Keyless - Can it be disabled ?
I am not too sure how it works on the Superb, ie do you simply need to walk up to the car for it to open or do you need to press some kind of button, but if it is the former can it be changed so the key does not transmit 24/7. Thanks
Press "unlock" on your key and quickly touch "lock" on the door handle, it will disable keyless entry.
Yes you just walk up to the car and unless you've initiated eurotripwagen's tip above, it will just unlock.
But unlike other manufacturers, it doesn’t lock the car when you walk away from it, which, in my view is, a bit ridiculous.
I believe you must touch the door handle: with the key fob about your person, you grab the handle to unlock, you touch the little oval sensor on the outside edge of the handle to lock.
What I like on these summer days is if you hold down the unlock button on your key and hold it until all the windows have fully opened and the sunroof has popped up. Nice.
I think it also works on door handles, at least in reverse order. When I notice that I've left the sunroof and/or windows open I just touch and hold the "lock" on the handle to close everything.
Nice. I'll have to give that a try. Normally, I do all that when I'm still inside the car.
Thank you for that, i would not want to continually use a faraday case to protect it from the possibility of relay theft, just a simply key is what i like.
There was a change for the MY19 model that meant the key fob was only transmitting when it was moved. So if its just sitting somewhere in the house, it shouldn't be transmitting.
KODA SUPERB - change of the product MY2019
KESSY-key motion sensor
Key without movement does not transmit signal for a certain period of time - protection against thefts.
The wireless remote control will be equipped with a position sensor.
Presently
- Possibility of theft
New
- Key without movement secure
- The key is in motion without protections
Previous thread:
https://www.briskoda.net/forums/topic/458312-my19-keyless-keys/
https://www.briskoda.net/forums/topic/453455-kessy-security-problems/
That's not true, at least not on my MY19:  You have to physically place your hand inside the door handle and only then it will unlock.
Simply walking close to it or even standing next to it won't do it (for the better imo).
Renault does this and it is a nice feature, but the trade off is....well, having a Renault
Touching the door handle isn’t really hassle, and I believe you can do something with VCDS and even Carista where once the engine is switched off and all doors are closed the car locks itself immediately.
Useful for some but useless for me because then I have to unlock it all again to get the dogs / shopping out, unless you leave your door open until finished.
Yeah, Renault as you say, albeit others do the same but you’re right; it’s not a hassle just to touch the handle but it’d be nice to have the option.
There’s the “slam the bloody door” locking that can be set up in VCDS - is that the one you’re thinking about?
It is possible to fully disable Keyless, but you'll need VCDS or OBD-eleven.
https://www.vwroc.com/forums/topic/30978-how-to-disable-kessy/
I've disabled KESSY on my 2016 Superb, the only downside is you have to hold the key to the ignition barrel / button to get the car to start.
The method I have used is after exiting and closing the doors, lock the car with the key then touch the outside of the handle to disable kessy (my18).
That’s the one! 😂
That’s very true and not only do I totally agree, but was what I meant to put.
I blame it on a lack of brain to finger coordination! :thumbup:
Ha! I usually blame it on autocorrect.  😀
