Amundsen MIB2 Firmware Update
I'll send it to you tomorrow, I'm not at my computer anymore
  • Replies 4.6k
  • Views 810k
10 hours ago, Joco776 said:
@scex Hi, send me an email and I will send you the update for your unit and the update instructions.
Hi
My e-mail is: [email protected]
And i find my curent version in attachments.
Hello,
I currently have:
Software Train:     MST2_EU_SK_ZR_P0478T
SW MU Version    0478
Part Number:       5650,874
SW Version:          H29.319.93_STD2Nav_EU
I'm looking for 480 Update
@scex Hi Sent, you will have it in your inbox in 30 minutes.
Update instructions.
You can use an empty ŠKODA SD card, your device does not accept other SD cards. And you need to unpack the update and copy everything to the root of the SD card and insert it into the SD1 slot.
1.)Hold the MENU button for 3 seconds.
2.) Click on update.
3.)Start the update - click continue.
4.)The unit will reboot and update will begin.
The unit may reboot several times during installation. When finished, the update completion message will appear on the screen and OK will be written in the place where the software changes were made.
If you have vcd or obdeleven go to 5F enter security code S12345 OK then in edit look for "confirmation" there you will see 4 numbers you will need to change using the calculator I will send you a link to. https://mib-helper.com/im-so-xory/
There you write the numbers and let new ones be generated and write to vcd or obdeleven with a space and confirm, then the unit tells you to start again (that means the unit reboots). After rebooting, remove all errors from 5f that appear due to the update log and you will never see these errors again because you have successfully verified the new code after installation.
(if you don't have vcds or obdeleven, it doesn't matter, you can clear the errors at any time, those errors have no bad effect on your unit or your vehicle) .
The engine can be started so that you have enough power in the battery, the engine must not be turned off and the update must not be interrupted, because your unit will get stuck and you will not be able to fix it yourself at home without equipment.
Do not worry.
Start the vehicle and you can update.
I wish you a pleasant entertainment.
Regards.
@lellek Hi, send me an email and I will send you the update
sent you a PM
Hey @Joco776 thanks for the update, it worked perfectly - so very much appreciated with your quick and great advice!
However I've lost my radio station icons - any ideas?
@Simonsifi Hi what station do you need region of the state
@Joco776 I'm in the UK
Although the download above is not a software database update, it's just a folder full of .png logos - so I don't think they will automatically be assigned to the correct radio stations. I guess there should be a database update? Or do they get pulled down over the air?
An update, I found by selecting each station, then pressing and holding the memory slot to re-store it brings back the logo for some reason. Anyway looks like it's fine now. Thanks again!
You did a good job.
Hello @pab567,
can you please tell me if there is a newer firmware for
Part number 3Q0 035 846 B
Train MST2_EU_VW_P0867D
Thanks in advance!!
Regards
MST2_EU_VW_P0883D (MU: 0883)
Hello 1st post,  is there an update for my 2015 octavia scout please?
Thanks in advance
Steve
@steve533 Hi.
There are two versions of the update for your unit. The first is just an easy update to 0253.
The second is to know how to prepare the data for the old unit and how to prepare the unit itself to receive the new 0480 update.
If you are interested, please email me.
MST2_EU_SK_ZR_P0253T (MU: 0253)
MST2_EU_SK_ZR_P0480T (MU: 0480)
On 13/03/2024 at 10:17, Simonsifi said:
Hi I have an Octavia 2018 which the Infotainment is on 4.68 software, I know there is a 4.80 version - where can I get it and what are the instructions for updating please? I get some issues with Android Auto connection being unreliable, changed cables and phones and the problem persists, so I want to see if a software update helps.
@Joco776 What's the differences out of interest between 4.68 and 4.80? Are there any release notes? Mine seems to be working fine since the upgrade - cheers
On 26/08/2022 at 23:25, VenomVrs said:
Hi!
Can someone help me with new update?
Hi!
Can i get a new update please?
I didnt complete the last one and forget it.
But yesterday my Mib started to restart on its own when i close the car and also rear camera doesnt work. Just in case im gonna try the update.
@VenomVrs  Hi, send me an email and I will send you the update for your unit.
Skoda don't release patch notes of the updates.
However if you load in the new FW then prior to update it will show you roughly what modules are being updated
Is there any way to activate the smartlink?
and also
Is there any firmware updates?
Thanks.
Hi!
2018 Octavia Sport
Serial : 5Q0035840C
Hardware : H41
Software :0468
Thanks a lot
Looking for an software update for this system, can anyone help me?
Thanks!
