MY17 Superb SLA Headlights Upgrade - Help
This is what my Skoda looks like now :D
  • Replies 133
  • Views 42k
  • Finally got some good news to report - the final piece to the puzzle, the AFS_MDF data file, was successfully loaded today, via ODIS, into the 4B module and the SLA functionality is now fully operatio
  • Amazing guide @JR RS and this helped me out massively.    Just a few things I wanted to add to this, if you are met with High beam shutter faults after the conversion as shown in the picture
  • This is what my Skoda looks like now
Hi, I have a Skoda superb 2016, I want to install the 2018 SLA headlights, tell me the encoding for the 55 block.
Edited by Yury84
Sorry, unfortunately I don't have the coding required for MY15 and MY16, nor do I have the parameter file for 55-headlight module.
  • 6 months later...
@grzybek31Hi, how did you do it?  I have a Superb 2016 with Halogen headlights. Is it possible to make it like yours? Thanks.
Converting from Halogen headlights to SLA Bi-Xenon headlights, let alone normal Bi-xenon headlights, will b a massive job!!
I would not recommend it.
In addition to the Bi-xenon headlights, u'll need:-
- 3x levelling sensors
- 2x light controller modules per headlight
- 1x ballast per headlight
- 1x AFS module
- completely different wiring loom
- upgraded BCM module
- A5 camera
- headlight washer
- upgraded washer fluid tank
.....and a whole bunch of coding and parameter files for various modules.
Edited by JR RS
In halogen headlights I’m thing too many changes to make
  • 1 year later...
On 28/10/2020 at 06:45, JR RS said:
Hello! I want to install SLA Lights for my superb mk3 2019. I have problem with SLA parameters file. Can you send me this file for e-mail? Thank you!
@Serhii1886 - sure thing. But first, do u have a pre-facelift or facelift MY19?
Facelift have Xenon? Only LED Low and Matrix or Not?
Its Pre-facelift MY19, with 4B modules
Cool, thanks for confirming.
Send me a private message with ur email address - I'll send u the 4B parameter file.
Facelift has Matrix lighting using LED.
Pre-facelift has Smart Light Assist (matrix light utilising rollers) using Bi-Xenon.
@JR RS I can’t send private message because i’m new user((( can you do it?
Edited by Gizmo
tagged JR RS, Serhii1886, please don't add email address on posts
I just sent u an email, to the Gmail one u had shared before.
Thank you so much! 🤝
Hi everyone, I'm following this amazing retrofit guide. I have already upgraded to version B headlights and the 4H0 LCM module. Could anyone please share the AFS_MDF data/parameter file for the 4B module?
I'll send u a Private Message shortly so u can give me ur email address.....
Hi guys, I would want to do this retrofit(or matrix), but im not sure my car supports it.
I have swapped to EC BCM, so this is not a problem.
I currently have A xenons, and as my car is MY16 I have 55-Headlights range module, not the 4B one.
Can SLA with B Xenons work with 55? What about the facelift matrix headlights? Is the 55->4B swap possible?
I attached photos with my current 55 module.
Thanks!
You need for Matrix Facelift BCM, Facelift 4B Unit and Facelift A5 unit
Thanks!
MY15 and MY16 use Headlight module 55 which requires a different parameter file for SLA.
U can't use the 4B module SLA parameter file.
I don't have the SLA parameter file for module 55.
If u want to retrofit facelift headlights, u will not only need new headlights but u'll also need a new facelift bumper. Wiring is also different. BCM, Camera, AFS and LCM modules r all different.
Way too much hassle.
Edited by JR RS
What about the B Xenons, with SLA?
A5 currently is 3Q0 with updated fw and custom dataset , should work.
I know, all that work is not a problem.
Just wanted to know if current 55 supports SLA on Xenons and where can I find a dataset for it, for matrix I would change A5 cam to 2Q0, the BCM is ok , and I would swap the 55 to a 3Q0…E 4B module as I’ve found a dataset for superb for it.
MY15 and MY16 with 55-Headlight module can do SLA with version B lights - yes.
But I don't have the parameter file for 55-headlight module.
I will Check
On 20/02/2026 at 13:50, Cairus said:
I will Check
Hi mate, found anything?
