Multiple error/warning lights - ABS Wheel Speed Sensor issue?
hopefully someone can help me
Message me your VIN and which corner of the car needs sensor, and I'll tell you the correct part number. Tell me the complete  exact part number of what has been fitted too.
Hi pete I can only send one message a day here
I'll send you a message with an email address.
  • 2 years later...
On 31/05/2019 at 22:49, JezHocking said:
In case anyone is reading this with the same symptoms.
I purchased an OEM sensor https://www.onlinecarparts.co.uk/ate-7618461.html for £38 inc delivery, arrived from Lithuania 2 days later.
Part number for car with self parking is WHT 003 864 A, there are loads of manufacturers on this site but I went for the ATe one as this was the same as the ones originally fitted.
I have been driving around for 2 weeks without a hint of  a problem or error message, so touch wood this seems to have cured all my issues. :-)
Mine lit up like a xmas tree this morning obd points to sensor booked in to my local who does good reasonably priced repairs for me as not got time to sort myself.
  • 11 months later...
On 22/09/2021 at 16:46, village said:
So thought i ought to follow this up, just in case it's of use to someone else.
My first plan was to ignore it, which i did, and it worked, albeit briefly. So when I next got in the car the  next day, all the lights were still there, but went off after a few yards and then I cleared all the codes on carista.
Next long journey, after about 5 hours, all the lights came back. Then went off, came back, went off and then came back again and stayed on for the rest of the journey. But again, when left overnight they would clear after a few yards the next day.
This cycle continued for a while (looks like 6mths from the date of my last post!), and it became apparent that the hotter the ambient temp was, the sooner the fault would occur.
Checked the live data on Carista for wheel speeds, which all looked ok and suggested my idea of a faulty abs sensor was off, so, after i got a new light (Error: Brake. Workshop!), I bit the bullet and got skoda to run a diagnostic. Nothing enlightening from the diagnostic, but the tech reckoned it was lightly to be a faulty main power relay. There are two main power relays, and apparently the other one doesn't control anything overly important, so power relays have been swapped round and we'll see what happens. If that solves it, a new relay is only £23, so fingers crossed....
These were the warnings I was getting as at the last activation. Can share the Carista codes too if any interest
@village Did this work?
I feel I have this exact problem and don't know if I should try replace the sensor or the relay. My fault codes read out about 20 things about data bus error , wheel speed snsor rear left implausible signal, left front abs wheel speed sensor magenetic field too low ABS control implausible signal, plus loads others only get this issue on long drives and usually when I've used cruise control as some point.
Edited by Preecey
wanted to tag user
Yes it was nsr abs sensor, in fact just 2 weeks ago lit up again and this time osr sensor. £120 fix non skoda dealer.
What did your errors show ? or how did you know which side was the problem? My diagnostic has loads of things on it, only calls out left fron abs wheel speed sensor magentic field too low and rear left implausible signal.
My dashboard looks the same as Villages screen shot I quoted. Well it does when I have the issue. Didn't have it for a 6 months then popped up once and disappeared again since.
Yes it worked for me. So well in fact that i forgot about it and didn't event bother replacing the faulty relay after swapping them round. I kept the car for another 2.5 years after that post (c. 70k miles) and it never came back. Definitely worth a crack given it's a potential free fix
@village I couldn't figure out how to DM you about a year ago when this happened last aha. I can't find any information on this relay or which ones to swap. Even google is a bit blank on relays on the MK3 or mentions fuses. Do you know which ones I need to swap please? Legend
I can’t for the life of me remember, but I think someone did DM me about it and I might have been a bit more help back then. Will have a look
It was you that i was DM'ing about this about 2 years ago! I've inserted the salient points for prosperity:
This was one fix i didn't actually get personally involved in, so i'm not entirely sure what was involved in switching the relays, but i seem to recall that i only got charged for running the diagnostic so the relay switching must have been pretty straight forward.
If i was going to guess, i'd say it's [relay] 645 (at 2min 30), but that is only a guess. To the best of my recollection, it wasn't a back up relay, it was just used for less important stuff.
If you swap the 645's round, what's the worst that could happen! I'm joking (sort of), whilst i may be tempted to have a go at swapping like numbered relays around, i genuinely dont know enough about this stuff to advise anyone else
https://youtu.be/LJDtidR9JHc?si=q7Nqqvnb-mf0YI8H
hahaha I've just read our chat, I swear it wouldn't let me DM you hahaha. Cheers, I'll actually have a look this time.
When I was on holiday recently in Northern France and Belgium, I had the same issue of having multiple warnings, which would then clear themselves.
The first problem was just I reached the Le Shuttle terminal in Folkestone, when I had a low tyre pressure warning. However, none of the tyres showed any signs of being deflated, so, after a couple of days, I reset the warning and it never occurred again.
However, a few days later, after about an hour of driving, I suddenly had a string of warnings such as the cruise control not available, low tyre pressure system not available, some of the assist functions not available, etc. When I restarted the car after I had parked it to visit somewhere or an overnight stay, the warnings went away, but a little while later, the warnings returned.
This kept on happening, with the time before they occurred getting shorter and shorter.
Since I returned home, this problem has gone and the car is back to normal.
Yesterday, I had my car checked over by my local garage and no faults were found.
So this is a complete mystery to me - the only difference between when was on holiday and now is there's no luggage in the boot.
The other thing to mention was that despite all of these warnings, I was able to drive the car with no issues with the engine, etc.
I've had the car since new in 2016 with about 57,000 miles on the clock, and it has been brilliant in terms of reliability.
I would appreciate it if someone might have an idea of what was causing it.
Hi Peter, sounds like the exact same issue.
Only two fixes I've read is swapping the main relays around and changing the wheel speed sensors on whichever wheel is triggering the fault. I've never got to the bottom of it but it hasn't come back for about a year.
Many thanks for getting back to me.
Currently the car is fine so I've nothing to go on to investigate why I had these issues and why I don't have the now.
Hi all,
It must be the extreme heat, but my 2018 Vrs estate has just done the "light up like a Christmas tree" thing, then stopped doing it, then started again.
I have, in sequence: Error: tyre pressure loss indicator; manoeuvre braking currently unavailable; Error: start-stop system; Error: ABS/stabilisation control (AST); Error: tyre pressure loss indicator (again!); Error: headlight range control.
And the cruise control is a graphical error on the dash as well.
Is this a sensor thing the same as the ones above do you reckon?
I have come to the conclusion that the CAN BUS controllers that operate the various computers that have the cruise control, etc. may have been affected by the heat. But I have no way of verifying this as there are no fault codes.
May I ask if anyone knows where the computers and controllers are located in the car?
All of those systems require vehicle speed information, so I strongly suspect you have a problem with one (or more) ABS wheel sensors. Time for a scan with OBDeleven or VCDS or similar to determine which one.
2 hours ago, greeny12 said:
Hi all,
Sounds exactly like mine above. Use something like carista or obd11 and check the wheel speeds when the car is moving. If they’re all reading the same then it’s not going to be an abs sensor, and I suspect much more likely to be a relay fuse (which I suspect it is given it’s heat related). If one of the sensors isn’t giving a speed reading then it’ll likely be that sensor (although could be a cracked hub as happened to me, but less likely)
It was indeed the ABS sensor on the driver's side from wheel. Now fixed for a reasonable price at my local auto shop. Thanks for all the help everyone!
Recently Browsing 1
