Amundsen MIB2 Firmware Update
1 hour ago, donkane said:
Hi@varooom
do you know if there has been a new update since 0480 ?
thanks you 🙂
None as of yet
  • Replies 4.7k
  • Views 900.9k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
Hello there,
I'm currently looking for a way to update my infotainment, which has boring crashing issues with wired Android Auto.
Here are my system's details:
- Octavia MKIII 2018
- Head Unit: 5Q0035864C
- Hardware H41
- Software version 0468
I could see that for the Amundsen there's a 0480 version. How can I get it, and, of course the procedure to follow to update it ?
Thanks a lot 😄
27 minutes ago, mmussler said:
Hello there,
- Hardware H41
Thanks a lot 😄
Did you try https://mibsolution.one/#/1/9
Pls check your fw version and then navigate to different fw versions under MQB Solution folder to get right firmware for your unit. Username/ pwd : guest/guest
Ok
I figured out the right version, and in the meantime how to update it through the service menu.
I'm currently downloading all this and will give a try
Thanks for the link
Good afternoon,
Can you please help with updates for below.
Thank you!
So finally getting my backside in gear to activate Smartlink on my 16 plate Octavia. The quote I have is £158 for the part I need which needs to be ordered in and £39 to have it fitted. Does that sound about right?
Hello,  is there some update for my unit?
I forgot my Software Train
Hey guys! I'm new to the forum!
I don't know if anyone can help!? I recently bought my car Octavia Combi 5E5 2016.
I want to change the voice of my Navigation to Hungarian, it now speaks English. Is this possible by updating a software component? Can someone help me??? Thanks in advance,
I have attached the MIB2 Amundsen data.
Hello, @varooom,
do you have MST2_EU_SK_ZR_P0363T? I can only find MST2_EU_SK_ZR_P0369T on mibsolution.one
I've just done an update on my unit which has previously had component protection removed. The update seems to have re-enabled component protection, has anyone had that issue before?
Hi Could I have the updated version for this please and instructions,many thanks.
Hello,
I have Superb 2017, and I can't find MST2_EU_SK_ZR_P0369T anywhere.
mibsolution.one does not have it. Can anyone forward me link to it?
@OlieeMo
There is a file for MST2_EU_SK_ZR_P0369T if you go through folders:
MQB_solution -> MST2 - TechniSat Preh -> Firmware -> SKODA_ZR -> EU -> MST2_EU_SK_ZR_P0369T
@waldostv
Thank you. I tried using search but could not find it. ❤️
Re the above. I will try to downgrade back to the old version if possible. Does anyone have a copy of MHI2_ER_SKG11_K3330 please, mibsolution.one only seems to have the latest versions
Edited by Dave77
The upgrade will have likely removed whatever component protection patch was installed. Downgrading is unlikely to help...
You need to reapply a component protection patch along with any FEC unlocks etc required :)
Might be worth speaking to whoever you got the headunit from, I'm not sure if it can be done remotely by @pab567 or not.
This is normal... Downgarding will NOT help, unit must be patched again.
Everyone requesting SW pls check your PMs. if you don;t find a link plks contact me on PM.
Hello Pab,
My trip odometer and  fuel consumption figures (since refuel and long term) keep resetting on almost a daily basis. One or two members on this site, seem to think an update may cure the problem?
Edited by snowglowjoe
Multiple images
Unfortunately you already have the latest SW 😞
On 27/06/2023 at 10:24, varooom said:
WinRAR as a 30-day trial, though 7-Zip should have been ok.
The path of some of the files looked off.
I will try to do a command line of the files/by folder so you can do the command to compare.
I was unable to try again for the last 2 weeks as I was away until this morning. But I can finally report that I am now upgraded to 369 and the #10 fuse and glovebox are back installed! Thanks for all your patience, especially Varoom. I got to the bottom of the reason the error happened and perhaps it may help someone else in the future. I unzipped (with 7-zip) from the download file to the freshly formatted sd card. But one needs to first unzip the downloaded zipped file to a directory in your download folder. Then copy the directory contents to the SD card. Unzipping directly to the sd card does not work.
Hi @pab567
Could you provide me with the update for the following Amundsen device?
5Q0035874C
Hardware: H41
Software 0475
Thank you very very much! :)
sent via PM
Must any other modules be updated as well when the mib2 receives a firmware update? E.g. Can gateway (19) or telematics (75)?
