Amundsen MIB2 Firmware Update
Currently on 0468 using a H41.
Any update to this would be appreciated.
Edited by Jtho
  • Replies 4.7k
  • Views 905.6k
@pab567 morning sir! I see you've been helping this community for a long time - I am new here and I need the MST2_EU_SK_ZR_P0480T file if you don't mind sending it over? I can't seem to find it anywhere these days.
Appreciate your help!
PM sent
I am new here. Would you mind sending MST2_EU_SK_ZR_P0480T please?
Many thanks!
@pab567 forgot to put your nickname to my post....
Much appreciated
PM sent
18 minutes ago, pab567 said:
PM sent
Thanks!
@pab567 could you provide me with an update for my navigation system? Thx in advance.
Media Codec 3141.0.0.1
PM sent
Hi, I would like to update the radio. Can someone send me the latest functional version? For example, mst2_eu_sk_zr_p0480T? Thank you.
ciao a tutti
vorrei avere dei consigli se possibile anche se io ho vw e non skoda però ho letto che molti di voi sanno parecchio sul funzionamento dei sw
vorrei installare sulla mia golf 7.5 del 2017 con mib2 questa versione di sw mst2_eu_vw_zr_p0480t.
Ora ho la versione installata mst2_eu_vw_zr_p0363t
ho gia installato toolbox sulla vettura ed ho gia anche il sw 480t pronto per essere installato.
il mio infotaiment è: MIB2 3Q0035864B (con 2 schede sd)
posso fare questo aggiornamento ?
se si, come devo procedere ?
Grazie a a tutti comunque per quello che fate e spero possiate aiutare anche me.
Un saluto a tutti voi
Augusto :-)
Edited by augusto73roma
14 minutes ago, augusto73roma said:
ciao a tutti
Augusto :-)
The language of this forum is English, so you need to post in English.
Here's what Google Translate makes of your post:
Hi everyone,
I'd like some advice if possible, even though I have a VW and not a Skoda. However, I've read that many of you know a lot about how software works.
I'd like to install this version of the software, mst2_eu_vw_zr_p0480t, on my 2017 Golf 7.5 with MIB2.
I now have the mst2_eu_vw_zr_p0363t version installed.
I've already installed the toolbox on the car and I also have the 480t software ready to be installed.
My infotainment is: MIB2 3Q0035864B (with 2 SD cards).
Can I do this update?
If so, how should I proceed?
Thank you all for what you do, and I hope you can help me too.
Best regards, everyone.
Hi everyone,
sorry and thanks :) @PetrolDave
Hi everyone,
@pab567 Hi, I see you're very knowledgeable about this. Could you give me some advice? Thanks so much :-)
Hi, does anyone have a link for MST2_EU_VW_PQ_R0604T?
@augusto73roma you have to patch swdownload from toolbox and then start installation of 0480 firmware. It will break with some error messages - you have to modify metainfo2.txt (change "RequiredVersion..." lines from any version it has to "0").
@pab567 Thanks a lot for the info :-) Do I make the metainfo2 modification during the installation of the new sw 480? So directly from the radio? Right?
Nope, you modify it on SD card
14 hours ago, pab567 said:
No, lo modifichi sulla scheda SD
@pab567 Thanks so much, I'll try updating and let you know how it goes. Thanks so much, you've been a great help :-)
15 hours ago, pab567 said:
@augusto73romaDevi applicare la patch a swdownload dalla casella degli strumenti e poi avviare l'installazione del firmware 0480. Si bloccherà con alcuni messaggi di errore: devi modificare metainfo2.txt (sostituendo le righe "RequiredVersion..." da qualsiasi versione abbia in "0").
@pab567 I noticed that there are several RequiredVersion lines in the metainfo file. Should I change them all to "0"? But can't I do that before starting the update?
Yes, you can change all RequiredVersion lines to "0". It can be done befor you start the update.
10 minutes ago, pab567 said:
Sì, puoi modificare tutte le righe RequiredVersion impostandole su "0". Puoi farlo prima di avviare l'aggiornamento.
ok thanks @pab567
Update to 480t done.
Aside from just saying I have the 0480t software installed, nothing has changed.
Everything is exactly the same as it was with the 363t, and the update took about 2-3 minutes to complete, and I only noticed that it updated two items: Bluetooth and another one I don't remember. The skins haven't changed, as I thought they would with the new graphics. I'm starting to think my 0480t software was a bit dated and incomplete. I don't know what to think, but the update seems to have gone well anyway.
This means you have done something wrong. Use Manual SWDL and select all but emergency in Main and emergency in CPU.
