Amundsen MIB2 Firmware Update
Hello.
Anyone know where to get latest version?
MST2_EU_SK_ZR_P0480T
  • Replies 4.7k
  • Views 899.3k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
11 hours ago, Cairus said:
@IvanMaihaus
Die neueste Firmware ist 0480
Passwort senden Sie mir eine Nachricht
https://mega.nz/#P!AgGWtzUFoIOM4t9fc-ytrUjaQcCFEvmu8jKphKDSB14nvb6R3neEHfChr0i8fyXQe6SkrUDjtl3vpPDZXRGV44NecBDE2by_C0hK_zDuHWDuB9bbfSd4gJMWyqcRA7qmbxxCSZ4ldow
@Cairus Is it possible to get the password via message? Can't send PM as a newbie.... Many thanks.
Hi Guys, anyone know is there an update for my system, its 2013 Octavia
Hello,
I am writing to you regarding the software upgrade for my vehicle, Škoda Fabia 2015 (from Slovenia).
I have been looking for a solution for several days to enable the SmartLink function but unfortunately without any luck
I would like to ask for your help
Thank you for your time and help. I look forward to your response.
software version MEN2_EU_SKGPX_P7381L
Device part number 6V0 035 871H
hardware 690
software 8740
Hello guys, I just purchased my Octavia 2017 Combi 1.6TDI and I have some problems with the battery (12v low battery when I start the car).
I want to update the infotainment just to be sure it's not the one draining it.
Is there an update for my current version? mibsolution one does not allow to download it.
The car already has Android Auto and Mirrorlink with the usb port in the compartment below. in case i Update it, would I lose these benefits?
Thanks to whoever can give me a hand.
Edited by Portocala84
Hello, welcome to the forum.
If your infotainment system is presently working correctly, an update is unlikely to change anything to affect the battery charging.
Have you checked the alternator charge rate - or battery condition?
If the battery is original, it may be approaching its end of life.
Hi Warrior193, thank you for your answer.
I did that, I got a Varta AGM 70Ah 760ah and coded using a friend's VCDS. I was away for work and used the car like 1 time a week with no errors.
As I changed job i started using it more often and it started telling me the error above. With a multimeter I checked and the error was on even with the battery at 12.4v or 12.76v before turning it on.
It's not an alternator problem as it charges (12.9v-13.3v-13.4v).
The previous owner mounted canbus LEDs in the foot area, above the head and in the trunk. But those should not be a problem.
I wanted to update the infotainment only because one day I did not turn it on and I did not get the Low battery error. I thought maybe with a newer version something was fixed.
Some correlation/causation situation.
Are you in the habit of listening to music for any length of time with the engine not running?
Ideally, the alternator should be charging at a little more than 14 volts with the battery on load.
As the unit turns off fully with the ignition it is highly unlikely to be creating a parasitic draw Car has other problems
There have been reports of after market infotainment systems (especially from China) being responsible for parasitic drain - but hopefully, this is not the issue here.
Hi, I'm writing from Italy.
Thank you for this precious support channel!!
After an app update, I'm having a connection problem between the infotainment system and the "MySkoda" app (I had already renewed all the services 😭 ).
The dealership told me it's definitely an update issue, but they have to keep the car for a whole day, and it's a big problem for my job.
Can you help me, please?
Here are the system screenshots. Thanks!!!!!
Hello! I would like to update the software. Can someone send me the latest version for my device? Thank you!
Hi, I have MST2_EU_SK_ZR_P0245T. mib helper says the latest I can update is MST2_EU_SK_ZR_P0253T. Since I am unable to download does any one have a file for this update or if my system can be updated. @varooom @pab567 if you don't mind helping me out ? :)
Fw 0253T
https://mega.nz/#P!AgEDeRWdGttRAsXCXNEvOYEm17bDYWmmCzT6PSQ-j8N-pb8V3EhGv0DeiL_wgPndDwA67vYcMJnYzgwns09MczzMVhqv0hy801-YQ74oYN-C2_fJM3WJuwxAafcWEp8FrbTCBOUC9FI
4 minutes ago, Cairus said:
Fw 0253T
Hi Carius I appreciate you sending a link. There is susposed to be a password to access?
No-password link sent in PM
Dobrý deň, je k dispozícii nejaký upgrade na toto?
Hello, is there any upgrade available for this?
Please use a translation tool for posts on the site, as the default language is English and I know the mods don’t like to start giving out warnings for wrong language stuff.
Hi I have a Skoda Kodiaq 2017 with a installed SW train version : MHI2_ER_SKG13_P4177
Intalled SW MU version: 1125
Part number: 565035021A
Could somebody help to see if it needs updating and where I can download to put on SD card
Thanks in advance.
Hi guys, I'd like to publicly thank @pab567 ; I sent him my MIB2 and in less than 24 hours he sent it back to me updated with the latest firmware version (408) and with all the functions activated and working. I've already installed it in my 2016 Octavia Scout and everything works perfectly.
You mean FW480?
44 minutes ago, Cairus said:
You mean FW480?
yes, my typing error
I'm certain I need MHI2_ER_SKG13_P4526 (MU:1440). Any help would be much appreciated! Thanks in advance!
