Hello all, im looking to get my air conditioning serviced on my Skoda Fabia estate Monte Carlo 14 plate. I’ve just received a quote from a company saying.....
“From 2014 vehicle manufacturers have introduced a new air conditioning system that takes a new HFO-1234YF gas. There is a possibility that your vehicle may require the new HFO-1234YF gas.  The full service for that is £120. If it's the normal R134A gas then the full service on that is £60”
Can anyone shed some light on weather it’s the new or the old system in my fabia?
thanks in advance
Steve
There should be a sticker in the engine bay stating which gas is in the system
Would this be it?
Seriously?
2 minutes ago, sepulchrave said:
Seriously?
Sorry I misread what I was looking for 😂😂
Thank you for your help 👍🏻
£60 then
Yep. Well happy about that 😃
1 hour ago, sepulchrave said:
Seriously?
4 hours ago, pavinjo said:
Pavinjo, Seplchrave was suggesting that the OP should have spotted the number/code in the photo and the differing gas numbers... Hence a spot of sarcasm..
As with anything, if you now, you know!
SkodaSteve88, Kwik-Fit offer gassing for around £50 and offer a deal where if it is less then 10% cooler, you don't pay. (If you trust them... Some do, many won't). Other a/c regas centres often say if the system leaks and/or they can't regas, they won't charge.
Also, ATS (Multiple locations) Had a groupon offer, re-gas for £38.99, down from £60. I am unsure if its still available but worth a search and if no luck, worth phoning your local branch to see if they can match the deal or offer a better one then £60. They may match Kwok-Fit, for example. A little cheek can go a long way!
Be sure they do a thorough job though and don't just "Top-up the gas you have. A full removal, leak test and regals will take around an hour or so.
