help finding a new bike
looking for some advice as I'm after a hardtail  sub £1000
specs I know I want
1 x 10-12 gears
27.5 or 29er (leaning to 29)
hydraulic discs 180/160
air forks ( ive been told with my weight 15-17st, air would suit me best)
what I'm a little unsure about
dropper post - I assume this can be added later?
full suspension? - I've been told not really needed for what I do (Sherwood pines, through some wood lands, small jumps / drops  and some bike path stuff with the Mrs)  and I would be better of getting a better spec'd hard tail.
tubeless wheels ?
bikes I've looked at / considered buying
voodoo - bazingo/bokor ( minustor/canzo -full sus)
cannondale trail 2/3  / Cujo 2/3
trek roscoe 7
  • Replies 145
  • Views 25.9k
  • eeeeeeeeee   Vitus Sentier 27 VR 2020 spec with nukeproof pedals grip and handle bar, and dropper post.    sweet..
  • Retirement Portrait for Emmelle   last trip up the hill under me this morning
  • slight upgrade 🤪   no, its not the distance.. the andlebars are a solid 6inches wider than the old one... itll take a couple of goes to adjust i think... as for the braking, just aroun
I’ve got a giant fathom 2 which falls into this category. You should consider the vitus Sentier VRX
Dropped post is good, I’d say a must for what I do, also tubeless is great as you can run less pressure and get better grip
Vrx is out of my budget, can't find one for less than 1500 but I agree it's a great bike I've very much considered the vr but that's top budget so no room for extras like guards dropper post etc.
With halfords doing 15% off makes the bokor around 700 so I'm going to go have a play with one  this weekend
In fairness it looks a good bike and should be more than capable, enjoy your play lol
Have you looked at brands like planet-x?  Some amazing deals to be had and not cheap rubbish like most think they are.  Also the likes of canyon and YT are good too.  this is all dependant on how you are funding it and if you don't mind getting one without seeing it in the flesh first.  Wouldn't trust Halfords to build a bike safely so you don't really gain anything by going there IMO.
No I haven't, but I will thanks for the suggestions, I'll check them out.
Ive decided to do a lot of reading before buying  now
I've been looking at the sentier vrs from chain reaction  and Lappiere grizzly
Ended up buying a LaPierre edge 827+.
Just need to go get some pedals and take it out now.
Looks good. Be interested in how the plus size tyres go.
so far so good, it's very smooth when riding quick irons out a lot of the bumps with the large volume although I want to change the front tyre as I've lost it a couple of times in muddy conditions.
next changes for it - go tubeless first to see if a lower pressure will help with traction at the front end  failing that ill move to a nobby nic or margic mary (MM was on my last bike and has been excellent)
Tubeless will make a big difference in grip, definitely try that first
 dropped the front pressure down to 20psi (tubed) rear seems to be nice at 30psi  was definitely better at Sherwood pines at the weekend - back again this weekend so try a slightly faster run this time. it's better but still not as confidence inspiring as MM were might end up swapping the front to a 2.6MM.
Ill be 100% going tubeless for the next run - any suggestions im running WTB I40 rims
ive heard sod rim tape and go for gorilla as this holds better (being tubeless ready- does this just mean the tyres or the rims are ready to go as well?)  I was looking at the Stans no tubes kit
Tubeless ready just means the shape of the rim is good for it. Still need tape and yes gorilla tape is good. I have Stan's tape in one and worked ok. Didn't in the other so went back to tube for a bit.
A tubeless inflator is a good idea too. Don't use cO2 jobbies. Unless the tyres are good to go with a track pump.
mine have both come already set up tubeless. 20psi is very low for a tubed tyre and you risk getting a pinch flat. My EX8 runs bontrager XR4's which are immense, never had problems even when others are complaining about a lack of grip.
Agree it's low however with the volume of air in the 2.8 plus size it seems to handle it quite well,  wouldn't go that low on my old 2.2 tubed
Polygon or trek ex8 ? Either way lovely bit of kit
Edited by Gissin
Nice one.
Does the tape need to just go over spoke holes or the entire width of the rim? Finding conflicting info.
I've got a decent sized track pump but no inflators.. well one for my car tyres ?
Edited by Gissin
Rim tape: Over the holes is minimum to seal the air in.  More (over holes or width) depends on how good the tyre fit and the shape of the rim.  Sometimes you have to pack the centre of the rim to create a seal on the bead.  This is more common than needing to go more tape to the edge but both are sometimes needed.  I find 2 layers is usually good for extra sealicity.
Pump: Tubeless inflators are a tank of air that you charge and then they dump a load of air in to force the bead onto the rim.  C02 jobbies are not good as they tend to freeze the sealant and are single use.  Car tyre inflators are far too slow and most track pumps are also too slow/low volume.
Fair enough
So would something like https://www.halfords.com/cycling/bike-parts/inner-tubes/stans-standard-notubes-tubeless-kit be a good idea ?
Or is it best to just get some gorilla tape tubeless valves and sealant separately?
What's the difference with valve length (assuming that's what it is) as some places list kits with 36mm-75mm
The issue with moulded rim tape is the compatibility with rims.  Get the right one and it works very well with no sticky tape required.  Anything outside that and tape/valve separates is better.  Plus it makes it easier to get the fit right with tape on its own.
Valve length is just for shallow or deep section rims.  If in doubt, go long.
46mm valves ordered - they're the size that's on it now
big bottle of stans
as for tape I've read many  different opinions  gorilla tape is the go to but some say it absorbs the sealant over time and the clear repair tape is a better option ?
also what width - again opinions vary from covering just enough to get the spokes or wide across to slightly up the side walls
ie for me being internal size of 40mm I have suggestions from 25mm - 45m tape
I've never had an issue with gorilla tape.   Plus its cheap so if after 2 years it needs redoing......
I'd say don't go wider than the rim.  You can always overlap 2 layers offset to get the width should you need it, but always put 1 down the middle to cover the holes in one strip.  It all depends on your rims.  As a starter if your rims are 40mm internal I'd go for 30mm tape and chuck another 2 layers on to get the width if needed.
Update- brought some tesa 4289 tape as its essentially stans but at £8 per 66m instead of 15 at 10m
36mm  is what I went with but I've also got some 45mm gorilla tape incase it went wrong.
Anyway tesa went on fine with one wrap and seems to be holding just fine had an issue with not holding air and going down after 6 hours or so, after the 3rd pump up  this has now held for a few days, first ride out tomorrow pm
  • 7 months later...
thought I'd update on this, still running tubeless and happy with it (I still have a tube strapped to the frame just in case!
changed the 2.8 WTB rangers - just couldn't get on with them, they felt slow and always had issues with grip so I swapped to Schwalbe, I've got a rocket ron 2.6 on the back and a hans dampf 2.6 on the front (25psi rear / 20 front) blue stripe, snakeskins and i have to say I'm very happy with them, the bikes faster and gives more confidence in the corners or over roots, rock gardens etc.
whilst all the trails are closed im going to build a manual trainer as im rubbish at them!
as soon as the trails open again ill be heading to ladybower and Cannock chase as I've heard good things
is it worth swapping to carbon bars ?
there's some on sale near me so was considering it - but not entirely sure its worth it
  • 6 months later...
Thought id provide an update to changes I've made which I think have made a difference
Changed my grips to DMR death grips as my old ones were pretty shot, I have to say im impressed, the comfort and grip from them are great, I've not ridden for longer than 2 hours so I can't say how they fair on longer rides.
put some Zip ties around brake lines and shifters to stop them moving about, this has tidied up the bike and reduced noise on the trail
stuck on a Topeak ninja cage  this comes with a comprehensive, solid multi tool and takes a 750ml bottle this combined with a tube strapped to the bike and CO2 cartridge hidden under the seat allows for shorter rides to be pack free.
Humvee 2 liner shorts these are simply awesome and super comfy sat in the pub after and drove home in them too!
few new bits on order for the bike
Nukeproof 780mm Carbon bars (35mm) + Carbon assembly paste
Topeak D2 digital pressure gauge
Spank 45mm stem
will update on the new parts once fitted and been out for a couple rides
Edited by Gissin
