Amundsen MIB2 Firmware Update
new firmaware is needed when something does not work right.
why do you want update ?
  • Replies 4.7k
  • Views 902k
Yes, never change a working system but I hope there are updates since 2016 that improve a few things.
I can only see one issue: if the windows are open when I stop the engine, I have to start the engine to be able to close the windows again.
There might be also other improvements that only a trained eye could see, that improve things without me, a noob to notice.
turns out you need a gateway connected on bench to instigate recovery mode on technisat units.  managed to get old one to work 😁
i have delphi unit that will not boot up shows up white screen, when connecting uart to putty shows up this error over and over
Synchronization lost on the primary LCD output try to enable MFLAG for all pipelines of the primary LCD in graphics.conf
seems to be file related
https://www.qnx.com/developers/docs/7.1/#com.qnx.doc.screen/topic/manual/cscreen_config_intro.html#screen_winmgr_display
how can i recover firmware onto delphi unit, does not seem to be as easy as technisat ?
Hey, can someone help me with what update I need for this.
Karoq 20 plate if that helps
PM
Hello,
i want to update from MOI3_EU_SKMQB_P1560P to MOI3_EU_SKMQB_P3240P.
I know i have to install in this order: 0156 -> 0178 -> 0308 ->0324
I have the MOI3_EU_SKMQB_P3080P and the MOI3_EU_SKMQB_P3240P update package, but i cant find MOI3_EU_SKMQB_P1780 anywhere. Can someone help?
thx
13 hours ago, pab567 said:
PM
Can the active smartlink be turned off after the update? So what is in use disappears?
If it wa activated by factory or Skoda dealer - no
Hey, could I get the newest firmware for my unit?
image.thumb.jpeg.b6487b8a7fa5e6e687a8b0c47ba3af88.jpegimage.thumb.jpeg.b3d51a52e69adfa495a1a0d772971bae.jpeg
23 hours ago, nipee said:
Hey, ünitem için en yeni aygıt yazılımını alabilir miyim?
https://mibsolution.one/ P0480
Salut, va rog un update pentru
good day
i
is there a way to get apple carplay on this device ?
or a newer  firmware/maps ?
many thanks in advance
greetings
erwinIMG_6802.HEIC
hello guys, is there a way to update my system ?
thanks a lot for your time :-)
Hi everyone!
@pab567
I am a new Skoda owner with a 2018 Octavia combi Style car. I would like to ask if it is possible to update my system? Also, is there an option for Wireless Apple Carplay? Thanks!
On 27/01/2024 at 13:03, error1111 said:
good day
i
greetings
erwinIMG_6802.HEIC
Nope, this is MIB1 Columbus, you must replace to MIB2 unit, either Amundsen or Ciolumbus. Pls contact me on PM if you are interested.
Pls check your PMs. For the future pls make sure you tag me like that @pab567 so I can react as I don't have resources to read all the threads in briskoda.
@pab567 hello pab,  hope you are doing well , can you please pm me if there is an update to my infotainment system
PM
@pab567
Hello there, I'd be grateful for advice on upgrading my current infotainment please?
Thanks.
R
Edited by ralphyimages
What is the latest firmware for this device?
DEVICE:             5Q0035874C
HARDWARE:     H41
SOFTWARE:      0472
NAVIGATION:   5L0051236AH
1030
ECE1 2018/2019
SHIELD: 2016-44 (BUILD 309)
MEDIA CODEC:    4101.0.0.0
BLUETOOTH :      C300
SMARTLINK:         4101.438.1.5
RADIO DB:            1.9.4
USB SURFSTICK:   4101.438.1.4
@pab567 hello pab567, can you help me update my device? It's there also a change log somewhere. Especially the Android Auto connection is not so stable for me...
All check your PMs
@pab567 Hi. Can this be updated and car play activated?
thank you !
Updated - yes, you have download link on PM.
Activated - Skoda dealer only, (at least I don't know anyone who can patch it).
@pab567 Many thanks in advance, is there an update for my unit with the below details?
