Amundsen MIB2 Firmware Update
21 minutes ago, Mark2001 said:
Honnan lehet letolteni a fájt mert nem tudok a mib be belepni
Honnan tudom letolteni nekem is elkuldod letszives
The language of this forum is English, please post only in English.
  • Replies 4.7k
  • Views 907k
Hello. Looking for an software update for this system, can anyone help me?
Thanks!
Sorry if jumping on band wagon
I want to see if there is an update for my unit
Is there firmware available for my head unit?
Thanks very much!
Hello, @pab567
I have an 2016 Octavia and MST2_EU_SK_ZR_P0359T installed on my unit and when i check mib-helper it shows me that i can update to MST2_EU_SK_ZR_P0480T but when i tried to install the unit gives an error to say you cant install this. here are my head unit infos. What can i do ? , is there a wah to update to 4080t or should i update to MST2_EU_SK_ZR_P0369T ?
image.thumb.jpeg.09b2af644e83e05c55be03177b0aa4be.jpegimage.thumb.jpeg.1f42e5318dda9cc28101eb7eaf481f40.jpegimage.thumb.jpeg.b74c5543d3f0507c53993ac5106d0d5f.jpegimage.thumb.jpeg.2e83b0b9b275fdd6c611f3a365aa89ca.jpegimage.thumb.jpeg.e455d8fb98044b26022048156336c13a.jpegimage.thumb.jpeg.88880dc4a34b5f113e265c63d06b6a4c.jpeg
I had the same issue with 0480T.
Apprently, there is a way to force the update but it's risky. I just updated to 0369T and called it a day. I didn't find any changes from 0359T.
I did update the maps, POI, and radio station logos
On 27/11/2024 at 16:31, hakankarayel said:
can someone help me install toolbox on a unit with a single sd card?
code: 840A
software version: 253T
Not possible via SD in single SD units.
@techgenius it ALWAYS requires patching the unit (swdownload must be patched) which in your case (single SD unit) requires soldering (not possible via SD).
All others check your PMs
Hello,
I bought a 2nd hand Kodiaq and has the infotainment as shown in pictures? Is it possible to update and use wireless Car play?
I am also looking at how to set up wireless android auto on my 2016 Scout.
Showing as MST2 so i belive i can get wireless ndroid auto via smart link?
My smartlink asks me to "contact my dealer" for a code.
Anyway around this?
I doubt it, my 2016 Amundsen doesn't have WiFi so I've had to add a CarPlay2Air plugged into the USB to get wireless CarPlay.
hello, my multimedia died, it`s a 5E0 919 605 J   won`t turn on anymore, could somebody suggest me maybe an android compatible? Thanks
How, is there any tutorial for soldering ?
@Konstant_nos you have link on PM.
@Winder9561 pls post part number and SW version of your unit.
@ScleptzeR 5E0 919 605 J is just a dsiplay, what probably died is the glove box unit, pls post your VIN so I can help more.
@techgenius I have no idea, I use my own solutions, you have to google for it.
Answering wireless SmartLink (Android Auto, Apple CarPlay) - in MIB2 / MIB2.5 units it's possible but ONLY with the external third party adapter connected to USB.
@pab567 I understand.. TMBJG7NE1G0047111 is the vin. Thanks
@pab567
Device part number
5Q0035874A
Hardware
H24
Software
0245
Cheers pal
Your unit is Amundsen MIB2 without DAB part number 5Q0035864A. It supports Android Auto and Apple Carplay however in your case it didn't work as it was not activated (option 9WC - Without "Multimedia" in vehicle).
Do you have any possibility to connect VCDS or any other diagnostics tool (OBD Eleven, ODIS, VC Tool) to check if there is a communication with 5F unit and what are the errors?
@Winder9561 google for "MIB STD2 Toolbox".
@pab567I did activated the apple carplay but not with the key..I connected the  VCDS and started scanning and the program freezed..anyway the 5F code was
                Address 5F: Information Electr.       Labels: 3V0-035-MIB-STD2.clb
Control Module Part Number: 5Q0 035 864 A    HW: 5Q0 035 864 A
  Component and/or Version: MU-S-N-ER     H24 0253
           Software Coding: 03730201FF00000011110001000800002F0200C401200100C6
            Work Shop Code: WSC 73430 790 00063
              ASAM Dataset: EV_MUStd4CTSAT 001022 (SK37)
                       ROD: EV_MUStd4CTSAT_VW27.rod
                      VCID: 3169A3C660295CCCA7-8064
3 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] -  -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 236138 km
                    Date: 2024.12.05
                    Time: 17:52:51
                    Voltage terminal 30: 12.5 V
                    Status_Software_Version_Management-module_name:
6179 - Display Module 1 for Multimedia System
          B1297 F6 [009] - Cable for Video Signal; Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 22
                    Voltage terminal 30: 12.6 V
6691 - Local Data Bus
          U10BA 00 [008] - No Communication
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 62
after I closed and restarted the scan(full scan not only the 5F) surprize..the multimedia started working..I don`t know for how long it will work..but now it's working.. maybe u can help me telling me what to do ? i attach the full log. Thanks
Log-ANDREISKODAA-TMBJG7NE1G0047111-236188km-146760mi.txt
@ScleptzeR
Hi.
If you have vcd or obdeleven go to 5F enter security code S12345 OK then in edit look for "confirmation" there you will see 4 numbers you will need to change using the calculator I will send you a link to. https://mib-helper.com/im-so-xory/
There you write the numbers and have new ones generated and write to the vcd with a space and confirm, then the unit tells you to start over (that means the unit reboots). After rebooting, remove all errors from 5f that appear due to the update log and you will never see these errors again because you have successfully verified the new code after installation.
If you want, I can update your unit to version 0480.
@Joco776Hi ,
I followed the steps but is not changing the code..remains the old one..and it doesn`t ask me to reboot..doesn`t give errors but does not change the number. I did entered on security code, adaptation..the channel confirmation but doesn`t seems to work. Anyway I noticed that the collors of the display doesn`t look like normal..The update of the unit to 0480 could help? ThanksIMG-20241207-WA0016.thumb.jpg.f775699b4d4641b3754c7cd96dd679f4.jpgIMG-20241207-WA0018.thumb.jpg.81c8335e0ed260817afd6fd3c8736a3d.jpgIMG-20241207-WA0014.thumb.jpg.ed2a35de2a48901d18b8a1182e790611.jpgIMG-20241207-WA0015.thumb.jpg.89217b00f1c5c5d4672cbbb5d5a532cb.jpgIMG-20241207-WA0017.thumb.jpg.71102a03f81771e8941d764f2784965c.jpgIMG-20241207-WA0013.thumb.jpg.a28a114b1c2f7c44417938c702111576.jpg
Edited by ScleptzeR
@ScleptzeR
restart the radio and then fix the errors. 480 will change all the colors to new ones
@Joco776 the colors are changed because I think it`s dying. How to update to 0480 Thanks🤗
@ScleptzeR
I need to create new software for your unit and then upload it to the unit as instructed. If you want, send me a pm.
@Joco776
I can`t contact u
Joco776 cannot receive messages.
Edited by ScleptzeR
it died again...doesn`t turn on anymore
