Electric Windows
Hmmm strange
i fitted a bosch battery,  been 3 weeks no issue
Edited by Badgertech
  • Replies 98
  • Views 11.8k
There is a window control motor on the driver's side
the control unit is bad
I'm calling for service tomorrow for repairs
There is a window reset method involving holding door switches ? I found in google,mine luckily was just a faulty switch
I tried all the usual suspects
like i said, a new battery was my result
i replaced fuses, door switch and the door control module, basically replacement door motors, all still didn’t solve it
Does a different door  module will need coding by any chance?
Image 1 - VW-SEAT-SKODA-RIGHT-DRIVER-SIDE-FRONT-WINDOW-MOTOR-CONTROL-MODULE-1K0959793C
No.
I don't know where to begin.
I bought another module, with the same part number but somehow it had written 2001-2007 on it. Mine is a 2007. I guessed that they must have been using the same parts from previous models. Anyhow, the connectors look to fit but the module inside looks different. Plugged it in, and didn't work.
I plugged the old unit and Voilà!! Both windows worked fine......for 10 seconds. Then none of the windows worked. I unplugged the harnes plugged it back in, it worked for another 10 seconds. I tried to make a video but could no longer replicate the scenerario so now I'm back as before.
I don't know what to do anymore.
Like I said before, replace the battery!
I have already done that!
A brand new battery?
I tried everything and a new bosch battery sorted it
been a month now no issues
Yes I just bought one for my other Fabia and tried it. The current on on it is about 4months old. There's no way the brand can make a difference. I tried 2 batteries on it already.
I know I never believed the brand would make a difference
but some cars are more sensitive to voltage drops
apparently bosch have a cleaner current
maybe i was just lucky because I replaced the door switch, fuses and two window modules before trying the battery
I don't know, I'm a bit reluctant to change an almost brand new battery. I don't know....
You could try cleaning up the battery terminals and torque them down nice and tight
my lion brand battery was only 6 months old, load of ****!
bosch one fixed it
Mine is VARTA which was the OEM on my 2013. I'll find a way to maybe test on one before buying it.
That is what i fitted
I've done something to it and the passenger door works but only with its own switch. I left the harness unplugged for about 30 min.
It is Varta that manufacture Bosch batteries it seems.
A battery is a battery is a battery, they are all just chemical factories that store and hand out current at approx 12V, the important thing is to make sure that the storage capacity in Amp Hours of the new one is same as or more than the factory fitted one, also that the CCA is also the same or more, with newer cars it also helps if the technology is the same, but this car will not be a Stop/Start so basic flooded battery is good enough..
I've never heard about this "clean" or "not so clean" current being supplied, though if I was selling Bosch batteries, I'm sure that I'd try pressing that point!
I can only describe what my experience was with the nightmare electric windows scenario
The battery is a battery comment is so subjective, every “cheap” battery I have fitted over the years have always let me down
varta and bosch are reliable
My next thing is to replace the relay and capacitor on the module.
Which fuse numbers have you checked? Fuse 11?
Does the battery symbol come on when you turn the ignition on (it should)?
I checked all of the fuses to be honest. Off the top of my head 51 and 52. But I took every single fuse out and checked. No11 is for the mirrors. I don't know about the battery, I'll have to check.
Edited by Bertie90
Check no. 11 again, better still replace it. It isn't just for the mirrors. Also, make sure you're checking the correct ones, LHD/RHD fuse layouts are often poorly documented in Skoda manuals.
But my mirrors work just fine. I'll put a new one in there. Can a fuse cause intermittent faults? The passenger side work yesterday for about 1h. This morning doesn't work at all again.
I read on a forum that the relays can get stuck on one position.
I took the whole harnes out again with the motors and I'll try to bench test into see if the issue is in that circuit. I'll hook the power wires to a battery and hope for the best.
The heating of the mirrors working?
