Bolero MIB1 Update Help Please!
And How can i activaded " smart Link"
  • Replies 248
  • Views 40.4k
  • Guys you must post your system model number and SW version first...
  • Downlad link you both have on PM. To get Android Auto you must have both display and glove box unit exchanged. If you are interested pls contact me on PM.
  • 5E0919605H is MIB2 screen so glove box unit must be exchanged as well
I did ask a question of you to find Software Train.
Smart link can be done one of two ways, an expensive code from the dealer, or a free method, that needs you to have VCDS of similar tool, so that you can place the radio in developer mode.
ok thank you
Hi, i would like to update my Bolero unit, details below. Are there any unlockable functions?
Yes, you can have an update to 0490 version, no idea of any functions you can activate.
Hello, could you please send me an update for this one?
Thanks in advance!
Thanks in advance!
Yes I can send you an update
@pab567
this my device any help with link
i download these file but SD not working?
can this be done by USB?
This should be done with SD, started from Service Menu (lon press MENU button)
not working i try a lot with FAT32 and EXfat
can it be done with USB?
should i add all 3 folders or only one?
You need to extract that compressed 7z file to the root of an SD Card, so extract all to M: for example.
And as said by Pab567, you need to be in engineering menu... so press and hold Menu/Setup button for 10 seconds to find page where Software Train is seen, and use that update button.
Forget about USB
The correct screen shown here, and press the update button in this location.
980524946_Octavia3version1.jpg.8b565650aed138b565384dddb1f8982d.thumb.jpg.467347d46c28497a4810488facb16c0e.jpg
Edited by varooom
this what i found no SD card Slelected
i format SD card form windows and just copy file to it
what do u mean by Root of SD card?
By "root" of SD Card, this means the bottom folder.
Some will make the mistake of creating this kind of path
F:\MSTD_EU_SK_P6230_0490
When it should be extracted to...
F:\
As seen in your image above
Hello, can i ask please  where can i  get MSTD_EU_SK_P6230 cant find it, now i have MSTD_EU_SK_P3163 and wanted to update
I have MIB1 Amunsen
I have MIB1 Amunsen
I will send this via Private Message
Hello some version for MEN2_EU_SK_P4350L cant find any on mib-helper
7675784.thumb.jpeg.844528c0465cab19fe83f7cd992d7a9b.jpegHello,
Update for this one if available?
Having problems getting android auto to work with it.
Thanks in advance!
@batgruyo I will send you a link to 0480 version
This last version?
Still have problem keeping restart i didn't know what i shoulde do?
4 hours ago, Mazen86 said:
This last version?
@pab567 This sounds like a hardware fault, recently updated to 0490 version and still errors.
Maybe swap to a MIB2 unit?
What is MIB2 unit
A unit that supports Android Auto and Apple CarPlay.
10 hours ago, Mazen86 said:
What is MIB2 unit
You have a MIB1 System (1st generation)
MIB2 is 2nd generation and as mentioned by @pab567 can support Android Auto/Apple CarPlay for he is the hardware expert 🤝
  • 3 months later...
Hello @pab567 and @varooom !
May i have the update for my system ?
Thank you in advance.
PM
