Travel assist retrofit
Hello,
I am gathering information about possibility of retrofitting travel assist (or at least correct adaptive lane guidance) on my octavia RS 2021.
I do not have: Columbus, traffic sign recognition, side assist.
I do have: ACC, DSG, simple lane assist (lane departure prevention).
I have tried to code adaptive lane assist (point intervention->early in A5). It keeps the car in lanes perfectly but expectedly every 10-15s asks to put my hands onto steering wheel while they're still on it.
After some hours of googling I've found out that travel assist can be retrofitted and coded (necessary blocks are not SFD-protected) by replacing steering wheel with the one with capacitive sensors.
Questions:
Will I also need integrated navigation (Columbus). If yes can I just buy it from the shop inside Bolero?
Will I also need traffic sign recognition for it to work?
Steering wheels which look the same have different part numbers (e.g. 5E3 419 093 AR VKK  https://www.cars-equipment.com/en/shop/steering-wheels-parts/oem-flat-bottom-vrs-steering-wheel-2/ and 5E3 419 093 AH VKK https://picclick.it/New-orig-MF-steering-wheel-complete-RS-FLAT-203513044462.html). Which one do I need?
Do you know anything about that?
  • Replies 162
  • Views 68.7k
  • Check if all below is done :   Select Driver Assistance A5 - Select Long coding - Select KLR - Set to Coded - Select Point of intervention - Set to Early - Select HC Warn Intensity -
  • East_Yorkshire_Retrofits
    New wheel isn't covered under warranty. Rest of the car should be unaffected    Ensure you replace the bolt that secures the wheel, and torque it correctly. Also ensure you don't mark/damage
  • Update from my last post. It appears I forgot to add the following changes A5 -> Hc_Variante: 2 A5 -> Klr: Enabled. This one will enable capacitivesensors.   Travel ass
My setup is identical. I know it is possible, but the companies that do so ask a significant sum for it. I have been quoted 900 euro for just the coding, not included the additional steeringwheel hardware.
Have a few local guys looking into it as well, will let you know when they get back to me.
  • 3 months later...
Update:
I went for it and bought a new steering wheel with capacitive sensors inside it.
Mounting it pretty easy, there are some videos on YouTube. You'll just need a M12 Spline to unscrew it.
Coding is also simple, no SFD unlock required:
Control Unit 13->Long Coding-> byte 2 -> Capacitive_steering_wheel - Enabled.
A5 Driver Assistance - Long Coding - HC_Warn_Intensity - Setting_over_Menu (activates the Travel Assist menu in the interface)
A5 -> Klr: Enabled. This one will enable capacitive sensors.
With these options travel assist will be available
Oh, and of course you'll need to set
A5 - long coding -  byte 8 - > point of intervention - early
Interesting post ... Just a little question. If I am not mistaken, travel assist uses traffic sign recognition to set properly the speed of the car ... How did you sorted it out? Were you able to code it as well?
Edited by Mario_Delgado
Travel assist doesn't read road signs. It just reads road markings
PACC reads the road signs
For those looking to save a little money, it's possible to install a module that's essentially a modified capacative sensor. It simulates your hands always being on the wheel (this doesn't mean it's ok to drive without holding the wheel 👀).
It doesn't cause any fault codes, and it's often cheaper than a new steering wheel
Edited by East_Yorkshire_Retrofits
Actually, you are right, traffic sign recognition is used to set the speed automatically. Without it, speed is only set manually which is my case. I also find it more convenient since I set a bit higher speed than on traffic sign.
p.s. I believe it's impossible to code traffic sign recognition
It's not impossible, it's just not cheap unless available in the vehicles online store, as it requires a Feature Enablement Code
Travel assist doesn't automatically set the speed for you, PACC does. For example on my car I have the predictive element disabled yet use Travel assist all of the time. It operates as regular ACC with adaptive Lane Guidance.
It works the other way around too, you can use PACC without Travel Assist enabled. They're seperate systems
It will be interesting to see if your Travel Assist works, mine (factory fitted) does not work since the last (5 months ago) software update to fix the SOS and popping, Skoda UK said it won't work until they get the ACC 'fix' that was due this month but as ever no idea when that (if at all) will come.
2 hours ago, East_Yorkshire_Retrofits said:
It's not impossible
I meant impossible to just code without FeC.
Actually I've found some shady instruction but not sure it's still working or will work with current gen. Also, odis and vas adapter are required. Check here: https://www.drive2.ru/l/593313242974033325/
It works. Without pACC but works. I had no issues with simple ACC either. I received the car in December 2021 and I'm from Estonia
That guide is useless for MQB2020 unfortunately & the TSR fec is in the canbus gateway not the radar
Worth checking if TSR is available in the Skoda store
That's exactly what I had in mind. And after all this time with the retrofit installed and working ... are you happy with it? Did you have time to use it in highway for a long distance? I am considering the retrofit as well ... but I am not sure if it's worth the money after checking a bit steering wheels' prices.
And regarding traffic sign recognition ... I'm curious, @East_Yorkshire_Retrofits you said that it's not cheap but ... Do you have an order of magnitude?
Extremely expensive for MQB2020, it costs us the same to enable TSR as it does to enable TSR & lane assist (a little less time involved). Hopefully in time, prices will drop
I installed it a week ago so no long journeys yet. But I've tested it on a highway and in town and it feels good (especially on highway ofc). You can have your one arm (or both) relaxing on a wheel while steering happens automatically. Definitely worth it, at least for me.
No alarms if your palm is on the wheel. If alarm happens it goes away as soon as you slightly touch the wheel.
On 26/03/2022 at 20:39, JustOxy said:
Update:
Hello, thank you so much for starting this thread and sharing your experience!
Am i right to say that you have replace steering wheel and with the codes, enabled Travel Assist which allows semi-autonomous driving?
I have Lane Assist but no Adaptive Lane Guidance on my Octavia RS MK4.
Question: If I would like Adaptive Lane Guidance only i.e. hands need to be on steering wheel, not changing the factory steering wheel, does it mean that it can be done through coding? Which tool did you use?
thank you.
thank you.
Adaptive Lane Guidance is part of travel assist on MQB2020
On 28/03/2022 at 18:44, East_Yorkshire_Retrofits said:
It would be around £345 with VAT, it costs us the same to enable TSR as it does to enable TSR & lane assist (a little less time involved). Hopefully in time, prices will drop
Thanks a lot for this ! 🙂 well, another item for which I will wait for a reduction in prices.
thanks, would this mean that i will not be able to enable Adaptive Lan Guidance unless i replace the steering wheel + perform the codings?
Correct, if you're doing it right
You can do it with only coding (point of intervention->early in A5) but you'll get 'hands on the wheel' alert every 10s or so
got it, will this out soon. thanks!
I managed to enable it! Thanks so much :)
PS: did you manage to get the entry assist (where the seats move when getting in or out)?
Hello everyone,
I'm new on this forum.
I drive 2021 Octavia Style. It is equipped with Columbus (with navigation), ACC, DSG, simple lane assist (lane departure prevention). There is no traffic sign recognition, side assist.
I would like to activate Travel Assist and Traffic Sign Recognition.
I have a few questions @JustOxy
1. Can you please share the original part number of the wheel that you bought? Is it equipped with DSG paddles and heating?
2. When you activated Travel Assist, does the lane assist work below 60 km/h?
Is there a possibility to activate Traffic Sign Recognition with the car equipped like mine?
Thank you!
BR
Mati
@Mati_M
PN: 5E3419093ARVKK
With dsg paddles and heating
Yes, it does
12 hours ago, Mati_M said:
Hello everyone,
Thank you!
BR
Mati
Yes traffic sign can be activated. However, if it isn't available in the skoda store then it's expensive as hell
