Octavia mk 4 no gearstick
Buried in the text (see link) is the DSG lever replaced by rocker switch
Various engines, some lower power ones available with manual
Lots of details including dimensions
https://www.skoda-storyboard.com/en/press-releases/the-new-skoda-octavia-the-brands-icon-makes-great-strides-in-terms-of-technology-and-design/
some internal renderings showing no gear knob
https://www.skoda-storyboard.com/en/models/octavia/the-all-new-skoda-octavia-take-a-look-inside/
Sounds like some sensible ideas like a USB-C port by rear view mirror (will be handy for dashcams)
  • Replies 106
  • Views 13.8k
  • I'd much rather have a normal handbrake. In fact I simply wouldn't buy a car without one. It's simple, it works, you have complete control.  Less to go wrong.   I've driven many ma
  • And me... I much prefer to use a proper starting handle to turn the engine over, those futuristic keys will make holes in my pockets.... 😏
  • I use neutral and handbrake at lights etc, so I don't blind the people behind. I don't like sitting behind someone with brake lights on so I don't do that to others. Enough reason for me not to want a
Suspect the Octavia’s will be similar to the forthcoming VW golf 8
Well that's one way to avoid the dreaded "Only leave vehicle while lever is in park" message. :biggrin:
No up or down gear - I wonder how you put it in manual mode (how I drive my DSG most of the time) I guess that would suggest that all will have wheel mounted paddles.
hmm..  might not be true.
I've seen other renders and sneak peak photos showing still a manual hand break  .. so..
Anyway keeping my fingers crossed... but targeting/dreaming for A4 Allroad :)
Having lived with BMW's joystick and Jag's rotary selector on our other cars for the last 7 years it's time VAG ditched the PRND gear lever, there are better options.
Paddles are a must though.
Lee
A manual handbrake in the Mk4? Why?
Cos some of us are young enough ( at heart) to enjoy a sneaky hand brake turn on a deserted gravel ( or snowy) car park.........?
Edited by Phil245
I'm more in favour of a manual handbrake as well. The good ol' fail safe.
And as mentioned above, it does aid in the asbo grand prix around the asda car park
Vorsprung Durch Technik.
Manual parking brakes in Scala & Kamiq.
One might assume that VW Group knows something about just how many issues there are with e-brakes.
Lets hope that VW Group have learned loads from Ford and the Durashifts they had.
It cost me over £2,200 to have the actuator replaced on a 2001 Ford Transit with push button gear changes.
(It had been a Ford Demonstrator that should have been scrapped but a dealership had sold early. It was years later before i discovered that.)
I'f you want proper fun don't buy a FWD family hatch. :)  There's proper ways to slide the back end and that needs power to the rear wheels.
The Octavia by missing out on Electric Hand Brake also missed out on Auto Hold.
I
Ford are ditching dual clutch boxes as are some other manufacturers.
VAG will continue with the dire DQ200 until we don't need gearboxes anymore.
Scala and Kamiq are smaller and cheaper platforms though.
Nearly all the Octy's rivals have EPB. Golf, Leon, Focus, Astra.
The have the DQ 400 -e for the Hybrids.
That will be 'Proper job'.
Boxes were lively in 2015/16 Golf GTE 1.4TSI , Audi A3 hybrid.
EDIT,  Typo on 'lively' but they  were, meant lovely.
Edited by Roottootemoot
My VRS has a manual handbrake and "auto hold".  If you hold it whilst stationery on the footbrake you get up to about 2 or 3 seconds when you take your foot off the brake before the brakes release, allowing you to pull away without rolling back.....
@Phil245
That is not 'Autohold'  that is Hill Hold Assist or Hill Hold Control,  Different thing from Holding the car as long as you want without Parking Brake or e-brake.
Ahh....right.     Whatever the terminology,  it does everything I need.  I consider the VRS to have the best of both worlds,  the Hill assist hold doo dah, and a "proper" handbrake.  There you go, a satisfied customer......😉
But if you had autohold you wouldn't need the handbrake. :)
Once you've had Autohold a manual handbrake is a pain.
(Autohold is a system that holds hydraulic pressure onto all four wheels and releases instantly. It doesn't actually use the EPB but VAG only fit it to models with EPB)
I say more of the good old manual handbrake, at least if your footbrake fails completely your can still stop the vehicle in a safe manor, all or most EPB's are disabled as soon as the vehicle is moving, leaving you with out any way of stopping.
A VAG DSG with the complexity of 3 clutches and electric motor.
What could possibly go wrong?
Leave it a few years to get the numerous recalls out of the way or dive straight in?
For VAG and most other manufacturers in an emergency situation you can pull and hold up the EPB switch and the parking brake motors will engage. If the switch is released the brakes will disengage.
So it'll be a car for eunuchs... In that it'll have no knob.
Edited by TheWanderer
If the hydraulic brake/service/foot brake fails then no hill hold or auto hold, but you hold a car on a manual handbrake.
If the hydraulic system fails then yes you loose  footbrake and autohold.
You still have EPB which uses direct electric motors.
