Misfire when cold, boost leak?
Hi! I'm a new owner of a yeti 2.0tdi cr 110hp 4x4, however the car has some issues when cold. When I build up boost pressure the car starts to misfire. This is worst when cold and fades away as the engine gets warm. I ended up buying a VCDS device and logged a short trip yesterday and as I'm suspecting a boost leak I only logged sensor data for that. If you guys have suggestions of what I should log next let me know.
I've attached the log file i made driving a short trip around the neighborhood and it looks like I'm getting less boost than requested and it also seems to lag behind. I don't know if these numbers are within some margin though. A scary fact is that the car has gone 50.000km between the two last oil changes, so I'm worried its not only a simple boost leak.
LOG-01-IDE00190_&3.CSV
