Air Quality Sensor Faulty
On 29/07/2024 at 13:14, defsix said:
Did anyone try cleaning theirs AQS ? I gave mine a wash down with IPA , not had any issues since.
Can you give us a run through of how you cleaned this?
  • Replies 79
  • Views 81.1k
  • OK glad that worked out I used the Hella part. Attached are the photos of replacement - the scuttle panel is split in half and lifts up pretty easily without taking the wipers off (on RHD anyway). The
  • That sensor controls the re-circulation in the climate control systems. if it detects external air quality is not sufficient, it will turn off re-circ.    it went in my car last year, and it
  • No visible indication to the driver.  You can go to the climate menu, settings and make sure auto recirculation is selected though.
Sprayed the entire sensor in IPA. Not had the issue since.
Did you leave it insitu or remove for cleaning? Might try some contact cleaner myself.
I just found this on AliExpress:
€21.75 | Car Air Quality Sensor 5QJ907643 For VW PASSAT B8 Golf 8 MK8 Tiguan For Audi Q4 Q5 For Skoda Seat Kodiaq 5Q0907643D 5QJ 907 643
https://a.aliexpress.com/_Ey3JZ1G
Works like a charm, OEM part for chinese market
Hey guys, i have the same problem with my superb. I can only find 5q0907643F from Vemo and Aic. They should be compatible right? On autodoc it says that they are not compatible with superb 3v5.
So right now i dont have a clue which sensor to buy. I wanted to order 5q0907643F from VEMO but it says its not compatible.
