ECU problems or not?
Mine didn't come with a carry case - the tight arses! 🙁
Didn't get a CD either.
  • Replies 58
  • Views 21.3k
  • Just a quick update on what it was.   There was no power going to the ECU and all the fuses in the ebox needed cleaning out and original fuses needed fitting as some cheap one in there were
  • Breezy_Pete
    Breezy_Pete
    Check/replace the fuse if you haven't already, relay coil fuse is number 10 in the e-box, should be 5-amp rated. Look for corrosion or looseness of contacts, as well as fuse itself. If that is OK
  • It's quite probable that the ECU has more than 1 12v supply to it, but you need the wiring diagram ( which Wino may have access to ) to see.   Also might be worth removing the battery lead f
Petrol dave told me to buy it from where I did so i got him to thank for the extras :)
Not Gendan then?
Ok Guys I done an Auto Scan... see below, it was all running fine before I had the mobile Mechanic change all the shocks.
Thing is what to do next?.  I do have it booked into an engine management specialist on Monday I have had the ECU checked and told thats running ok but it could be an intermittent fault
Tuesday,11,August,2020,13:14:24:35642
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: TMBKE21Z788009343   License Plate: NX57GHB
Mileage: 310690km-193053mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
VIN: TMBKE21Z788009343   Mileage: 310690km-193053miles
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 1010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AD    HW: 1K0 614 517 AD
   Component: ESP 4MOTION MK60-AT 0102
   Revision: 00H14001
   Coding: 0023170
   Shop #: WSC 73430 790 00000
   VCID: 698E4478957151E3E5D-803C
7 Faults Found:
01309 - Power Steering Control Module (J500)
            004 - No Signal/Communication - Intermittent
01317 - Control Module in Instrument Cluster (J285)
00474 - Control Module for Immobilizer
01324 - Control Module for All Wheel Drive (J492)
01299 - Diagnostic Interface for Data Bus (J533)
            008 - Implausible Signal - Intermittent
01314 - Engine Control Module
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 R    HW: 1Z0 907 044 R
   Component: ClimatronicPQ35 110 0402
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 45D6A8C8D9A95583215-8010
5 Faults Found:
00538 - Reference Voltage
            002 - Lower Limit Exceeded
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
01316 - ABS Control Module
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005018991
   Coding: E18A0F130004100000110D000000000000087F065C000000000000000000
   Shop #: WSC 07894 067 57207
   VCID: 71BE2C18BDA1A923ADD-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 060607 022  0601
   Coding: 00055223
   Shop #: WSC 07894
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     250607 046  0204
   Coding: 00471077
   Shop #: WSC 07894
10 Faults Found:
01800 - Light Switch (E1)
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.30 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
02071 - Local Databus
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.25 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
01321 - Control Module for Airbags (J234)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.20 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 10.55 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.70 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 8.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.25 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00926 - Terminal 30
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 5.00 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1A3RTX
   Coding: 0020788
   VCID: 3D26C028B1791D43795-8068
   Subsystem 1 - Serial number: 6332MSME184A620EG
   Subsystem 2 - Serial number: 6342MSME1C044D46G
2 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0002042
   VCID: 015E7CD88D01B9A35DD-8054
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
No fault code found.
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4311023
   Coding: 0007402
   Shop #: WSC 11111 067 57207
   VCID: 392ED438A551216355D-806C
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:01:31
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:44
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:44
Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 160607F2000472
   Coding: E9837F0E0002022303
   VCID: 3038E91C762BE02BE23-8064
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:01:33
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:45
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:45
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:03:38
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:08:44
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   VCID: 3634DF04944FCE1BB8F-8062
2 Faults Found:
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000758
   VCID: 3828D13C9E5B386BAA3-806C
2 Faults Found:
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 73430 000 90108
5 Faults Found:
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Mileage: 310680 km
                    Temperature: 14.0°C
                    Voltage: 10.50 V
                    Voltage: 10.30 V
00778 - Steering Angle Sensor (G85)
            000 - -
             Freeze Frame:
00573 - Steering Torque Sensor (G269)
             Freeze Frame:
00625 - Vehicle Speed Signal
             Freeze Frame:
                    Mileage: 310680 km
                    Temperature: 14.0°C
                    Voltage: 10.70 V
                    Voltage: 10.50 V
00668 - Supply Voltage Terminal 30
             Freeze Frame:
                    Mileage: 310680 km
                    Temperature: 14.0°C
                    Voltage: 10.20 V
                    Voltage: 10.00 V
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 81801A085283007F3F02050FC0085F96907C00
   VCID: 035276D0971DABB34F1-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Component:   Sounder No Answer
   Subsystem 7 - Component:       NGS n.mounted
3 Faults Found:
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:03:03
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:08:43
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:03:38
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000758
2 Faults Found:
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000008
   VCID: 74B0250CC2B39C0B46B-8020
3 Faults Found:
00070 - Starting Battery Voltage
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0019189
   Coding: 0000402
   VCID: 2E04F7646C1FF6DBF0F-807A
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 372AD20093453713A39-8062
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
1 Fault Found:
00576 - Terminal 15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:37
End----------(Elapsed Time: 01:25, VBatt start/end: 12.0V/12.3V)-----------
Address 01: Engine
Cannot be reached
   Revision: 00H14001
   Coding: 0023170
7 Faults Found:
5 Faults Found:
            009 - Open or Short to Ground - Intermittent
   Coding: 00055223
   Shop #: WSC 07894
   Coding: 00471077
   Shop #: WSC 07894
10 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.30 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.25 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.20 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 10.55 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.70 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 8.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 11.25 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00926 - Terminal 30
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 5.00 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.15 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0020788
2 Faults Found:
   Coding: 0002042
   Coding: 0007402
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:01:31
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:44
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:44
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:01:33
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:45
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:45
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:03:38
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:08:44
   Coding: 0000001
2 Faults Found:
   Coding: 0000758
2 Faults Found:
5 Faults Found:
             Freeze Frame:
                    Mileage: 310680 km
                    Temperature: 14.0°C
                    Voltage: 10.50 V
                    Voltage: 10.30 V
            000 - -
             Freeze Frame:
             Freeze Frame:
             Freeze Frame:
                    Mileage: 310680 km
                    Temperature: 14.0°C
                    Voltage: 10.70 V
                    Voltage: 10.50 V
             Freeze Frame:
                    Mileage: 310680 km
                    Temperature: 14.0°C
                    Voltage: 10.20 V
                    Voltage: 10.00 V
   Coding: 00000000
   Shop #: WSC 73430
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:03:03
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:08:43
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:03:38
   Coding: 0000758
2 Faults Found:
   Coding: 0000008
3 Faults Found:
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
1 Fault Found:
00576 - Terminal 15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 139
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:07:37
End----------(Elapsed Time: 01:19, VBatt start/end: 12.3V/12.3V)-----------
Edited by sealover1
13 minutes ago, sealover1 said:
Address 01: Engine
Cannot be reached
Is the engine ECU fully plugged back in?
I just been chatting to a guy who told me cuz the battery went flat I should do a fault reset and scan again, everytime I turn the ignition on for some reason the radiator fan starts up, if I pull out the ECU relay it stops and after a while starts back up again.
I did notice last time we pulled out the ECU relay and put it back then it found the engine.
I will go and scan again when it cools down a bit as the cars like an oven in there right now but will check all the plugs before scanning
Edited by sealover1
oh that guy explained to me I had fitted coilovers not normal shocks and there more for rallying not sure it that would cause loads of faults to show up?  have bought some normal shocks to go on after I get it started and will sell the other ones
Edited by sealover1
Try to get a photo of the point on the rad fan where the wiring goes in too, next time you're out with it.
Suspension won't be anything to do with this, unless some wiring was somehow damaged during fitting.
I cant see where the wiring to the rad goes Wino but I did clear all faults and rescan the car and this is the 2nd time which was nowhere near as long but still cant seem to get into 01 engine status,
done a port test and says must register would that stop it? where do I register?
Tuesday,11,August,2020,14:50:04:35642
www.Ross-Tech.com
Mileage: 310690km-193053mi   Repair Order: 2
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine
Cannot be reached
   Revision: 00H14001
   Coding: 0023170
1 Fault Found:
1 Fault Found:
   Coding: 00055223
   Shop #: WSC 07894
   Coding: 00471077
   Shop #: WSC 07894
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.30 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
   Coding: 0020788
   Coding: 0002042
   Coding: 0007402
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:38:22
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:38:24
   Coding: 0000001
1 Fault Found:
   Coding: 0000758
3 Faults Found:
             Freeze Frame:
                    Mileage: 310680 km
                    Temperature: 29.0°C
                    Voltage: 12.30 V
                    Voltage: 12.10 V
            000 - -
             Freeze Frame:
             Freeze Frame:
   Coding: 00000000
   Shop #: WSC 73430
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 310691 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:38:55
   Coding: 0000758
   Coding: 0000008
1 Fault Found:
   Coding: 0000402
   Coding: 0000144
   Coding: 0000144
   Coding: 0000001
End----------(Elapsed Time: 01:16, VBatt start/end: 12.7V/12.3V)-----------
I've never owned full VCDS, but I guess registering is done at Ross-tech.com?
Looks like communication between engine ECU and the rest of the car is the main problem at the moment then.
I would wait for Langers 2K but my guess is canbus gateway or a physical failure of the canbus wiring as it appears that there are not comms with any of the modules.
Lots of low voltage warnings also so it would be worth cleaning and deoxidising all the battery terminals and the big strip fuse terminals.
Does the central locking, electric wndows etc work normally, they all rely on canbus communications.
Have you had any water leaks? Water & corrosion of terminals with a partial short circuit could drop out the comms.
Given the absence of comms with the ECU have you properly re-engaged the connector and pulled the latch lever fully home?
Maybe while you are waiting open the bellows on the drivers door to check there are no fractured wires shorting, ditto the other doors but the drivers gets the most use & usually fails first.
Check cabin fuse No.1; 10 amp. It's an ignition 12V feed to the engine ECU.  I can imagine that if that  has blown it won't talk to anything.
yea central locking, electric windows etc work all working normally,
I checked the No 1 10amp fuse and that is ok, funny though as when I turn the ignition on the rad fan goes on after a few secs, but when I took the No 1 10amp ECU fuse out the fan went off as it does when I take out the ECU relay in the ebox
Also might be worth removing the battery lead for a couple of minutes, just in case something in the ECU has got in a tizzy & needs resetting.
yea I have tried removing the battery lead a few times to see if it helps but no joy
@PipH you're right, there are three ECU pins that get a permanent 12V feed from one of the e-box fuses, a 30 amp one, fuse 13. It's straining my vision a bit to see, but it looks like it might be the lower of two just to the right of centre in the OP's photo on the previous page? Looks like it's already been changed at least once due to being a visually different style to the others.
@J.R. I agree that I'd be hoping @langers2k might be able to use his knowledge and experience to help here.  The engine ECU appears to have both K-line and CAN comms, so I would have thought one or the other could be talking to the VCDS diagnostics unless there was something 'global' like a power feed fail?
The fan behaviour may be the key to all of this, but I'm struggling to get my brain going today.
ok thanks for helping guys means a lot, lets see if  @langers2k  can help :)
I still need to source a ECU seal what would you need to know to start a search please guys?
Edited by sealover1
Photo showing where this seal goes?
And get onto checking that fuse No.13 in the e-box while you wait for anyone else to step in.
yea fuse 13 in the e-box is fine will these photos help with the seal?
.452770965_ECU02.jpg.70fbf441845a4b3b04157edec2eb4295.jpg182577100_ECU01.jpg.58147bad9f017f3b27dcc3e04a241c13.jpg
Which relay have you checked? According to the wiring diagrams on Elsawin there's two under the dash, one controls terminal 30 power which is referred to in some of your fault codes. (B4 in attachment)
Not (for me anyway) without an arrow or verbal description of where in those photos this missing seal should be.
Only in relation to interior lighting I think.  The terminal 30 (permanent 12V) supply to the engine ECU (and a bunch of other stuff) all comes direct from battery positive through the relay in the ebox, the only one in the photo on page 1; which is the one that's been changed I believe.  Good idea though.
I'm crap at drawing but do you get what I mean Wino? it goes along/inside the grove
Edited by sealover1
Dunno, can't spot it in the parts catalogue, and none of the ECUs on ebay that I've just been looking at seem to have anything there.  What's it seal against?
