I need Bolero Update :-)
Hi pab567, Do you have new software for this unit. It has been miss behaving and I hope a software update will fix things.
  • Replies 1.2k
  • Views 223.8k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Hi folks,
could you please advice what it the latest version of firmware for my unit? I found 0253, can I use it?
Are there any changelogs for these firmwares? Do  I need to do  a registration of update after?
Sorry, I am noob in these questions. Please advice
Device part number 5C0035200A
Hardware: H22
Software: 0247
Hi, I’ve got the same problem. It’s there an update for device p/n 5Q0035842C
 hardware: H41
 software: 0468
@pab567 Hi, is there any fw updates for this system? Cheers
Installed SW train version:
MHI2 ER VWG11 P3301
Installed SW MU version:
0814
Part number:
3G0035020D
Software version:
H28.28.135 HIGH2 EU
Hi @pab567
I have a Scala Ambition 1.0 TSI with Bolero. Do you know if there is an update for this model?
I have read that there may be new versions 464 or 473. I have problems with the music folders from pendrive.
Thank you very much, and sorry for my bad english.
1635978807059.thumb.jpg.0dae46d7085e53cfa6178cd63f16be29.jpg1635978807013.thumb.jpg.6f96e8d9e651f4969386ced8a49b98c9.jpg1635978806995.thumb.jpg.347f7744e746392dc8037e6ebf5a7d68.jpg
On 18/10/2021 at 13:00, alanriemer said:
Hi! I need an update to my skoda fabia! I would like to connect my android phone
Hardware: 052
Software: 7200
Number: 6V0035871D
@pab567 thank you!!!
Unfortunately I have no firmware for your unit 😞
7 hours ago, martosoria said:
Hi @pab567
All others check your PMs
MHI2 ER VWG11 P3301
0814
Part number:
3G0035020D
Software version:
H28.28.135 HIGH2 EU
@pab567   Thank you
Hi pab567
I have a Bolero in my Skoda Octaviafrom 2016. My smartlink function is broken and it crashes very often. Could u provide me an update? Thank u for ur work!!!!
@pab567 do you have an update for my car? Thank you
Hi @pab567 I have a similar request to the one above, if you have an update I would really appreciate it - thanks very much
Phil McC
Hi, I also need an update for my car. Thank you very much!
hi i'm looking for an update for my infotainment.
installed sw train version:
MST2_EU_VW_E0220D
0624
Part number:
3Q0035874A
Can you assist me?
Hello!
@pab567: Do you have a firmware-update for me?
Many thanks in advance!
BR Peter
MST2_EU_VW_E0220D
0624
Part number:
3Q0035874A
Can you assist me?
Your version seems to be engineering one, not consumer, as it has letter E before release number (E0220D, consumer version is P0220D). Such version are usually not upgradeable to consumer version and I really doubt if you find any newer E version.
All others pls check your PMs.
Hello @pab567
I've recently bought a 2015 Fabia and was hoping you could tell me if there's an update to my Bolaro system.
Thanks in advance
Unfortunately not 😞 If you would like to get a replacement unit that supports not only MirrorLink but also Android Auto, Apple CarPlay and Voice Control pls contact me on PM.
Hi all, I recently bought Skoda Fabia Mk3 2016 and I have Bolero in it.
Part number is 5Q0035840B
HW: H30
SW: 0353
Medien-Codec: 3101.0.0.9
I red that the most recent version for ma HW is 0367, but I have no idea where to find the firmware file.. I would like the SK (Slovak) version. If anybody has the link, I would by very glad if you send me a link .. Thanks
 Hi pab567 many thanks for the software. It wouldent load from a usb stick but worked  perfectly from a SD card. I hope that one of the bug fixes in the updated software will improve the operation of USB. Picture showing the update.
Cheers.
@pab567: Could you please send the latest firmware for my Fabia 3 Combi Bolero?:
Device Part Number: 5Q0035842A
Hardware: H24
Software: 0245
Media-Codec: 2101.0.0.10
Thanks a lot!
@pab567 might you have any updates for Bolero, Fabia 2015. MST2_EU_SK_ZR_P0137T 5Q0035820.
Would love to get Smartlink enabled or is the unit incapable?
Unfortunately this unit, as well as 5Q0035819, supports MirrorLink only. To have SmartLink enabled you must have the unit exchanged - if you are interested pls contact me on PM.
All others pls check your PM.
Is there any update for this head unit?
Hi pab567,
Would you happen to have, or know the location for an update to my Superb ICE, screenshot below?
Many thanks if you do.
If you don't, many thanks for the  sterling work you do for others.
best regards.
borrible
