I need Bolero Update :-)
On 04/10/2019 at 22:05, Draxdamax said:
Hi,
I also have the bolero version:
Hardware H24
Software 0245
And I will like to update it to the latest firmware. But does it worth it? Any changelog for the new software or noticeable changes?
Also does the update work with any sd card or it requires a skoda branded sd card ?
Thank you
I got the link.
Thank you Pawel.
  • Replies 1.2k
  • Views 238.9k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Hi,
I need the latest firmware for:
Device part number: 5Q0035840C
Hardware: H41
Software: 0468
Similarly to Draxdamax I also wonder if there is a change log for the new software or noticeable changes?
Thank you.
How do you get a update?
I have bolero mib 1
 Hardware - 040
Software - 0435
Custom turbo back exhaust✅
Stage 2 Remap with crackle overrun map✅
MST Intake system ✅
Eibach Lowering Springs ✅
Expensive Week ✅
My update isn’t recognised. When I put it in it says it is an update file but when I go to the update button it spins a bit then says no valid update found. I don’t get tabs on the top of the screen like another user does. I tried dropping onto the SD card I use for music and onto a usb stick but got the same from both. The SD card plays music fine and the usb card I then used to update radio logos so they both look to be ok.
Pawel do I have the right file. I’ve tried a couple of times now to unzip and try again?
Is there a update available for:
Hi. Is for this bolero an Update available?
Greetings from germany
Hello@pab567, could you kindly check if my system can be updated?
Device part number: 5Q0035819A
Hardware: H24
Software: 0245
Media Codec:
2101.0.0.10
PM
Can I get a update to please
Can you update these cars if you can get online, say out side the house?
I have connected to my home router and it does some online stuff.
Or are all updates done via SD card / USB drive?
Put file on memory stick, bring memory to car, plug into car.
Hello Pab. Have you an Update for my bolero ?
are there dangers in updating my system on my own?
spoken to my dealer and he offered to update my system for 120$, seemed like a lot of money for an update.
@pab567 would love to get a PM from you 😉
5e0035842a
Software 0421
Hi Pab 567
Android Auto, on my 2016 Fabia 3, worked fine until a month ago.  Now refuses to connect to Bolero screen.
Tried numerous USB cables without success.  Android auto, is up to date and works fine just using the phone screen.
Phone contacts & SD card music/album art, populate the Bolero screen correctly.
Time to update the Bolero firmware perhaps?  Can you help please?
Current Bolero system is:-
Device part number: 5Q0035842A
Hardware: H25
Software: 0245
Hardware: H24
Software: 0245
Media Codec:
2101.0.0.10
how can i add mirror link
Hi,
I have a MIB2 Bolero:
5Q0035840B
Hardware:H30
Software:0359
Is there any update for it available?
@pab567
I would be very glad if you could help me out with an update as well 😀
Here is a screenshot.
Your unit is MIB1, I have no SW updates for it 😞
Yours is MIB1 200, sorry 😞
PM
On 01/11/2019 at 22:45, mitre said:
Hi Pab 567
Hardware: H25
Software: 0245
PM
Hardware: H24
Software: 0245
Media Codec:
2101.0.0.10
You got SW link via PM. Unfortunately adding MirrorLink is not possible in this unit - you must have it replaced.
On 05/11/2019 at 09:11, Mika76 said:
Hi,
5Q0035840B
Hardware:H30
Software:0359
PM
8 hours ago, Chokobanana said:
@pab567
PM
Hi Pab,
is there an update for my unit available?
