MY17 Superb SLA Headlights Upgrade - Help
27 minutes ago, Wilku said:
Sorry for the post above.
I have a Superb III 2016 with module 55 and I need a file with parameters for it, can anyone help me? Please
MY15 - MY16 uses different headlight electronics to MY17 - MY19.
MY20 onwards is different again.
Unfortunately I do not have the parameter file for 55-headlights module.
  • Replies 140
  • Views 44k
  • Finally got some good news to report - the final piece to the puzzle, the AFS_MDF data file, was successfully loaded today, via ODIS, into the 4B module and the SLA functionality is now fully operatio
  • Amazing guide @JR RS and this helped me out massively.    Just a few things I wanted to add to this, if you are met with High beam shutter faults after the conversion as shown in the picture
  • This is what my Skoda looks like now
I build the new Xenon Light.
Coding Unit A5 und 09 succesfull.
Problem was flashing 4B.
Now I have the ERROR "Dataset implausible" in Unit 4B
I flashed with this selfmace .xml for VCP. (attachment)
I can not code the LeiMo Units, also Error LeiMo left und right not coded.
I think maybe the ALFID is incorrect.
I tried with 44 and without any ALFID.
Can anybody help me?
4B_3Q0907338_VCP.xml
Hello,
i flashed my 4B unit to 0286 and could install dataset via ODIS.
Now I cannont run basic setup in 4b and i think there is a wrong coding in unit 4B or Unit 09.
Can somebody send me please Adpmap and Autoscan of Unit 09 und 4b?
regards.
5 hours ago, Nudelsuppe said:
Hello,
regards.
Do you have B type SLA headlights or type A?
7 hours ago, Nudelsuppe said:
Hello,
regards.
not sure why u flashed ur 4B module to 0286. there is no flashing required, for any of the modules.
mine is the factory original 0285.
also, did u change the LCM under each headlight to the 4H0 version?
i'll send u shortly, via message, my admaps for 09 and 4B modules.
meanwhile, below is my module versions:-
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001706702006
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 33361 790 00141
   ASAM Dataset: EV_BCMMQB 017001
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B0184D77025830A8-802A
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   001 0285
   Serial number: 19031710522619
   Coding: 000000020100066E06007F01000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BDD8B0942278EB756-8026
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: Leimo links  H02 0013
   Coding: 000000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: Leimo rechts  H02 0013
   Coding: 000000
Changed to Type B
   Coding: 000000
   Coding: 000000
i changed the headlamps to Model B.
I changed the 8U0941329 against 4H0941329.
The other Moduls i took from old headlamps.
I coded the 09, Shutter (Leuchte 10 and 11) disabled, Eyeleashed enabled (Leuchte 16 and 17).
I coded the 09 for DLA and i coded the A5 Byte 21 to Hex 40.
After that i trided to flash the dataset for my 4B.
After flashing there was a Error in 4B, invalid dataset.
To rescue the situation we flashed the 4B to SW 0246 and took a Dataset from another car with DLA, work done with ODIS.
Now i can not run basic setting and the error is shown in Unit 4B "no basic setting".
If I try to run manuel the basic setting, VCDS, OBD11, ODIS say, "conditions wrong for basic setting".
Every time i start the car i can see and hear he is trying to run the basic setting.
Even when i delete the fault in 4B, directly ater deleting he is trying to run basic setting an the fault comes back.
I dont know what to do now 😞
Maybe try to flash on 0285 and try Dataset you send me.
Adresse 4B: Multifunktionsstg. (J745) Labeldatei 3Q0-907-338-V1.clb
Teilenummer SW: 3Q0 907 338 HW: 3Q0 907 338 C
Bauteil: FCM MQB Low 002 0286
Seriennummer: 23101811601588 Datenstand-Nummer: V03935274LG 0001
Codierung: 000000020100066A02007F01000000000000000000000000000000000000
Betriebsnr.: WSC 12345 123 61029
ASAM Datensatz: EV_MultiModulContiVW48X 001010
VCID: 72BDDAD5042CDF4A09F-8026
Leistungsmodul für Scheinwerfer links:
Subsystem 1 - Teilenummer SW: 4H0 941 329 HW: 4H0 941 329
Bauteil: Leimo links H02 0013
Codierung: 000000
Leistungsmodul für Scheinwerfer rechts:
Subsystem 2 - Teilenummer SW: 4H0 941 329 HW: 4H0 941 329
Bauteil: Leimo rechts H02 0013
Codierung: 000000
2 Fehlercodes gefunden:
13705479 - Datenbus fehlende Botschaft
U1121 00 [008] - -
[Kamera_FDD_Obj01 data bus missing message]
Sporadisch - bestätigt - geprüft seit letzter Löschung
0032 - Scheinwerfer
C107E 54 [137] - keine Grundeinstellung
Warnleuchte EIN - bestätigt - geprüft seit letzter Löschung
What is the part numbers for the camera you have fitted? Is it 5q0, 3q0 or 2q0? @Nudelsuppe
Also why do you keep updating the software of 4B, and how sure are you that the dataset you are using is compatible with that software version?
newer isn’t always best and not always compatible?
Camera 3QD980654
H09
SW1272
Its not a newer Firmware!
We flashed from 0345 down to 0286, because there was a dataset with DLA available at ODIS.
286 is the correct firmware version.
Use the dataset supplied in this thread.
Then please provide a full scan if the problem persists.
@Nudelsuppe - 3QD?
I've not seen a D version before.
Mine is 3Q0.
Also u say ur 4B firmware was 0345.....I'm starting to think u don't have a pre-facelift Superb.
Wat model year is urs?
The 4B parameter file I've shared with u has been used by a few others, with success.
I'm not sure why u r having so many issues.
18 minutes ago, JR RS said:
@Nudelsuppe - 3QD?
Mine is 3Q0.
3QD was fitted on the superb from october 2017 to november 2018 :)
Unless his is 3QD980654A in which case that was fitted up to july 2019.
2 hours ago, JR RS said:
@Nudelsuppe - 3QD?
Mine is 3Q0.
Skoda Superb 3v 01/2019
Style Edition
pre Facelift MY2019
3QD und 3Q0 have same Dataset but different Hardware and Firmware.
3QD = Made in China
3Q0 = Made in Germany
Problem solved.
It was a wrong coding in 4B.
My car has no DCC, but we took data from a car with dcc.
So we coded 2 LWR sensors, but my car only has one.
After coding to 1 Sensor i could run basic settig and every thing is okay.
Much thanks to ervery one here for help!!
1 minute ago, Nudelsuppe said:
Problem solved.
You also made sure to change LWR  source to BCM opposed to DCC module I assume?
glad it’s sorted!
Yes this was all time on BCM.
I didnt know without DCC the car oly have 1 Sensor.
We read the electric diagram and saw that only one sensor is connected to 4B unit.
Good to hear u got to the bottom of ur problems.
The DCC and headlights are all interrelated, including other systems.
5.12.2023 o 23:03, Nudelsuppe powiedział:
Problem rozwiązany.
To było błędne kodowanie w 4B.
Mój samochód nie ma DCC, ale pobraliśmy dane z samochodu z dcc.
Więc zakodowaliśmy 2 czujniki LWR, ale mój samochód ma tylko jeden.
Po zakodowaniu do 1 czujnika mogłem uruchomić podstawowy settig i wszystko jest w porządku.
Wielkie podziękowania dla ervery one here za pomoc!!
 hello, I am also changing from 015A to 015B, I do not have dcc, I have 4h modules changed from 8u. Can someone describe the coding that I should do, because I have a lot of errors? Can I ask for a vcp file to upload?
i notice u have a 2016 year model - does ur car have the 4B multi-function module or the 55-headlight module?
reason i ask is that MY15 and MY16 r a different design, using the 55-headlight module, and not the 4B module, which was introduced from MY17 onwards.
Im have a 4b Module
Adres 4B: Modu≥ wielofunkc. (J745)       Plik etykiet:| 3Q0-907-338-V1.clb
   Oznaczenie elementu SW: 3Q0 907 338     HW: 3Q0 907 338
   Komponent: FCM MQB Low   001 0285
   Numer seryjny: 06111610521810 Numer zestawu danych: V03935248XG 0001
   Kodowanie: 000000020100066A00003F01000000000000000000000000000000000000
   Kod serwisu: WSC 33361 790 00156
   Zbiůr danych ASAM: EV_MultiModulContiVW48X 001010
   VCID: 72BED23AF420B3EA09F-8026
If you have 4B you have to flash new dataset.
After flashen you can code the Modules.
Attached is a tutorial and dataset flashfile for ODIS and VCP.
In the tutorial i wrote everything to code
Skoda_Superb_3v_DLA_retrofit.zip
Thanks in next week I’m thing I’m have time to coding I’m tell of results 😁😁😁
Hello guys.Is there anybody who has dataset for SLA for unit 55?
Hello, thank you very much for your help, the headlights work great. I managed to do it only yesterday, lack of time.
the vcp file didn't work, but Oddis Enginering gave me a great description.
