MY17 Superb SLA Headlights Upgrade - Help
Sorry, Lot of Work, tomorrow please
  • Replies 148
  • Views 46.7k
  • Finally got some good news to report - the final piece to the puzzle, the AFS_MDF data file, was successfully loaded today, via ODIS, into the 4B module and the SLA functionality is now fully operatio
  • Amazing guide @JR RS and this helped me out massively.    Just a few things I wanted to add to this, if you are met with High beam shutter faults after the conversion as shown in the picture
  • This is what my Skoda looks like now
Any news mate?
Yes, but only VC Tool, i get answer from a friend, i will Hope
  • 3 months later...
hello. I only need the eyelashes. The lamps are in the car with part number “b” with the original lamp modules with part number “a”. The eyelashes work but my reflectors don’t. What should I do in this case?
Edited by Kriszfabia
I don't understand - u say original lamps r version B, but then u say original lamps r version A.
Which one is it?
U say u need eyelashes, but then u say ur eyelashes work.
Which one is it?
Wat do u mean by reflectors?
Is ur car a pre-facelift or facelift?
Edited by JR RS
2016 09 factory date
I usually replace factory “a” part number headlights into a “b” part number ones.
My original headlights “a” part number ndings.
The eyelashes coding is okay but my high beam is not working
I don't want automatic lights, just the Eyelashes.
Is there a solution for this?
I transferred all the modules from the old lamp.
Sry my bad english
You have To replace the Controller in the Lights
@Kriszfabia - as @Cairus mentioned above, u need to replace the light control module (LCM).
The one that comes with version A headlights does not know how to control the high beams on version B headlights.
Hence u'll need to replace LCM if u want ur high beams to work again.
Control module for version A is 8U0 941 329.
Control module for version B is 4H0 941 329
On 23/12/2022 at 23:52, AndrejZ said:
Hello guys.
Thanks to JR RS guideline I made a change of headlights.Difference is that I have unit 55 instead of 4B.
I uploaded parameters via ODIS from car which had SLA from factory.Only topic which I have is the coding of Slave units.I am not able to change it via master to the correct value B30000 .As a result,my High beams are not working and there are faults that the units are incorrectly coded.Is there anybody who can help?Thanks
Hi mate, could you please send me the dataset for unit 55? I have been looking for it for quite some time.
On 09/02/2019 at 01:28, JR RS said:
the headlight plug on version B had slightly different pin arrangements, however the wiring harness from the car to it had that covered. i.e. it wasn't blank and had a matching wiring to the pin.
Hi JR RS, could you please give more details about this?
Is the wiring/pin order in the wiring harness different for B headlights than the A ones? Or are they 100% plug n play?
no, the wiring harness on the car side does not need to change.
in other words - it caters for both version A and version B headlight plugs.
i didn't have to change or modify anything with the wiring harness when i switched from A to B.
Ok, but what did you mean by "different pin arrangements"?
on the headlight itself, where the wiring harness plugs into, is different between version A and version B.
from memory, there r more pins on version B headlights.
Got it, thanks!
By the way, do you know if both headlight units should be the same generation? (015-016 or 017-018, in part numbers).
Found a good deal for a 015 left unit and a 018 right unit and Im curious if they would work ok.
17 minutes ago, Codrut20171 said:
Got it, thanks!
hmmm, that i don't know sorry.
i do remember reading (back then) that it's "best practice" to stick with the pairs, i.e. 15 with 16; and 17 with 18.
however, who knows, perhaps they might work if u interchanged them, i.e. paired 18 with 15.
Hi, do you know this 4b module parameters for Skoda compatible with Passat B8 2017? Same module number. I need activated for DLA, i also have A5 camera and high led. i just coded using VCDS.
Thank you.
If anyone have this parameter can share to me.
Vcds can not Upload dataset
I have VCP and Odis, can anyone help me with the dataset?
Dataset for 4B? VCP dont have?
Remote?
Edited by Cairus
Send me a message with ur email address - I'll email u the 4B parameter file
Edited by JR RS
  • 4 weeks later...
Hi, od anyone here willing to share dataset for 4B? I did also swaped headlights and I'm on the search for dataset...
Wat Model Year is ur Superb?
I can give u the 4B parameter file.
2018, prefacelift
