Bolero MIB1 Update Help Please!
Hello, is there known improvements with update 0421 to 0490 ? I have O3 with bolero infotainment. Sometimes it is lagging when I use mp3 audio from sd card. Anyone knows that update to 0490 could fix this problem ?
Edited by radoszczak
  • Replies 248
  • Views 37.6k
  • Guys you must post your system model number and SW version first...
  • Downlad link you both have on PM. To get Android Auto you must have both display and glove box unit exchanged. If you are interested pls contact me on PM.
  • 5E0919605H is MIB2 screen so glove box unit must be exchanged as well
that should fix the problems.
I have question about size of update. My bolero mib1 doesn't have NAV function. I have download 0490 update but it's size is about 5 GB after unpack from 7z/zip. Have I downloaded accurate version ? In my case I need only to update main firmware without maps etc. Thank you in advance.
Update succes. Ignition on, engine off, charger connected. Estimated time of update is 20 minutes via 8 gb fat32 pendrive.
Hi all hope your all having a great day..
any chance someone can send me the update file please .. and instructions
thank you ...mib1 Octavia 64
thanks in advance ..
Download FW https://easyupload.io/p9xaox MSTD_EU_SK_P6230 (0490)
Unpack archive to sd card or pendrive (min 8 GB) fat32 file system
Unpack files directly to root folder of mass storage so the car could see it
Prepare charger for battery in your car
Connect charger so battery will not lose voltage when update will proceed
Turn ignition on, engine off
Press menu button for about 3-5 sec
Get into service menu
Choose right mass storage usb/sd card
Follow instructions
DONT'T turn ignition off while update
All at your own risk - there is small risk that you can brick your unit
Good luck
Could you send me update link for minę version?
I would be grateful for your help. I recently bought a Skoda Octavia with a Bolero MIB one system - details see below.
Would anybody be able to forward me an update - I believe there is one with version 490?
Thank you very much!
On 06/09/2024 at 15:21, skooct said:
Thank you very much!!’
You're welcome.
Hello, can you someone send me link to update to MSTD_EU_SK_P6230?  (Czechia)
And where i can get maps EU for 2024.. on skoda web have only 2020/2021 maps..
Thank you
@pab567 I’m hoping you can help me get required updates pls?
@pab567 have you please a link for a software update for Bolero2? My current version is 5E0035840A,
Hardware 040,
Software 0421.
My car language is German.
Many thanks in advance!
Kind Regards,
Andi
Thank you
Unfortunateky there are no newr maps for your system as it ran out of support time 😞
@Hookandi you have fw download link on PM
Hi guys. Could any one of you please send me the latest firmware for my Octavia 2015 Bolero? Also, is there any changelog of the versions available online?
Update on this.
- I long-pressed on the menu button, which gave me access to the Service menu.
- Then I got the SW Train and put it into mib-helper.com.
- The website informed me that the latest compatible update was 0490, so I got that installed. It seems to work with no issues.
- I was a bit skeptical at first to perform the install as I saw rumblings of a possible `DTC 1555 / B201A` error, but my system did not have that.
- So, In summary, everything works great. I hope this helps If anybody else want to do this.
Some questions though.
I saw somewhere about a SmartLink function, is it not supported on this model of MQB? I was half expecting to see something after the update, but nope.
  • 5 months later...
On 2023. 10. 29. at 19:44, Bazsa77 said:
Helló!
Az első két kép az enyém.
Hogy tudnék ehhez magyart adni, mint a második két képen?
Ezenkívül a MirrorLink vagy az Android Auto aktiválható valahogy?
Helló!
YA khochu obnovit' mul'timedia moyego avtomobilya Skoda Octavia 2014 goda.
Mozhete li vy pomoch' s versiyey MIB1 0435?
