Air Quality Sensor Faulty
On 13/11/2023 at 21:30, Bap33 said:
I've just contacted ECS Tuning to ask them if they ship to France.
Well, I got the answer this morning. They do! But... $36... This means ~ €96 to get it... Weel it hurts, but probably the "cheapest" I could find in a version at least as recent as mine.
Thanks a lot @JR RS 👍 for the tip! Much appreciated!
  • Replies 79
  • Views 80.7k
  • OK glad that worked out I used the Hella part. Attached are the photos of replacement - the scuttle panel is split in half and lifts up pretty easily without taking the wipers off (on RHD anyway). The
  • That sensor controls the re-circulation in the climate control systems. if it detects external air quality is not sufficient, it will turn off re-circ.    it went in my car last year, and it
  • No visible indication to the driver.  You can go to the climate menu, settings and make sure auto recirculation is selected though.
@Bap33 - agreed.  it is not ideal, but compared to prices at other places, for a version F, it is a win.
  • 4 weeks later...
Hi,
Problem solved, no more fault code popping up upon VCDS scan.
I finally found a D version (as my original one) on a french website for €107 (delivered), compared to €97 on ECS Tuning. I found this easier.
8 hours ago, Bap33 said:
Hi,
Why would you fit the old D version that often fails opposed to the revised F version which doesn’t fail prematurely?
The original one lastet almost 6 years. I expect the new one to last the same time. Anyway, I’m quite sure I´ll have changed my car within the 6 next years…
  • 4 months later...
AQS, the return!
My new AQS has lasted... 6 months 😤... I had bet it would last at least 2 or 3 years.
Losing bet 🙄...
I'll check if there can be a 1 year warranty. Otherwise, next one will then be a F version. I hope it won't cost me an arm in this case
Edited by Bap33
I thought mine was back too because I did a scan last night and there was a warning on 08 Air Conditioning module!!
"B10CD00 - Function limitation due to energy management"
Different message to wat I was getting before I changed the AQS sensor.
Never seen that warning before.  Hopefully it's just a one off.
I've cleared it now.
Will keep an eye on it to see if it comes back.
Edited by JR RS
Here is the extract of the VCDS scan:
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 CP    HW: 3V0 907 044 CP
   Component: AC Automat    H34 4402
   Revision: 20K10000    Serial number: 00000B00659263 Dataset Number: 0000
   Coding: 1201010400041001100510410010112A
   Shop #: WSC 33361 790 00140
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 04296C198F083CB667-8050
   Humidity sensor: exterior:
   Rear air conditioning block 1:
H02
1 Fault Found:
263427 - Air Quality Sensor
          B10AF 29 [00001001] - Signal Implausible
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 103
                    Mileage: 116280 km
                    Date: 2024.05.08
                    Time: 19:12:46
                    Outside temperature: 17.0 ∞C
                    Voltage terminal 30: 11.9 V
                    System run time-Engine running time: 0 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: Clean air
Clearing it is useless, it comes back immediately. I googled the fault code on the ross-tech forum, and conclusion is regularly the same: Sensor faulty...
Good news!
The website had asked me to send my AQS back for quality control and expertise few weeks ago, which I did
I've received an email today saying, I'm going to be refunded. 😃
I'm now looking for another brand new AQS corresponding to 5Q0907643F OEM reference. 😎
1 hour ago, Bap33 said:
Good news!
I say nothing :D
glad they refunded it though!
on this subject, my D revision has recently started showing faults so looks like I’ll be replacing mine also
My original one was a D version, which lasted 6 years. I had imagined the new one could last the same duration.
Furthermore, F version was not available at similar costs. Shipping costs were up to 80% of the sensor price, especially if sold on non EU websites.... 😵
Currently, F version are available at more affordable prices...
Additionally, it reminds me 2 sayings:
- Experience is a light that only lights the path you've done.
- Others' experience is a light that lights in your back.
17 hours ago, ApertureS said:
I say nothing :D
Do all superb have an air quality sensor or just the ones with air care? If all have them is air care any different to a car that doesn’t have the logo?
seems to me it does the same thing but I’m sure there’s more to it
Hi,
I've found 3 possible suppliers for 5Q0907643F reference, but have no idea of which one is the most reliable: AIC, Vemo or Hella.
Prices can be significantly different fo course
Any advice or experience on these " suppliers?
TIA.
Edited by Bap33
This is the one I got 9 months ago - haven't had any AQS warnings since then.
Bought mine from ECS Tuning for $75 USD, delivered.
Edited by JR RS
Hi @JR RS,
Thanks for sharing. I've just done an estimate. Currently, ECS tuning would mean $68 delivered for me.
I was wondering about their disclaimer in red about shipping time/costs thru UPS:
"UPS: Service typically delivers in 2 - 5 business days for most international locations. Shipping quotes are based on orders that are not delayed in customs due to import processing delays.
This method of service does NOT include the cost of duties or taxes related to customs clearance. These fees are charged to the customer at the time of delivery."
Does your 75  USD include potential custom taxes?
TIA
@Bap33 - that was the total price.  i didn't have to pay any import duties or taxes.
i'm in australia though, so other countries may differ.
11 hours ago, Bap33 said:
Hi @JR RS,
TIA
ECS is based in america so it depends what agreement france has?
For example if i wanted to import from france to the UK i have to pay an additional 20% tax plus an admin fee on the value of the order when it reaches a UK entry point.
Thanks fo your feedbacks. I've ordered it this morning. To be continued...
Bad joke today: €32-ish of additional custom taxes 😮.
Fortunately, it’s still less expensive than the first one I ordered and for whom I was refunded.
Did anyone try cleaning theirs AQS ? I gave mine a wash down with IPA , not had any issues since.
Mine has been broken for the last 4 years and, for what it does, I can't be bothered to replace it. I will be trying your IPA solution though ( surely not India Pale Ale ) to see if it fixes it.
Just looked it up. Alcohol yes, ale no.😄
New Air Quality Sensor (5Q0907643F version) installed today.
I hope it will last longer than the previous one. 🤨
  • 4 months later...
I know this threads quite old now but I'm having an issue with my AQS. Fault code B10A415 - short circuit to postive. Replaced the sensor and cleared the fault but it comes back straight away. Any suggestions?
