Amundsen MIB2 Firmware Update
3 minutes ago, MohamedElGazayerly said:
Hi،
Greetings.
I have mst2_eu_sk_zr_p0359T on hardware H30, Software0359, with Part# 5q00358408 and Software version H28.28.133_std2plus_eu. As per the screen , it shows that there is update mst2_eu_sk_zr_p0359T (0359-2).
i can't find it and i would like to ask a couple of questions:
1- can i have this update file
2- is there a way to activate the mirror link thing which enables me to connect with my mobile
Best regards,
Mohamed Gazayerly
I will come back soon to assist you,
Current update is 0369, so ignore that value, it shows the updates that have been applied (seems like someone applied 0359 twice)
There is a hacking tool for this, but best send a picture of your whole screen with buttons (and you need to be prepared to hack)
To hack you MUST be able to put the infotainment system into Developer mode, you need a tool like VCDS or similar.
  • Replies 4.7k
  • Views 899.8k
You have private message now with link
Thanks.
Hello @Varoom,
First : Happy New Year and best wishes for you and your family.
Since your last message, I did not take time to proceed the update of my car. I start it this week-end, but the update menu didn't recognize the usb stick. I format it in fat32 and exfat, but even if it is detected in the image explorer, it is not in the update menu.
Any idea how to proceed in this case ?
Thanks a lot.
14 minutes ago, Willow971 said:
Hello @Varoom,
Thanks a lot.
Only a few have had success with USB stick
99% have had success with SD Card
I must use a sd card on USB port ?
I don't have native sd card port on my car.
Thx
Thx
Is it not in the glovebox?
Nope no sd card port in it.
Looked back at your post, you have the MIB3 with USB.
Can you show a picture of the contents of your USB stick?
You can use PM if you don't want images here.
Any update available?
Yes to 0253 via Private Message
Here is my USB content, actually formated in exfat
Ok good ! USB choice is available now. I will test the upgrade tomorow.
Thanks a lot.
Hi, if you have the update for MST2_EU_SK_ZR_P0245T  can i please have it
0245
5Q0035864A
Thank you, also how can i update the maps?
0245
5Q0035864A
Yes I can send you update to 0253 via Private Message in next few minutes.
Maps...
Good afternoon, can I get the link for MST2_EU_SK_ZR_P0480T please?
IMG_7410.HEIC
I will send you a link in a few minutes.
Good Afternoon.
Please can I have a link to the latest F/W for the following unit:
Many thanks 🙂
Paul.
1 minute ago, varooom said:
You are already using the latest
Is it not possible to (force/hack) update to the P04xx version as I'd like to get the grid view?
Tried enabling through MIB2Toolbox to no avail and think it was something released with the P03xx firmware and later?
I assume this is a MIB2 Standard unit and not a MIB2HIGH?
Cheers and sorry for all the questions.
I wouldn't attempt it myself, unless you have tools/abilities to open and bench flash it.
The software train will tell you which MIB you have, afaik standard MST2
@varooomupdate successfull with usb from 270 to 306 !
Thanks a lot !
