Karoq VCDS coding
Peeky thaks for all things
Can you help me on skoda karoq 2021 if any code to active navigation on mib3 and thanks
  • Replies 52
  • Views 29.5k
  • Disabling or turning down the Soundaktor   Disabling or turning down the Soundaktor reduces the engine sound especially in sport mode. From the VCDS main screen click the button “
  • Do you have the latest version of the VCDS cable?
  • So coding this has been done on a 2020 Sportline Karoq most if not all of this coding is common on most VAG cars and has worked on my car. This was coded on a HEX2 cable from RossTech. I take no respo
Peekey34
Thanks for your help
But are this codes work on karoq 2021?
Itry many not accpet coding
Great help peekay
But I have karoq 2021
Ans vcds he didn't accept 31347
on it rofucd it
any help on that i got last version on vcds too
@rawy vcds should offer you the security code. Make sure you have installed correctly the SW, I had the same issue in the past with my vcds and it turned out that in the installation process I've forgot to check a box(install 32bit driver or something like that). Once I did that, all of my issues were gone.
  • 4 months later...
Hi everyone.  Can someone help me with "Rain Close sunroof and windows" coding?
  • 6 months later...
On 09/07/2021 at 15:34, peekay34 said:
Ambient Lighting 30 Colours
In VCDS go to module 9
Security Code 31347
The colors are given in RGB coding
RGB is the acronym for Red-Green-Blue. Colors are made up of 3 parameters, with values in a range between 0 and 255.
Each color is encoded with a percentage of (Red, Green, Blue).
For example, a pure yellow can be defined as rgb (255, 255, 0).
I have attache an example of the colours I have set but you can use this as guide for more colours
RGB Color Codes Chart (calculatorx.com)
Changes can be started use lines in attached doco from 11-30 to add colours to existing 10 already enabled.
Rotwert Farbe  = Red
Gruenwert Farbe - Green
Blautwert Farbe = Blue
ambientLIGHTINGCODEING.docx
Does this work on FL too?
On 12/07/2021 at 10:23, peekay34 said:
I have the Alcantra Seats in my Sportline. For some unknown reason that I can't work out Skoda does not supply the mirror that does not mirror dip. They only included that option with the lessor model with leather memory seats (so I am told.)  My car is the top of the range with all options (lane assist read radar) available in Australia but still no mirror dip. I did some research and found that the mirror with memory function is missing from my car. So I ordered the mirror with memory function simply replaced the  mirror and recoded and it worked.   Since I dont know what model  you have I can only advise mirror assembly I purchased. 57C857507K pretty sure thats the part no.  https://www.oemvwshop.com/57c857507k-rear-view-mirror-housing-p2335210/
What's the part number for left hand drive cars for the right dipping mirror?
  • 10 months later...
So, to revive the topic: has anyone done VCDS coding on their Karoq and did it work?
I have:
GREEN score tracking
Offroad menu
Rear lights during daytime running lights
Power steering stiffness (harder)
Locking the car when starting
Compass display
Oil temperature on OBD
Closing windows against rain - not possible, in group 09-->07 there are only codes 0000000000 - coding here is not possible.
The menu shows Wiper mounting position - not possible
I have:
Offroad menu
Compass display
Which year is Your Karoq? May I code the off-road menu on my 22 FL?
Hello. VCDS coding – locking after leaving the vehicle – successful. But when I walk to the rear doors, they lock. Can this be set to, for example, 3 meters from the ignition switch?
Before making any changes, note down the original values.
Incorrect coding can adversely affect the function of the control unit; you are responsible for this. If the off-road menu does not appear on the radio after coding, restart the radio by holding down the power button until the radio restarts. It works for me:
5F - Electrical info »
[ Security access - 16 ] »
S12345 »
[ Adaptations - 10 ] »
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15 » New value "Activated"
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass » New value "Activated"
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high » New value "Activated"
S12345 »
Do You suggest to write down original coding so I can return to it in case the new doesn’t work/restore it? You coded this menu via VCDS? Which voices can You visualize? Can You post an image of the Off-road Menu?
Edited by Benja77
Hi new to the Koraq an I’m wondering if o can code out kessy ? I believe that’s what it’s called basically when I turn off my car and get out I close the door and all the doors lock automatically and I’m worried I will leave the keys in the car one day and get locked out
On 23. 2. 2026 at 18:04, noxik600 said:
Před provedením jakýchkoli změn si poznamenejte původní hodnoty.
Nesprávné kódování může nepříznivě ovlivnit funkci řídicí jednotky; za to nesete odpovědnost. Pokud se po kódování na rádiu neobjeví menu Off-Road, restartujte rádio podržením tlačítka napájení, dokud se rádio nerestartuje. U mě to funguje:
5F - Elektroinformace »
[ Bezpečnostní přístup - 16 ] »
S12345 »
[ Adaptace - 10 ] »
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15 » Nová hodnota „Aktivováno“
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass » Nová hodnota „Aktivováno“
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high » Nová hodnota „Aktivováno“
Anwendungen » [Kanalzuordnung] » Ziel- und Sicherheitszugriff –
Gesamtes Fahrzeug (nur CAN) // Um nur eine bestimmte Einheit zu sichern, wählen Sie „Steuergeräteadresse“ und geben Sie deren Nummer ein, z. B. 5F – Elektrische Informationen//
Funktion – Anpassung
Ausgabe – Roh-Hexadezimal
Nur das Hexadezimalformat kann zur Wiederherstellung verwendet werden.
On 14. 3. 2026 at 19:05, chadders_86 said:
Ahoj, jsem nový v Koraqu a zajímalo by mě, jestli můžu odemknout Kessy? Myslím, že se to tak jmenuje. V podstatě když vypnu auto a vystoupím, zavřu dveře a všechny se automaticky zamknou. Bojím se, že jednou nechám klíče v autě a zamknu se venku.
Hello, with KESSY – the keyless entry system – you can unlock your car at any time using the door handle after locking it. ANYONE can unlock the door. It's better to keep the key in your pocket and never take it out.
Edited by noxik600
Can You please write in English?
3 minutes ago, Benja77 said:
Můžete prosím psát anglicky?
Sure, I'm like a translator 😄
Applications » [ Channel Assignment] » Target Access and Security –
Whole Vehicle (CAN Only) // To back up only a specific unit, select "ECU Address" and enter its number, e.g. 5F – Electrical Information //
Function – Assignment
Recovery – Raw Hexadecimal Format
Only Hexadecimal format can be used for recovery.
  • 4 months later...
S12345 »
Can You visualize the OFF ROAD menu having the PERFORMANCE/SPORT menu activated? I mean can You visualize both of the options OR have You to choose one of them?
noxik600
Do you have the coding so I can enable "Rear lights during daytime running lights", as I see this is one of your mods.
Thanks in advance
18 hours ago, tecton said:
noxik600
Daytime running lights with taillights Method
This method is for cars that have taillights on two channels (left light and right light).
for cars: ŠKODA SuperB 3, Kodiaq, Octavia, SEAT Leon,...
09 - Central electrical installation »
[ access security - 16 ] »
31347 »
[ Customization-10 ]»
- setting the brightness values (dimming values) for both channels according to group AB 23, if we have 100, then we set 100, if we have 127 set in group AB, we set 127.
Leuchte23SL HLC10 - Dimming value CD 23 » new value "127"
Leuchte23SL HLC10 - Lighting function C 23 » new value "Daytime running light"
Leuchte24SL HRA65 - Dimming value CD 24 » new value "127"
Leuchte24SL HRA65 - Lighting function C 24 » new value "Daytime running light"
Many thanks. I'll try this weekend.
S12345 »
Hi! I tried but nothing; any other suggestions?
Mib3?
Yes
Dont Work anymore What i know
Can check with my 3 devices
