires using posi taps and tidied up with cloth tape.
They project “Superb” onto the floor the same as the front ones.
Note - it’s always worth having some spare door trim clips on hand as they seem to be a sacrificial part!
https://vehicleclips.co.uk/products/door-card-trim-moulding-clip-with-rubber-seal-skoda-5j0867276
Very nice job there, and a very tempting mod to do to mine at some point too. I also need to find time to strip down my wing mirrors as I have the uprated downlights to fit to them, to replace the not very bright factory ones.
Tried to fill up today but hit the pre-authorisation limit before it was full!
Ouch
3 minutes ago, tombee said:
Ouch
I feel much better about my fill up at the weekend. No pre auth here.
15 minutes ago, nick6262 said:
I feel much better about my fill up at the weekend. No pre-auth here.
Took another £20 to get to full!
Ha! I'm planning a drive to Prague next month. Couldn't have picked a worse time for petrol prices...
I wonder if they'll give me a discount for driving a Škoda?
I filled up at CostCo a couple of days ago and super has gone up 2p since then. Happily I'm not planning on going far unlike earlier this year when the prices leapt up just as I was about to drive up to Scotland on holiday.
Topped mine up at Tesco the other day. 99Ron Momentum is up to £1.84☹️.
Using my wife's EV as much as possible at the moment.
Bit of an AliExpress spending spree for me. Bought a wireless Android Auto/Car play dongle as I was bored of plugging the phone in for short journeys. Works fine and well worth the £12 I paid.
Also got a reversing camera that someone on the Octy 3 forum mentioned. For £40 can't complain. No coding required, but routing the cable was a bit of a ball ache.
OG Octy 3 thread and a useful video on cable routing for the estate Superb.
https://www.briskoda.net/forums/topic/485897-how-to-reverse-camera-fitting-guide/
https://m.youtube.com/watch?v=kAndR7pgjcM&pp=ugUEEgJlbg%3D%3D
Edited by jeffl
Add photos
Recently Browsing 1
