Amundsen MIB2 Firmware Update
Hello, would you be able to get an update for:
Partnumber: 5Q0035874C
Hardware: H41
Software: 0468
Nav DB:
5L0051236AD
0910
ECE1 2018
SHIELD: SHIELD 2016-44 (build 309)
Thanks!
  • Replies 4.7k
  • Views 899.5k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
After weeks of searching i finally found this forum and i hope, that i can get here THE firmware update, that my car dealer wont give me, to eleminate several bugs. :)
I would be very happy if you @pab567 (maybe the godfather of skoda firmware ;)) could provide me the latest firmware for my Skoda Octavia III (2019). More Details in the screenshot.
Big thx in advance! :)
Ypu need to wait a bit as my NAS has been compromised and I need some time to have it fully recovered.
Hi, I'd be very grateful if you could provide me a link to a firmware upgrade ..
Fingers crossed, that you can recover / restore all your datat.
Additional questions: Is also a changelog for different firmware versions available? :)
If you need some files I maybe can help out.
Thank u @pab567.
I have another adept for update.
Thank you, so mutch.
Hello
Will you be able to get an update
Skoda Octavia VRS 2019
Thank you
Not necessarily looking to update immediately but can anyone confirm what infotainment system I have, if there is an update and if there is any point updating it either from here or paying for one from VAG updates?
If you hold the menu button for some seconds, you enter the service menu and there you can see your software train version and your firmware version.
Don't pay  for firmwares from VAG updates, instead google for "MIB solution" and you'll find a site  with documentation and many (all?) firmware versions available.
@pab567: I hope you're healthy and the NAS-rebuilding comes to an end. :) Can you already say when you will be up and ready again? :)
Hi,
Please can you provide the latest software update available for my device?
Partnumber: 5Q0035864QA
Hardware: H24
Software: 0241
TNX
Hi @pab, I'm looking for FW update for my Octy 2016.
Please share if possible :)
Hey. Would you be able to provide the latest software for the following system? Thanks.
Today I figured out that I tagged wrong forum user. :)
@pab567  sorry :)
Does anyone have sw for:
Part number:5Q003580C
Hardware: H41
Software: 0475
Version: MST2_EU_SK_ZR_P0475T
Hey guys,
I've finally found the solution for my problem, (which was a sort of boot loop)
everything works as expected.
Now ofcourse, new problems are at hand.
I've worked with the mib toolbox to patch the unit,
Used OBD-eleven to insert FEC-codes, all accepted. Including the one for Android Auto and Carplay, but in the menu, they don't show up. If I connect a phone, I doesn't see the unit
any ideas here????
regards
Dear forum,
I once got a file to update my Amundson, but unfortunately my system won't update.
When I put in the SD-card the system first says "update files found".
But as soon I go to system-settings and do "Update Software" it says "no update files found or ...",
Can it be that my download maybe is not ok "MST2_EU_SK_ZR_P0367T.7z". It has 3,36GB, should it be larger?
1 minute ago, Harry0989 said:
Dear forum,
Thats because you are using the wrong software update funktion. Do a long press onto the menu button and use the than showing service menu to update your unit.
I mis-clicked, so my post was already submitted.
My system is:
5Q0035864B
Hardware: H30
Software: 0361
Thanks.
Thank you very much. I will give that a try.
Hello,
Can someone help me to update my Karoq Entertainment system because Carplay doesn't work anymore ?
5Q0035864C
H41
0471
Thanks a lot
Thanks for the file. I've updated my Amundsen from 0475 to 0480 succesfully. :)
Hello, I have a 2013 skoda octavia mk3, it had a bolero radio without Apple car play android auto and mirror link, it did have voice control, bluetooth, hands-free, etc., and I bought a scrapping unit 5q0035840b and screen 5e0919605n, it had a lock of components I could see everything that the unit had, appel car play mirror link android auto, skoda dealer removed component protection and everything works but the android auto mirror link and appel car play does not work, skoda says that I have to buy the code for that to work, is there a way to activate it? I wait for answers, I do not have access to odis, I can have access to vagcom and obd11 thanks
Correct, CarPlay and Android Auto are SWaP (SoftWare as a Product) which means a code is needed to unlock it, I *think* the code is VIN specific (many are).
48 minutes ago, PetrolDave said:
Correcto, CarPlay y Android Auto son SWaP (software como producto), lo que significa que se necesita un código para desbloquearlo, *creo* que el código es específico del VIN (muchos lo son).
Is there no other option and not pay for something that was already activated before removing component protection?
