Infotainment Model Numbers
  • john999boy pinned this topic
  • Replies 145
  • Views 66.7k
I  have 5Q0035874B What difference letter B makes? :thinking:
See this thread Infotainment retrofitting by @pab567 it's a MY17 MIB2
I'm very new here, thank you for guiding me :handshake:
  • 10 months later...
Mine is 5e0035871b, MY 2016
Hi,  New to the forum!
I'm in Melbourne Australia.
My Part number is 5E0035045B
Can someone please confirm what this soundsystem is?  MIB2?
I believe its a Columbus MIB2 but cant finf any info to confirm.
any assistance would be greatly appreciated.
I have a 2014 Octavia Elegance 1.8 TDI Wagon
Cheers
Paul
Cheers
Paul
2014 = MIB1 since the MIB 2 only entered production during 2015 (for 2016 MY?).
So yes it's a Columbus, but a MIB1.
My friend has a 5Q0 035 840 C device. MIB 2 Amundsen, likely, but could it do navigation?
It's an Amundsen, so all it needs is the correct Skoda SD card (note it MUST be a Skoda SD card not a 'vanilla' SD card).
I'm struggling with my Sat nav in Mt mkIII Octavia. I believe that it's an Amundsen MIB 1.
And comes with a 5E0051236C card.
The questions are:
1. How do I use Post codes for navigation?
2. How can I update the card?
Thanks.16507942197782783263447223873749.thumb.jpg.97da2bee60b072856694c9c81ec3433c.jpg
The questions are:
1. There is a button labelled 'PTCD' (in the lower left IIRC) that appears when you are entering a destination.
2. Map updates can be downloaded from the Skoda portal (or from direct links posted on here), make sure you download the Amundsen MIB1 update that includes the UK. I always save the contents of the SD card to a PC hard drive, then quick format the card (FAT32 with 2K cluster size) and having unzipped the downloaded file copy all the unzipped contents onto the SD card. Insert the SD card into either of the SD slots in the glovebox and wait - sometimes I had to remove and reinsert the SD card for the Amundsen to correctly identify it as maps.
I am very new here and just purchased mk3 2019 VRS 245HP. I have been reading through some threads and unsure if all my firmware is up to date. Can someone point me in the right direction, with a guide on how to do it.
If I use online update nothing seems to happen.
@pab567 is it possible for PM and info on updating firmware, I have figured out the maps through Skoda website 😊
PM
Good evening
i have memory card
the code writen on it is    5EO 051 236E
and i post the picture of head unit as well.
So what update i need.
Thanks very much
The SD card is navigation only not for updating the infotainment unit. You can login in to the Skoda portal with your VIN to update maps. You have to use Skoda format SD card for this, any other will not work.
Edited by FrankNicklin
10 hours ago, Arfanahmed said:
Good evening
i have memory card
Thanks very much
You can update the firmware from
MSTD_EU_SK_P3420 (0435)
to
MSTD_EU_SK_P6230 (0490)
Maps answered above by @FrankNicklin
Thanks very much
Thanks very much
from where i can download this
1 minute ago, Arfanahmed said:
Thanks very much
I can provide a link via PM in a few minutes.
What Country are you in? (as firewall on server is locked down via Countries)
Thanks very much for ur help, i am from UK
Download should work then without issue.
Hi everyone,
I have an Amundsen ? MIB ?
Device: P/N 5E 003 587 4A
H/W: 040
S/W: 0421
Unfortunately, due to being recent 2nd hand purchase, I don't have a Skoda official SD card.  Previous owner has probably lost it.
Out of interest, would the original card work in another vehicle? or would another official card work in mine?
I've just downloaded maps from Skoda site with my VIN and noticed the DBInfo.txt file contains P/N's etc. but none of them match my system. Is my unit a replacement?
Thanks for any help on this
1 hour ago, zeta said:
Hi everyone,
H/W: 040
S/W: 0421
The MAP cards are usually 16GB/32GB.
They can be used across the whole VAG group, they have a special CID embedded in each that the unit checks and then allows maps to be loaded.
I bet you will find many on the bay of E, and you will be golden.
Hi all,
I am new to this forum and need some advise please.
I have a 2018MY octavia with the following infotainment system:
5Q0035842C
H41 hardware
0472 Software.
I would like to change the unit to include sat nav what do I need to do and can you recommend anyone in the West Midlands that can do the job for me?
