DieselMonte's 2012 Monte Carlo Project. (175hp 6 speed swapped)
Got it all cleaned up, cleaned the intake manifold some too.
Cleaned the injector bodies up, and left the tips submerged in injector cleaner, i had some spare, figure it would do no harm.
Did see little bits in the bottom of the dish so it cleaned something out.
New seals, rocker cover gasket etc, all good, reused the original injectors, see how much longer they last.
Going great since, only problem now is my 6 month old battery is goosed, because it was sitting for a while.
Have a lift now so will make a lot of repairs much easier for me.
  • Replies 347
  • Views 55.8k
  • DieselMonte
    DieselMonte
  • DieselMonte
    DieselMonte
    Lot of progress done since: The axle has turned out very nice compared to what it was before, should keep looking fresh for a while yet.   I managed to find a set of 256mm rear br
  • Very happy with the mounts. So much nicer changing gears and a lot less drama putting my foot down. Slightly more vibrations but not crazy especially this being a diesel.    Wanted
Got some nearly new ar-1s for this thing
Some tyre softener stuff too so coated and wrapped them up.
Got the K brace back in it eventually, night and day difference.
Then the car started leaking quite badly, rocker cover.
Have done a fair amount of driving since and it was fine, until it wasnt, probably something caused or disturbed.
Bit the bullet and bought a new rocker cover, injector bolts and washers (again) and new leakoff pipes. Even with trade discount, it hurt.
Easy enough job since i'd done it before atleast.
Got it done in maybe 2hrs
All good and fine now.
Took it out and washed it all down and underneath. Get the oil off.
Ended up giving it a valet along with the mx5 so clean, waxed all that.
Have parts on order for it, chiefly its getting new brakes all around. So i'd already put so much aside to do that, the rocker definitely hurt to shell out for.
Brakes are done.
New Mtec Discs and Textar pads for the 312/256mm octavia setup on this.
Also got new slide pins, some bolts etc all new.
Don't mind the rust on the faces so much, i'd washed it and put it away
Rears while working fine looked a bit scruffy
Front pads were poorly. Forgotten they were mtecs own pad. Theyve been squealing this while. In all fairness to them, they did hold up pretty well in all.
Took my time cleaning up heat shields and such
Paint job on the calipers is good from far, but far from good
Arches really need a good clean up
Not actually driven it more than a few miles since, paint/coating on the discs hasnt even worn off it.
Initial impressions are very good and so far quiet as can be.
Braided lines gone on
Only did the fronts as the rears looked a pain to do. All bled up perfect.
Pedal feels great, brakes work fantastic AND they're quiet as can be.
Made up another engine mount. Replaced the hydroil with 60 shore polyurethane.
After a while of curing it went on. Easy job.
Feels fantastic so far and NVH is completely fine. Feels better than the wore standard mount that found its way on.
Not car related but found a kitten on its own in the shed.
On its own and its mam didnt come back so took it home, kept it warm fed etc.
Anyway a month on its doing great,
So all going pretty well for once.
Few things since its been a while.
Handbrake lever broke so robbed one out of the Mk1 vrs parts car, fits fine. Was easier got to than the mk2 parts car since its been stripped down.
Also a slightly less worn wheel to go on mine.
Full 180k service. Seen a pipercross filter for cheap so got it (new). Know full well it will make no performance difference.
Full Oil/Air/Fuel/Pollen wipers etc. New n75 again and pedal pads as mine were slightly wore.
Replaced two rough looking coolant pipes also.
Small amount of fuzz on sump bung but nothing worrysome yet.
New lhf arch liner as mine was damaged (genuine).
Refitted all the undertrays.
Got my "new" ar1s fitted.
VERY tight fit.
Did mondello end of last month with a mate. Extremely busy for something in the middle of the week.
Car did well, suffered bigly from rubbing
Tyre softener stuff worked brilliantly, as did the cetane booster from the same lad. Let it cool off proper between runs, standard cooling system is at its limit. I did refit the intercooler sprayer which helped.
Think the tyres clearanced themselves over the day.
Full credits to the photographer on the day
Very nice picks for a not so fast car.
Could be worse.
Weighed all the wheels i had out of interest.
Heaviest was the monte wheels with ar1s : 21kg
Next was the monte wheels with PS4s :20.3kg
Then the OZ superturismos :19.75kg
Lastly the mk1 spyders at just: 16.6kg
Basically 4kg a wheel lighter than my normal wheels. And i do think theyre the nicest wheels out of all of them. Most likely run them next time i need tires.
Roped into doing mondello again end of the month, hopefully i can do kirkistown again too as it was brilliant.
Mx5 if it passes mot next year will do the trackwork as ill be getting slicks for it very soon.
Potentially getting turbo sorted start of next year.
Funds allowing.
Have all there but ill most likely do more work around it.
I would like a 6 speed. Probably should put a new rad in also. Really if im swapping the turbo ill drop all out and do it out of the car. Not a small job in itself but itll be done.
Providing it passes nct end of the year, get it over with before i do any major work.
No reason it won't pass nct
But they will fail it on something thats fine and miss everything inbetween.
2 more trackdays down. Did mondello on the bank holiday monday gone by and kirkistown today.
Few repairs done before mondello.
Fixed one of the rivnuts for the brace, got a tool from lidl for nothing and it worked brilliantly.
Back stripped out, seats etc.
Checking over bolts and immediately snapped one for the rarb. Managed to repair it with an old bush from the justy cut down and bolt and nut through it.
Mondello went well, sort of damp, car did a lot bettet than last time.
Spun it but no damage suffered. Was silly but a lot of people did the exact same on the same corner so not too mad. Amount of red flags at mondello is astounding, thankfully i wasnt one (yellow flagged for spinning)
Didnt do too much except change the oil and check it over for kirkistown. Its about 100 miles each way from me and of course i was driving there and back.
Car did well, was some ridiculously fast stuff there today including a manthey porsche, big body amg saloon, ferrari 599 and an m3 convertible and it was VERY busy.
Weather held out amazingly. Brakes held much better than last year as did tyres. Heat management definitely a problem and I dont love not having oil temp atleast.
Ran the car on HVO both these trackdays, cars took to it great but i wouldnt leave it sitting with that in it.
Believe much like e10 and petrols it will rot lines if theyre not rated.
Use torque to monitor coolant temps, intake temps, pressure etc. Eased off once coolant got to 100°. No clue whats a "safe limit" but figured thats safe enough.
Rubbing pretty bad still. Thought it clearanced itself but guess not.
Last few photos arent mine theyre from another forum, but they look cool so ill post them here too.
Over 181k miles now so see how much more it will take.
Long one.
Gave the car another service after doing kirkistown and ahead of a long trip.
Changed rear springs for my Heavy duty ones.
Gave the car a quick polish and away to the uk.
A friend was doing the RAC and I tagged along.
Went belfast to cairnryan. Picked up a friend who lived nearish the ferry, loaded up and down in one shot to carmarthen for the start.
Very cool seeing the serious amount of machinery on display.
Showgrounds were huge.
Stayed at a place nearish.
Got snowed in.
Every one else made it out but I did not.
So tactical dump into a field entrance and walked back to the accomodation.
Eventually got it unstuck some hours later.
Snow was mostly around where we were, main roads were fine.
But getting to and from them consisted of being pushed for about 2km.
(Pic from the next morning)
Thursday morning was difficult because there was that much snow the car basically high sided in the middle lifting the wheels off the ground. Pilot sports did not help. Not the car for the job. Its not very low but it is lowered a bit.
Atleast in fresh snow it acted like a snow plow of sorts.
But was embarassing to have to be pushed for so long until we hit road.
Thursday night the stuff in the middle was turning to ice and needed to be pushed a bit again.
Friday morning wasnt *as bad. Needed a push to start getting out. But aside from the ice it did get onto the road mostly ok.
Said ice in the middle became very hard and did damage. Not terrible but not a pleasant run over the road.
Wont let me upload the video but it sounded pretty horrible driving over (on) it.
Leaving to follow the service van, copped the undertray was low.
Very low.
Was held on at that point by 2 screws only so ripped it off.
About an hour or so of driving got a call that mates car had an off on SS8.
(Not my pic but its where the car ended up)
They're fine. Car is done for.
So diverted to near it and met with the management cars and waited, chatted with some very nice locals too.
Watched some very cool stuff go by until they could get lifted down to end of stage and picked up.
Car wasnt going to be lifted until saturday morning so we left late friday for scotland. Drove straight back up and crashed on a couch until the ferry came.
(Not my pic but how it was lifted out)
4 new tyres for the MX5 AD08RS almost identical to what was on it years before i had it.
Worked out about 1250 miles before i got home. So a lot of driving in a few days.
Rac does 2 legs so starts in carmarthen and finishes in carlisle.
Mate went off on the last day of the welsh leg. Either way we would have been driving to carlisle atleast. Would have worked out handy ferry wise, but not the end of the world.
To be honest looking at how the northern leg went, probably did us a favour in a strange way.
Took it out a few days later to assess what id done.
Full deep scrub underneath especially. 2 trips on the irish sea and salted welsh roads had me worried.
Have a video but too long so bullet points.
Rubbed the underneath raw, broke undertray. Floorpan covers damaged slightly, backbox/fuel tank all rubbed slightly
Undertray missing. Some of the mountings damaged.
Exhaust mounts tweaked on downpipe.
Damaged the lip mostly areas id fixed earlier giving way.20251124_143503.jpg
Was gonna repaint it eventually so no big deal.
Floorpan covers i had spare from a parts car, my old ones will be fitted to the sdi eventually.
Sorted some rust underneath. Not too bad. Sprayed all white over it and used wax coating on top.
Sprayed the floorpan brace also.
In next week for NCT so in preparation mode for that.
Have to change backbox anyway so stripped all off to tackle some rust.
Wired all back best i could.
SOAKED in kurust overnight.
Started with Anti corrosion zinc primer.
Then etch.
Then stone chip.
Will be sprayed white and then waxoyled once this sets overnight.
Slightly better floorpan covers and brand new genuine undertray, again.
Rarb has to come off. As does kbrace.
Also have a flat sheet of metal I intend to do up a cover for the exhaust.
Hide the downpipe better.
Will fail on something.
Im just giving them as few excuses as possible.
Trip to the Uk was brilliant, 10/10 experience, honored to have been involved in some small way.
Fella is probably the best driver i know, just got caught out at the worst time.
Hope I can get invited back again.
Nearly 183000 miles on my car now. Going pretty well.
Suspect i damaged a boost pipe as its a bit more whistly now. Easy sorted if i can find the bugger.
All finished off gloss white with wax coating on top.
Car passed clean sheet this time.
Normal exhaust painted and back on.
New fitting kit for the rarb, painted it yet again.
Fixed a few other things, cb etc, refitted brace too.
Also got a few things off skoda parts, including an old irc sticker, always wanted one.
  • 4 months later...
Lot of work going on
Engine and all out
Front off
Shed load of parts to go on
6 speed has been taken from the vrsdi
Spare 5 speed box from another monte gone in, bolts straight in etc, provided you swap EVERYTHING, works just fine.
New shafts and all going in this.
Finally the Cr170 turbo ive been sitting on for years being put to use
Took some bits down to powerwash, intercooler came up insanely well, bit of polish and itll be golden.
Subframe being stripped and repainted, again.
Be touching up some bits of rust etc, very slight but its all apart so its being done.
Turbo off. Box off.
Currently at 188k miles.
Clutch has had its day anyhow, never slipped never gave me any trouble, original clutch all along. Springs rattling around in it so was due in anycase.
New rad and condensor. Rad was weeping slightly and not had working ac in years, used compressor going on also.
Lots of work done last few days
Pics out of order a bit but:
Engine bay cleaned down, new coolant bottle on, darkside braided clutch line on.
New caliper sanded, primed and painted
Came out very well for once.
Whiteline rear anti roll bar off, keeping it for the SDi.
H&R bar is non adjustable, but powder coating seems fantastic on it vs the whiteline, have to say the clamps for the bushes were a bit of a nightmare to install.
Bits of rust treated and painted up.
Standard dual mass 4pc kit gone one, new slave cylinder, bolted up lovely
Foreshadowing
Swapped out the shifter for the one out of the SDi originally, as it was in better shape than the one in my car, in spite of being 11 years older than the car, and having more miles. no matter what I did to it, I could never get it to feel as tight as I wanted it to.
Shifters are different but bolt up the same, otherwise fit and work the same, figure I can get a new bush for the SDi shifter and be golden.
Had solid shifter bracket bushes and was able to work my solid cable end bushes on the 6 speed.
It works, and it feels fantastic.
New bleeder for the clutch also, it's bled up perfect, and feels brilliant so far.
Brakes all bled fine etc
Starter connector is different, easy to swap them considering I had both cars to hand.
Currently stuck waiting for hardpipes, standard boost pipe no longer fits because the 6 speed is that much bigger, no way of working it and I did try.
Also found a pinhole in my downpipe
Least it's not split fully at the welds.
Seeing if I can just get a replacement top piece vs welding it, again.
Changed the gear oil on the box too.
And pulled the vrsdi asunder for its subframe. Painting the subframe from the monte became a mess, it will not stick, and paint stripper just turned it into a sticky gooey mess, horrible.
Plus is it'll be back on its caster increase bushes, and I get my wishbone ducts back.
Not far from being done
But still a bit left to do.
Couple other trick things, least I have time to sort some of them given it's gonna be down for a while longer.
Forget if I ever did a modlist, but I'll do one up after this.
Power will be whatever the injectors are capable of, but cross that bridge when it comes to it.
Just caught up with this. Excellent work as always. 👍
Nearly there. Hardpipe kit from darkside arrived, fiddly to get it to sit right around the box, but I think I'll have it sorted. Way it wanted to sit left me with the same problem of interfering with the shifter.
Got some bushes for the triangular up/down piece of the shifter, cleaned all down had to sand the pin that it pivots on the box as whatever grease was on it had hardened and bonded almost to the pin.
Hard to describe but cleaned up well, new bushes for it and the squarish slider piece on the end. Slight improvement again and much improved over the previous setup. I'll order a bush for the gear stick and do it later on, it's decent but could be better, sort of last piece of the puzzle.
The selector on the box with the weight will not come off so I'm "stuck" using it, not that I mind too much.
New top part of downpipe on too.
Spent some time touching up the undercoat I did end of last year. Wasn't bad but we had some ridiculous flooding start of the year and the plastic floor covers were filled with rocks and silt, was all off anyway and cleaned so. Touched up the wax coating, more schutz stuff around the exhaust tunnel (mostly for a bit of sound deadening and it was all out)
Shot any holes full of lanolin too to keep on top of everything.
Did some repairs to the lip, it'll get painted properly again at some point.
Patched up best I could. Apparently fiberglass ones are being made now so could see me just replacing it at some point.
Have repaired and repainted it before
But it does get hammered on quite a bit
Lovely road rash on it.
Is running and driving on the lift, changed the oil, new coolant etc. it is very close now.
Have videos I might link later.
No leaks or anything either thus far.
Not many more parts to go back on considering.
Very happy with the hardpipe kit, was struggling immensely but think I've got it figured out.PXL_20260606_161802274.jpg
Tried fitting bigger spotlamps however they were too big. Have to reuse the old ones for now but not hard to change them. Old ones been on there long enough they'd seized, fortunate I had the crashbar off to get access and heat/soak them enough to get them loose.
Will end up changing them at some point but at least for the summer there's no real need.
Want to try get some (very gentle) miles on it before it gets mapped if it will let me. Bed in the clutch and make sure it's holding all the fluids it should.
Trackings gonna be miles out now so that'll need sorting too.
Should say it's had new rear shocks (kyb monotube ones), swapped back to the shorter, softer St rear springs and some shorter bump stops. new rear wheel bearing, front hub and bearing, and went back to the power flex top mounts with new bearings there as the rubber ones had compressed to the point where the front was too low for my use.
Looked well, but I need ride height for the roads I'm on.
So it's finally done
Setback, after setback.
Got it tracked, driving lovely now with the new swaybars, caster increase bushes back in it and deadset kit.
Was driving it (VERY gently) to bed stuff in, making sure it wasn't gonna leak etc. bone dry.
Had to use a cone filter for now until I can sort the standard airbox.
Replacement hardpipe from darkside fits much better.
Took a day of work to get it mapped, hoped to trailer it up as the place that would do it is in ballymena. Which is about 90 ish miles from me.
Didn't happen, so drove it up, carefully. Still with the new box it was sitting happy at low revs 60-70 mph no problem. Got 64mpg on the way up.
Probably the hottest day of the year so far, 30°c had torque running but temps etc were perfect, drove great etc.
Left it for a few hours and came back to
175hp and 260ftlbs of torque.
Which is very solid for original injectors, and a 188k mile engine.
Got even better fuel economy from ballymena to lisburn, picked up the pace on from there.
For a hot, humid day it behaved extremely well, I know dynos are corrected for temp etc, but it was making that power consistently. Haven't noticed any smoke, was told the same when they were tuning it.
It is running very clean, making strong power and getting somehow even better economy, undertrays etc aren't even on.
6 speed box feels well matched to the car, standard mk1 vrs dmf/clutch. Braided clutch line. Clutch feels great and changing gears is much nicer now (mostly due to the less scuffed shifter box originally from the sdi.
For a car that's mostly kept looking standard, and a lot of the changes are ultimately standard VW parts from one car or another it really has come out decent.
I don't need a low car, or a reeky car etc.
Older pic from years back but still
All the little bits and pieces but unless you had one side by side you'd struggle to see much different, even in this pic there's nothing really obvious.
Got a lot of help and advice from a number of people and places,
Amd87ts was a great source of info
Max en caisse pointed me in the right direction with boost pipes and a few other odds and ends.
Darkside were very helpful getting the right bits I was missing, and with stuff previously on the vrsdi.
And autotune in ballymena have done a fantastic job on it.
Wouldn't have the stones for it if I didn't have a forum like this to research on either.
Few small jobs left.
Hopefully all the a/c needs is a regas now, it's pretty dire without in this weather
Need to fettle with the backbox it's hitting the axle over speed bumps, just slightly.
Want to get my phone charger working again, it's been dodgy of late.
Boost gauge (all it needs is 2 slightly longer hex bolts)
Redo the fog tints and new spots etc.
Small stuff, never ending.
  • DieselMonte changed the title to DieselMonte's 2012 Monte Carlo Project. (175hp 6 speed swapped)
A/C regassed and working for the first time in years
5 out of the 6 years I've had it, aircon was bust.
Figure I may post a Modlist of it as it is now.
Power:
175hp/260ft lbs
Engine:
188k mile CAYC 1.6 TDi
GTC1549VZ Turbo
Universal Front mount intercooler
Darkside hardpipe kit
Darkside 2.5" downpipe
Ulter 2.25" backbox
RamAir Foam filter *temporary*
Water sprayer for intercooler (inop atm)
Gearbox:
Mk1 Fabia vRS 6 speed (HDS)
Standard vRS DMF/Clutch kit
Braided Clutch line
Solid shifter bushes
PowerFlex purple Lower mount
Strengthened OEM engine mounts.
Mk1 fabia shifter box
Suspension/Chassis:
ST shocks and springs
Powerflex Top Mounts
Superpro Caster Increase bushes
Superpro Steering Rack bush
PSB rear axle bushes
H&R F+R Swaybars
Deadset kit
Baf K brace
Brakes/Tyres:
Mk1 fabia vRS Rear Axle (Disc conversion)
312mm Front brakes
256mm vented Rear brakes
Mtec Braided brake lines
Mtec Drilled/Grooved discs
Textar Pads
Standard Wheels 2x Sets
(Normal set)
215/40/17 Bridgestone potenza S001 AO
(Track set)
215/45/17 Nankang AR-1
Other:
Red Monte Carlo seats (grey originally)
Mk1 vRS handbrake (original broke)
Boost gauge
Halogen spotlamps in the grille
Passenger seat storage box
Sunglasses holder
Wireless car play "RCD330" (clone) head unit.
Wind deflectors
Mudflaps
  • 3 months later...
Not much to report.
A few thousand faultless* miles so far.
Had it in the UK in July, 35°c , air con cold as ice and getting unbelievably good fuel economy. Wasn't too long after getting it all back together so was a bit nervous but it drove flawlessly.
Few small things I managed to sort.
New bushes for the shifter in the cabin, one from the SDi originally. Tightened it up some more.
Also found a "6 speed" knob on Amazon so snagged it. Was only 15 or so quid.
It's basically the more modern VW gear knob with a boot to suit a mk2 fabia, it looks standard and considering it actually is a 6 speed now, fits perfect. My old 5 speed one was in bits this ages.
Got a new set of spotlamps too, my old halogen ones were in bits this while, treated myself to a set of led spotlamps. Fit well and came with their own wiring loom.
Now has a switch in the dash as well as coming on via high beam.
Some disassembly required. Also replaced the fan resistor with one from a parts car. It hadn't worked on "1" in a year or so.
Did a track day start of Sept at mondello. Car felt great, was able to stay out for much longer at a time and the new sway bars and other changes have made a pretty major improvement to how it felt on track. Without compromising too much on driving it every day.
Gearbox felt much better suited to task than the 5 speed.
Feels like Its finally where I've always wanted it to be.
Still many much faster cars on track.
One thing I only noticed recently with the colder weather coming in, it was struggling to get up to temp, staying mostly around 65-70°, heat wasn't great and would cause the coolant temp to plummet further.
Should have realized at mondello when it wasn't getting past 90°c.
So thermostat most likely, have one from darkside ready to go. Seems a bear to do in situ, and probably something I should have done when it was in pieces a few months back. Not doing big miles currently so not relying on it.
Had to replace a CV boot a few months back but sounds like a joints about to go.
Really wish the shaft I got when I was doing all was good, would save me a lot of hassle.
Twin sports cats look to have come a bit loose 😸
Gaz
