Amundsen MIB2 Firmware Update
1 hour ago, Joco776 said:
I can do a software conversation for you. Write to me.
I still cannot DM in this site so how can i contact to you in other way mate?
  • Replies 4.7k
  • Views 881k
I wrote to you
I own a 2016 Skoda Octavia and I want to update the multimedia system and activate Smart Link. The specifications of the multimedia system are shown in the attached image. What do I need to do? Thank you for your help.
Bonjour,
J’ai une octavia de 2017.
Je voudrais savoir si je peux faire une mise à jour de mon GPS vers le 480 directement et comment activer sans risque Android auto ?
Je vous remercie pour votre aide précieuse.
Hello
I have been using android auto in my car since bought it brand new. This week in the middle of driving it stopped working and my phone showed me red screen. Did some research and i think i must now update my bolero. Where can i find the update file, i think it is this "MST2_EU_SK_ZR_P0253T"?
Here => https://mib-helper.com/
Edited by Gy4083
Hello @pab567 the initial firmware for my LG Swing MEn2 was MEN2_EU_SKGPx_P7130L. Later, I installed the MEN2_EU_SKGPx_P0080L-MU8755_working firmware, but my main goal was to activate SmartLink. Can you help me with this? I've followed the steps with Obdeleven, and I've connected a USB Ethernet adapter, but I still can't connect. Also, is there a link where I can download the MEN2_EU_SKGPx_P7130L firmware? Thank you very much in advance.
On 18/08/2025 at 06:32, pab567 said:
@Paulygee22 I sent you download link in PM. If this doesn't help then I beleive it's a HW issue.
Hello again pab567, unfortunately my unit audio has completely failed. I have investigated as much as I can and believe as you said this is a hardware fault. (I think it maybe the on board/internal audio processing chip) I learned this can be repaired and I was quoted about 550GBP. My question today is: if I buy a used replacement unit, can it be programmed to work in my car?
My details again:
Amundsen MY17 unit with DAB - 5Q0035874B
Hardware: H30
Software: 0353
Software train version was: MST2_EU_SK_ZR_P0353T
Updated to
MST2_EU_ZR_P0369T with your instructions
Navigation SW: H28.28.91_STD2Nav_EU
Database: 5L0051236P
0730
ECE1 2017
SHIELD: SHIELD 2016-03 (build 020)
Appreciate your help
Paul
550GBP for repairing your unit seems really high... I can deliver a replacement unit, in Plug&Play version, at 60% of this amount. But before we proceed further pls send me VIN of your car in PM so I can check your car configuration.
Wow, sounds amazing.
VIN is removed by admin
Thank you!
Do not post vin or reg numbers on the public areas of the forum as information may be scraped for fraud etc such as vehicle cloning.
Use the site Private message service to contact trusted members only.
Regards
Briskoda admin
Sorry about that
OK, got your VIN in PM. You don't have CANTON so if there is no audio then either all speakers are broken, all harnesses between infotainment unit 5Q0035874B and speakers failed or the infotainment unit itself is broken. I can try to repair it but you have to deliver it to me to Poland. In the worst case scenario, i.e. if it's BER (Beyond Economic Repair), then I can prepare new unit, in Plug&Play version (Component Protection error visible in diagnostics only but everything works correctly, no need to visit Skoda dealer). Pls switch to PM if you are interested.
Edited by pab567
evening all
I'm having some issues with my ICE system when it is connected to iphone on car play it randomly stops playing the music and starts making a loud buzzing sound instead - I wonder if an update oin the firmware may fix??
is anyone able to help or at least tell me where I can get or send me a copy of the most recent update?
DPN - 5Q0035874C
Hardware - H41
Software - 0456
Gizz
Edited by bengsgizz
Hello, I’m posting on this forum to see if anyone can help me. I have a 2015 Skoda Fabia; I’ve never updated the radio, and recently it’s been giving me a lot of trouble with Android Auto error 8. I was wondering if there might be an update available for my radio. Many thanks in advance.
DPN - 5Q0035840A
Hardware - H25
Software - 0245
Media Codec: 2101.0.0.10
DPN - 5Q0035840A
Hardware - H25
Software - 0245
Installed SW Train Version:
MST2_EU_SK_ZR_P0245T
Installed SW MU Version:
0245
Part Number:
5Q0035840A
Software Version:
H25.14.78_STD2Plus_EU
Hello there!
Can anybody support me with an newer Firmware Update?
Time at the Display stands at 0:00 and never change.
Thanks in advance
Thommy
There is no official solution for the clock problem in your firmware. The only solution, also listed in the Digital Elite forum, is a cross-flash to a VW firmware, which addresses the clock issue. Then the Skoda HMI needs to be flashed. Only attempt this yourself if you know what you're doing; otherwise, you risk bricking your software.
@ThomBrink můžu vám ten problém vyřešit.
@Joco776 How can you help?
does anyone have
MST2_EU_VW_PQ_P0363T
MST2_EU_VW_PQ_P0367T
MST2_EU_VW_PQ_P0368T
mibsolution for 368 is corrupt
No image preview
3.11 GB file on MEGA
Firmware 369T
9 hours ago, Cairus said:
No image preview
Firmware 369T
i have 369 need earlier one 0368 is corrupted on mib solution
Edited by lenovo
Why 368?
5 minutes ago, Cairus said:
Why 368?
it refuses to take 0369 in emergency
