Amundsen MIB2 Firmware Update
@pab567 Could you provide an update for the following please:
P/N: 5Q0035874C
HW: H41
SW: 0472
  • Replies 4.7k
  • Views 897.3k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
Download link on PM
Hi There could you help with the update file for this Skoda Octavia 3 headunit?
Thank you
Hi,
also need an update for my Bolero HeadUnit.
Thank you very much for your help.
Hi @pab567, please could you advise whether there is an update for my 2013 Octavia 3 VRS infotainment unit?
I've had the generic "Fault : Vehicle Lighting" error on the display for several months which a few people seem to have reported. Checked and reseated all bulbs. Nothing showing on my OBD but don't know anyone with VCDS. Have seen a few suggestions on here that updating the infotainment might be worth a try?
@Superlolli you are already on the latest firmware. ALl others pls check your PMs.
Edited by NuriDark0
mark
PM
Hi,  I need firmware update: MST2_EU_SK_ZR_P0253T
Thank you very much!
Good momrinng all
I hope someone can help. I bought a 2015 Octavia last week and the original maps are still installed. I'd really like to update to the latest. I have downloaded them from the Skoda portal and installed them on a new SD card. However, I get an error message "Please insert a data medium with valid navigation data". I also went to MIB helper and downloaded from there with the same result. Can someone tell me what I am doing wrong? Thank you
34327211-26A9-433B-91DF-EDD773A4B62C_1_105_c.thumb.jpeg.1e3ac3e811030e1b040dd08c1450d7a7.jpeg
51 minutes ago, Hobgoblinrunner said:
Good momrinng all
Have you used the proper SD card? - Amundsen MIB2 will only accept Skoda/VAG SD card.
Hi,
I am new here. Are you able to provide me with a link for that firmware: MST2_EU_SK_ZR_P0480T ?
Currently installed v. P0478T.
Part#: 5Q0035874C
Hardware: H41
Would like to update to v 480..
Thanks in advance!
Hello , please update the last equipment 5Q0035874C
 hardware H41
 software 0471
Děkuji
Hi,
First time post. Thanks in advance.
Can someone point me to an update for same equipment as above post please and thanks.
Regards, Stephen
Dear friends, this is my first post on this forum, and what I have seen reading the comments, this is a place to learn and find a lot of help. Before I start, I want to thank everyone here for helping and exchanging experiences.
Recently I bought Škoda Octavia (2017 year). First of all, I want to tell you that I don't have experience at all with updating firmware of car console (software).
I can see that mr. @pab567 is a true legend here :) and I would really appreciate if you could help me with this problem.
I am attaching you the pictures of my version of software that is installed right now in my car. I hope you will get along with the language, I think that the versions are what you need to see.
Can you help me with all the procedure regarding the update? I am very grateful to you in advance!
Best regards!
Hi All,
Looking for an update for my Infotainment.
I did request one around 1 year ago and was kindly provided a file by Pab567.
I downloaded it onto an old computer and totally forgot about it. I've went back into my messages and downloaded it to try and put it onto an SD Card(formatted to FAT32). But gives file errors when I'm trying to transfer the files.
I've even tried unzipping direct to the SD and still gives the same errors.
Any help would be greatly appreciated.
The file I'm trying to copy over is called MST2_EU_SE_ZR_P0368T
Not sure why the image is upside down. 🙃
Thank you @Warrior193 I hadn't realised there was a difference. I thought I could just use a freshly formatted card. All sorted now.
Hello. I am new here.
Could you please help me with a software update ?
@karp Feel free to write to me.
On 04/03/2025 at 17:26, Octy6614 said:
Hi All,
Hello the update you try to copy si for Seat "SE" you need 369 SK is for škoda. I can send you link.
Is there an update foor my car?
SW MST2_EU_SK_ZR_P0480T
I have the 0:00 clock error described by many skoda/seat/vw drivers now with my yeti, too.
My unit is:
Partnumber: 5L0035680D
SW Train: MST2_EU_SK_PQ_E0368T
As I read this 0:00 clock bug should be fixed in Version 478 (and later).
@pab567: Could you kindly provide me an bugfree(d) update for my device?
btw:
my software-version seems strange because I found in the web version 359 shall be latest.
is there something wrong?
Thank you in advance.
My unit is:
btw:
forgot to mention...
Hardware = X72, Software = X368
@pab567 could you provide me with an update for my navigation system? Thx in advance.
Media Codec 3141.0.0.1
