Amundsen MIB2 Firmware Update
Is there an update (software v. 0480) ?
  • Replies 4.6k
  • Views 766.7k
Nothing beyond 0480 yet.
Thank you.
2 hours ago, varooom said:
@boardtc Here attached is the output of a directory command, very basic, but if you can run this on your "E: Drive" and output to a text file to compare that would be perfect
DIR /S
To output to a text file, use an existing path, as such
X: (for the drive letter first of course)
Then this, to output to a text file in that path written
DIR /S > C:\Temp\Firmware.txt
0369 full directory and file list
Thanks, I can try the later hopefully. fyi, the reason yours look different to the one I posted was I used DIR /S /B
Yeah I see you used the Bare command, if you use same as me, then we have a good comparison.
Fingers crossed
Hello, first of all, sorry for my English.
The second thing, my system is at 0367, could someone give me the last one? I mean 0369.
Thanks in advance.
Thanks in advance.
Yes, to 0369 we shall take you
Hello,
I have the following unit in my car:
Device part number: 5Q0035840C
Hardware: H41
Software: 0475
I assume this is an Amundsen.
Is there a newer version available for it?
Is it worth upgrading?
thanks
1 minute ago, gelcha said:
Hello,
Hardware: H41
Software: 0475
thanks
Amundsen as far as I know
0480 is available
Choice is yours
0480 is available
Choice is yours
Thanks varoom.
Then let's give a try.
How can i have it?
Just now, gelcha said:
Thanks varoom.
How can i have it?
Private message in a few minutes
Hi, same here, Amundsen
Hardware: H41
Software: 0475
Thx in advance 🙂
Hardware: H41
Software: 0475
Thx in advance 🙂
I will send you 0480 update
Hi
Just bought a Skoda Octavia 2015 and am trying to see if there's an update for the infotainment centre.
Details below
Thanks in advance
Just now, gogiii said:
Hi
Details below
Thanks in advance
Yes that can be updated to 0253 version
mistake car is 2016 year
will smart link work then
Year does not matter, the Software Train installed tells me what update there is.
Smartlink will work IF it was already enabled... if not you have to either
  1. Pay dealer or independant to install code to activate
  2. Use a "tool" to enable this for free, but you need to have VCDS or OBD11 to enabled "Developer Mode"
thank you very much for your kindness, I will look on the forum if there is an explanation of how to do it
You will need to have VCDS or OBD11 to enable this hidden menu (GEM - Green Engineering Menu)
Buenos días Varooom.
    Soy nuevo por aquí. Intentaré escribir en ingles, no tengo ni idea😔.
    Tengo un Octavia MK3 Scout, con este sistema:
  Pude actualizar el Mapa, pero solo a la Versión ECE 1 2023/24. Mi tarjeta SD es : 5L0 051 236E que es de 2015 de 16GB y no tiene la capacidad para la actualización:
   Existe una actualización mas moderna para mi sistema?
   Donde puedo comprar un tarjeta SD 32 GB compatible con el sistema?
    Muchas gracias de Antemano.
There is a firmware update to 0253 version, but this will not be a magic bullet to fix maps.
I have the same in my car, and loading 0253 made it more responsive.
The maps have now got too big to fit on the 16GB card, you can either load a smaller map like I have, or you need to find an online auction site and pray you do not get sent a fake card.
I am happy with the smaller maps myself, as I would not take a long road trip, if you are planning a long trip, then you need to either get a different map region loaded for the journey, or use a phone navigation mounted in your car.
With some adjustments, your system is able to do Android Auto and Apply car play, sadly you either need to pay for activation or there is a free way, but needs tools.
De momento, voy a instalar la versión 0253.
  Donde la puedo conseguir?
  Android auto lo dejaré para más adelante.
  En unos días haré un viaje de 4000 km. Y ha instalé una actualización de mapa.
  Muchas gracias
  Muchas gracias
I can send you the file, but please use Google Translate to convert your post into English.
Forum rules and it makes my job easier.
Thank you so much!!!😀
     I can install the file from any SD, right?        If you can send me the file I appreciate it.
Any SD Card
The file has been sent 1hr ago for you, check private messages top right of screen.
