Thule WingBar Evo with 775 feets?
Hi,
I'm looking for a couple of roof bars for my Yeti. Right now I'm leaning towards the Thule WingBar Evo 127 (in black) with the Thule Rapid System 775 as feets.
Does anyone have this setup on their Yeti? It would be awsome if someone could perhaps post a photo on how these looks on the Yeti.
I like (I think) the look of the bars and the feet but I'm not sure how far out the bars will go on the sides and what that will look like?
Edited by Jokkmokk
Typo
Whatever bars you settle for remember to make sure the slot underneath has a sealing strip, or the wind roar will really P*** you off.
@gumdrop Hm, not quite sure what you mean by that? What slots? 🙈
I think he's referring to any groove that runs down the length of the bars, where they provide a rubber infiltration strip to insert.
@gumdrop @Dale_Stevens Haha... confused I am... 🐸
Do you mean on the WingBars them self or the bars attached to the car?
Haven't seen anything resembling a sealing strip while looking around and boy have I looked around...
The WingBar Evo looks like this underneath, do you mean the two “gaps” that runs down the bar?
Edited by Jokkmokk
Added picture
Some bars (bars go across the car, the ones attached to your car and run along it's length are rails) have a channel running down the top of them so you can slide a T-bolt down it which is used to attach things like roof boxes, bike carriers etc. The rubber strip pulls out, you slide the T-bolt along and then cut the rubber strip and fill in the gaps so that wind doesn't whistle inside the channel.
Random Google image of a typical roof bar...
Edited by Dale_Stevens
Yes thats the gap, this can run right across the bars on some makes, so whatever make you decide on watch the gap.
Ah, okey now I understand. And yes, of course I will make sure to put the rubber strips in. Besides from reducing  annoying whistle sounds they have I purpose of adding friction and protection when loading things directly on the bars.
The only thing I really need now is some photos of a Yeti with these mounted... 😅
Another option is the Thule Wingbar Edge 9583 on the same 775 feet. Looks like these bars fit within the roof rails as opposed to hanging over the edge of them. Looks neater but gives less bar space for attaching things to..
The Wingbar evo (latest variation,) has two sealing strips ... so the "T" mount slides between them, and you never remove or require to cut the rubber strips .... big improvement over the non "evo" versions.
Hm, are you sure these are the same feet? This is what the setup looks like with WingBar and the 775 feet.
No, I can't say for sure, its just what I found when I was researching roof bars a few months ago. Perhaps they are different feet? I'd probably go with the Wingbar Evo
Are you using or have used these on a Yeti? Curious on how much wider they are from the rails.
Yeah, I like the aero design from lots of perspectives. Also the look when the bars sticks out a bit (though not to much), to me it gives a more rugged and adventures look. The flush roof bar things doesn’t play as good together with the Yeti in my opinion. But then again, if the bars will stick out a good 10cm from the rails, that isn’t either...
Hi, no, on the Yeti I have 127cm Aero bars, and they don't stick out further than the top of the doors ... about 100mm each side from the feet.
The Wingbar Evos, are on our BMW, and are longer (135CM) bars, so cant move them over to let you see.
Hm, but the WingBar Evo I have been looking at are 127cm so I guess that would be the same. Around 100mm you say, was hoping for less...
So, I've just ordered a package of Thule WingBar Evo 127 in black with Thule Rapid System 775. Will post a photo of the mounted bars when they arrive. :biggrin:
100mm, was best guess, but my wife always says I exaggerate :worried:
Don't we all when it comes to length?
I’d like a set of the Thule Wingbar Evos but frustratingly you can’t fit their load stops to them, and I find load stops extremely useful.
Agree, I have a set of load stop from the "old" square black bars .... real pity they cant be used with the "T" nut system bars ... :sadsmile:
Anyone know if the bars I've just posted above have any wind noise? I imagine the WIngbar Evo are quiet, but I do like to use load stops so might go with the rounder shaped bars.
Mounted and ready! 👏
Hm, that’s a real shame! When do you find them useful, in what situations? Shouldn’t a good fastening with “ropes” (don’t know the English word) do?
Anyway, making your own load stop out of wood should be to hard with the T-bolt setup when I think about it. Perhaps not pretty but hey, paint it black and no one would even think about it. 😏
Edited by Jokkmokk
Added info
Could be a fun little project, gonna order me some t-bolts and see what one could come up with.
Actually, a couple of consoles and wing nuts should do the trick? Perhaps a bit of adjustment to the console but should work, or am I to optimistic? 😏
Shorten the ends to a desired length on both sides and perhaps drill two holes for the t-bolt, slam on wing nuts to fasten. 😅
