Trevorb33’s Citigo Vrs 148Bhp (Up gti Conversion)
Is the wiring for the mirror indicators just a case of connecting to the plug for the wing repeaters?  Does it matter that the mirror indicators are LED or is that not an issue?
When will you be doing the front brakes?  If you have the front suspension leg and brakes as a complete unit can you trial fit one of the Aurigas 15" wheels?  If it fits no problem I'll start searching for the brake parts for my car.
  • Replies 228
  • Views 53.5k
  • Done Driveshaft arrived yesterday,  so got that fitted, gearbox oil filled, lovely traditional fill to spill box in these no set figure like the 5 speeds,   Coolant in and r
  • Got a little build tag made, came out great
  • Some pics from the past few days
It will be for me as I’ll be changing complete loom so mirror will plug in off the door loom, otherwise you could probably extend the wires from wing round into the door.
Made a start on rear brakes/suspension
swapped it all over as it’s nearly seven years newer.
hub/bearing, backing plate shoes etc. fitted some darkside 12mm axle spacers I brought a while back, and fitted up one side with the bilsteins and Eibach springs, test fit the wheel over the brakes it is tight but a few mm clearance from the wheel weights to caliper. I wonder if they do slimline wheel weights. It does turn without catching anywhere which is good
Looks like the front brakes will be OK with 15" alloys.  I'll start sourcing brakes for my Elegance I think.
Are there any differences with the rear brakes or axle beam?  I'm sure I've seen somewhere a rear disc conversion using Lupo GTi parts.
there’s a company that does rear disc conversions
https://theupgrade.haus/products/rear-disc-brake-conversion-kit
beams are the same all drums
the only place I’ve seen you can get the fronts from are a kit on eBay. But if your not upping power plenty of decent pad/disc combos for the standard 256’s
ebay link front kit
https://www.ebay.co.uk/itm/144114379107?fits=Model%3AUP!&hash=item218de2e963:g:L10AAOSwbDthBkQK
I saw that on eBay, would have to pay VAT & duty on that price otherwise I'd probably go for it.  Was thinking maybe one of the Polos or Ibizas had the same calipers and hub carriers.
I will eventually do the GTi conversion if a complete car comes at a decent price.  If you don't mind me asking could you give me an idea what you paid for you GTi parts.
I just brought a whole car that was written off
Edited by TrevorB33
Yes I saw the pictures. I just wondered what sort of price you got it for.
Made a start on front suspension, got both sides stripped an n/s refitted just run out of daylight again as weathers not been great, hopefully finish it at weekend 5D412A58-31E5-438E-86B6-786629CFBD5E.thumb.jpeg.606a41dc60bf285b5888ec77bae1b625.jpeg
Love all the modifications. I think we have a similar taste. Hehehe... 😅  Only disagree on the suspension, I would have opted for coilovers to be able to adjust the height if I want 😉
Really interested about the Up GTI engine/brakes conversion, but here in Spain it's impossible to get a wrecked Up GTI 😔  I'm thinking about a TSI... 🤔😅
Congrats and keep it up with this cool stuff. Miguel.
Cheers, the tsi is not common over here either just got really lucky with the gti. Tsi will still be as good power wise just with the 5 speed gearbox and not 6
Yes. It's another good option too 😉
It's difficult to change the grill? I have one MonteCarlo version waiting to be installed 😅
You can do it with the bumper on but is easier to remove it, just clips in
Good read so far and ignore part of my private message lol.
One word though I'd get the tyres changed on the UP GTI alloys, if you're using them, to 205/40/17. The other size tyres are rare and hard to come by, although I may have some if you want, and break easily in potholes. The other ones are much more hardy and are recommended via the UP GTI owners group. (I've used them and wouldn't use anything else on them).
Yeah I’ve seen the tyres debates lol only had three good ones so sold them on straight away as they get good money
Few little bits today,
boot struts swapped
boot seal swapped
rear speakers fitted
beats spare wheel sub and tool kit put in,
And the boot trim with light
obviously not wired in but when I run the new loom will all be plug and play
Edited by TrevorB33
LOL in that case I'll let you sell my four, 3 Good years and one no name tyre.... that's what happens when you hit a pothole in one and left marooned at the side of the road.
Stick them on Facebook I’ve seen them go as high as £800
Been having a test fit of the forge goodies I brought
Really cool 😍😏
Also finally found a drivers side facelift electric and heated mirror so I can get cracking on changing the door looms and fit the facelift mirrors as they have indicators built in too. And it gives me the double electric window switches and electric mirrors :)
Loving the build so far!! I am curious about the beat subwoofer. I am guessing the Up! GTI had the beats amp under the seat which is how youre going to run it to the radio?
Only reason for asking is I would be interested to know if the sub can be run without an amp via the standard radio... do you think this is possible?
Anything’s possible yes I’ve got the under seat oem amp to power it once I change interior loom, but to get it running in another car I imagine would be a knightmare, there are plenty of powered spare wheel subs that will do a better job and be easier to fit. I’m only fitting this as it’s going to be plug and play and the small size of the citigo should be more then enough
Made a start on sorting the door wiring looms.
the standard citigo only comes with single electric window switch and manual mirrors.
the up has the facelift mirrors with integrated indicators, electric and heated.
and the double window switch
with a nice brushed ally handle on the trim.
Standard door
so stripped the door open to remove old loom and refit the gti looms
5030A3E7-87FA-48A5-8A7A-2C6895B81F9A.thumb.jpeg.f45668c85a8205f14d71fa23f1c935a2.jpegA606F894-D7A2-4F0A-95CD-8474E5272D55.thumb.jpeg.efdc746eaeb7d069950c54a7b2bc68da.jpeg
as you can see a much more substantial loom with loads more wires
Finished product just needs a good clean
E3116874-D7AF-4CEA-AED9-495F6B3CC50C.thumb.jpeg.17fec7f98865fe5d7015ec86b21dae97.jpeg1ADD3195-0213-43D0-A5BC-A1EDBBF87113.thumb.jpeg.0769b2a32e586b1b4d72ab4472aa3e3b.jpegEAE1F64E-A06F-48FC-B2ED-1C7AD2F843D2.thumb.jpeg.d4df9f1bd6976aee6c35d4bf5a5fb4ec.jpeg
only had one good mirror from doner hence the blue other side. Was surprisingly hard to find an electric and heated one. I’ll change caps shortly when I find one
Edited by TrevorB33
