Amundsen MIB2 Firmware Update
Let me guess... you put update files on pendrive?
  • Replies 4.6k
  • Views 810.9k
I put on a miscro sd card 128gb fat 32 formated with sd adapter in to the slot 2
and the card was locked also
Try another card, possibly max. 32GB, formatted under FAT32 with cluster size = 4096 bytes
6 hours ago, pab567 said:
All check your PMs
I solved the problem with android auto en internet services yesterday, by pulling out for 15 min the fuses of infotainment and the cluster, for me fuse 12 en 17. I mentioned it if some who read the post are struggling with it also.
Thank you very much Pab567 for the latest firmware. I will install it tommorow!
All check your PMs
Hi @pab567
Would you be able to provide a software update for the following?
Device part number: 565035874
Hardware: H41
Software: 0478
Navigation database:
VO3959809G
1810
ECE1 2022/23
SHIELD: SHIELD 2016-44 (build 309)
Cheers
@KevSex you have download link on PM
So. :) I did the following. I used an old map SD card form Skoda formatted as you told me and also I erased the  "system volume information" hidden folder that windows create not to make any confusion with the device. This time it worked out. It only updated the one that failed the first time. Many many thanks @pab567for the unselfish help and sharing the updates with us. One more short info. Any idea is its possible to activate the SmartLink . With VCDS maybe.
1655755294065-800.thumb.jpg.012ff2630b9c5ac663d34b5462bf0365.jpg1655755294052-800.thumb.jpg.dc877700a06c0795d5077131edc81598.jpg1655755294020-800.thumb.jpg.9a4dbcf72f3bee2d3991ffe9c698b6fe.jpg
Possible but not with VCDS - unit must be patched (hacked).
Hi @pab567
Device part number: 5Q0035874B
Hardware: H30
Software: 0359
5L0051236BP
1410
ECE2 2020/21
SHIELD: SHIELD 2016-03 (build 020)
Cheers
PM
Hi guys you all seem very knowledgeable do you know if there is an update for my car at all?
Im on MST2 EU VW PQ P0363T
Hi @pab567 ,
According to an earlier post from you, you mention I should get the 0253 version:
Since I have component 5Q0035819A (Bolero). As far as I understand it is not possible to get either MirrorLink or SmartLink with this model. Is there any point in updating it then?
If you want to get SmartLink, rear view camera support or voice control then unit must be replaced, e.g. to 5Q0035840x (x - any letter A, B or C). If you are interested pls contact me on PM.
Hi @pab567. Me again. I have some issue with the updated firmware version. I run a full scan today at work with Gutmann tester and I get an issue that the software version is false. I scanned at home again with VCDS and its the same.
Control Module Part Number: 5Q0 035 864 A HW: 5Q0 035 864 A
Component and/or Version: MU-S-N-ER H24 0253
Software Coding: 03730201FF00000011110001000000002F0200C401200100C4
Work Shop Code: WSC 73430 790 00063
ASAM Dataset: EV_MUStd4CTSAT 001022 (SK37)
VCID: 3169A0C36029530EB4-8064
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 92718 km
Date: 2022.06.23
Time: 08:46:17
Voltage terminal 30: 12.0 V
Status_Software_Version_Management-module_name: D
Any idea? Is it possible that the version is false for my devices. Or if its correct but still I get the error can I revert the update so I return to the previous version.
Thank you in advanced
I recommend you search Briskoda for information of SVM (Software Version management) error - what it means and how to clear it.
Hi @pab567
would you be able to provide a software update for the following?
Device part number: 5Q0035874c
Hardware: H41
Software:
5L0051236AD
0915
ECE1 2018
thx and cheers
Addendum: I am sure that the software version is 0478. However, it seems that this has not been displayed for some time.
Hi @pab567
sorry for the confusion. After updating the navigation maps, the software version is now also displayed. Could you provide me with a download link to the software update for this? Thank you very much in advance.
Device part number: 5Q0035874C
Hardware: H41
Software: 0475
V03959809G
1810
ECE DL1 22/23
thx and cheers
PM
Hello, guys is three any chance to receive 490 ver to my Bolero. I have a 421 ver on SO III 2014. In the Skoda office they siad that 421 may be buggy and i need CD with 490 ver. Maybe Simone can help? Thanks on advance !
Hi all!
I’m on 480 version with my Octavia (5Q0035864C).. is there any new available?
1 hour ago, ChrisZN said:
Sorry for my previous post.
Firstly I have bolero so it's not my topic. My mistake. Secondly ver 490 relates to Bolero said guy in authorized service.
PS. I can't edit or delete previous post on mobile version and Opera.
Once again I apologize 🙂
Hello users!
I'm looking for the newest version of 5K7035200L
The current version is mst2_eu_vw_pq_p0449T.
Can you help me guys with sharing link do version with android car? :)
13 hours ago, edo112 said:
Hello users!
0480 is current. pab567 will for sure share a link for that version.
Android Car and Apple CarPlay is integrated in every version of the firmware (if your Nav has Navigation). Eighter you ask your VW Dealer for a SwapCode (you have to pay for that) or you try to hack the unit. If you are thinking about hacking the unit there are several other topics in this forum with manuals to do that.
