Superb DSG fault 19143
Super annoying (and maybe expensive)! Been enjoying my 2014 Superb for 2 years. 6-speed DSG always been smooth and great.
Had the oil changed and now only 71,000 on the clock and never towed or driven hard.
Then last night, when cruising  along in 6th, it suddenly started changing wildly and the people behind me almost drive into the back of me.
Call the AA, they sent some local garage who turned up, not even having any diagnostic kit and said they could only tow and do no more.
Got the car to my local garage. VCDS scan shown below.
The garage also scanned it and came up with the same thing, except their equipment added 'Short to Earth' in the description, which I think is important info.
Just wondering if anyone ever had this and what it turned out to be.
It really did not feel like a mechanical issue. It was sudden and crazy (and is intermittent). The garage is going to send away the Mechatronic unit. It sound like big bucks if Mechatronic or Gearbox need replacing. Also wondering about the ECU which controls the Mechatronic unit.
The Ross Tech VCDS web site has some strange possible causes of this error and most sound mechanical. But the other diagnostic kit did report 'Short to Earth' which I think sounds a lot more likely.
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 062 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4008
   Revision: 05652104
   Coding: 0000020
1 Fault Found:
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 007 -  - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100111
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 120990 km
                    Time Indication: 0
                    Date: 2019.01.14
                    Time: 17:46:23
The transmission will have a bunch of sensors to monitor where everything is inside there. It's possible one of those is acting up.
I'd be inclined to have a gearbox specialist familiar with the DSG look at it before doing anything else.
I've had the mechatronic unit removed and sent off to a DSG specialist in Birmingham, we see what they find
good luck, hope they find something simple and not too expensive.
I will share when I know more
