@mintyflinty ive got the same ones that @Binx1310 posted a couple of pages back https://a.aliexpress.com/_EJBESM6
These lights have 3 ways of connecting to the car … tiny 2 pin (yellow) a 2pin (that looks like an E) ( blue) which is the same connector in my boot ( superb 2017) and an adapter lead to a larger flat 2pin connector that looks like an arrow shape (green)
  • Replies 5.6k
  • Views 754.9k
  • rob_g_clarkson
    rob_g_clarkson
  • BriskodaJeff
    BriskodaJeff
@Sheriff when you changed the fuel filter did you have to do anything special??? I know on my Passats and my exeo I had to use VCDS to prime the filter but they were inline filters not “drop in “ replacements
No, just a straight change of old for new. It turned over a bit to start and then the eml light came on. Just turned it off and restarted and eml light went out. My mate reckons it was due to low fuel pressure with changing the filter. Been fine since. :)
I found this video where he primed using a code reader (edit: found it’s possible with carscanner so suspect OBD11 and vcds too) but says you can just start normally if you don’t have one.
He also has other basic service videos on superb which are handy.
Edited by Binx1310
Been tightening up on car security, days of nobody steals skoda's are long gone, they steal everything and anything nowadays.
Got a disklok, and moved the obd connector to a hidden place with one of these, it leaves a dummy obd in the original place and if scumbag plugs into it, it appears to work but no coding can be done.
thinking about fitting a hidden kill switch as well
16 minutes ago, Binx1310 said:
I found this video where he prunes using a code reader but says you can just start normally if you don’t have one.
best way is to top up canister with diesel before putting lid back on,
you'll never get any problems with airlocks
I just finished work and the windscreen was frozen…. 1st time using the heated windscreen… wish the rear screen had the same system
Is yours a hatch? Does the hatch not have a heated rear screen?!
the rear hatch window normally has heated elements, i.e. demister.
i don't know if this was an option in some markets or specs.
I would not imagine there is a manufacturer today that still makes a car without a rear heating element in the glass ... even the most basic utility vehicle available here that is not a van has them, even basic vehicles like Lada Nivas and UAZes ...
Now if instead you refer to the fact that the front is like "instant defrost" across all the glass and not in "lines" starting from the filaments outwards, yeah, I agree ...
There are very few cars with the multi-filament option, I remember old Mercedes have that (mine W126 has it), but it is prone after time to "delaminate" which looks awful and for which there is no solution except replacement, which is not longer costly, is just impossible as there are no more glasses available .... ☹️
Didn't you know? All Skodas have a heated rear screen to keep your hands warm when pushing them 🥸
@Binx1310 yep my car is the hatch and does have the standard heater wires, but what imeant wasby the time the windscreen wa clear the rear hadn't made much of a change, infact it wasn't totally clear until i was half way home,
Ah im with you, that makes sense. I've never had the luxury of a heated front screen.
Heated front screens are wonderful in this cold weather. Standard fit item on my 2016 L&K & my first experience of one. Better still though is my wife's EV which we can pre-heat & defrost the entire car without even leaving the house.
Agreed - heated front and rear on, seat and steering wheel. Toasty in a minute.
Alright alright all these L&K owners rubbing it in. I have to make do with ice scraper and heated seat!
At least your Skoda came with an Ice Scraper 😂.
Loads of plans but seem
To have lost interest now
Unsure whether to mod it because it’s such a nice car as it is
In my experience, once you start, that’s the seal broken…
Especially on AliExpress!
Haven’t started yet 😂😂😂
Though I have heated windscreen, I sometime use a very efficient method when I'm in a hurry to leave: a simple spray bottle that I fill with household alcohol. This prevents any risk of scratches on windscreen and any glasses. With ice scrapper, if your glasses are a bit dirty, it may cause awful scratches. 😬
BTW, it reminds me an old joke in the '80s:
_ Do you know why Ladas have heated rear screen?
_ To keep your hands warm, when you have to push it. 😂
Edited by Bap33
unfortunatly i dont have a steering wheel with paddles or heated wheel ( really cant justify ebay prices ) but the heated REAR seats seem warmer than the front 😇😜
Dear vehicle dismantlers of eBay. Please please please don’t write on the most expensive part of the wing mirror with tipex/paint pen….
30 Minutes with a soft plastic trim tool and some window cleaner and it’s as good as new! I could have used a solvent on it but I dare not in case of damaging the dimming function.
I Will need to plug it in to the car to adjust the glass down to remove it so that I can swap the black mirror cap onto it. But that’s a door card off job and not one to do in the dark at 2•C!
Recently Browsing 2
